Sponsored by:
Sponsored by: CARiD
Help with starting...
Old Aug 17, 2005 | 10:04 PM
blackmaxx96's Avatar
There's never a day when something's not on sale
I just recently had a transmission swap done by PappaSmurf.
It takes forever to crank, and it backfires a few times in the process or turning over. I checked for codes and these were the only two that showed up:
The Crank Position sensor (The sensor that plugs into the front of the transmission that gets a magnetic sensor off the flywheel) was cracked during the swap, and was throwing a code, so I purchased a new one...
It also threw a code for the Idle/Neutral Position sensor ( the one that plugs into the driverside of the transmission).
So after replacing both, and resetting the ECU, I still have the same problem. There are no other codes showing up, and both sensors are brand new. Is there something that i'm missing here, or I should be checking for?
I really hope to get this fixed on my own, but electrical stuff isn't my favorite part of our cars :X.
Thanks in advance,
Mike
Old Aug 18, 2005 | 09:55 AM
Once it starts, it drives fine...
everything seems to be in perfect order.
BUMP-anyone?
Old Aug 18, 2005 | 06:59 PM
Bump....
Both codes are gone, and now 0407 is here....
My starter is good, and I checked the voltage on the wires for the Crankshaft position sensor, and they were good...
I really dont want to take my car to the stealership, but I've got a code thats telling me nothing, and a car that will barely start.....
Montego Murph
135
Sep 28, 2014 12:27 PM
brandnew
20
Aug 1, 2007 09:41 AM
zazon
29
Apr 13, 2006 08:58 AM
cefiro8701
Sep 17, 2004 10:22 PM
