Sponsored by:
Sponsored by: CARiD
Pathfinder TB
Old Aug 25, 2005 | 04:24 PM
Playboycutie69
Pathfinder TB
Does the pathfinder Throttle Body give that much performance gain? If so how much horses? I am skeptical about this becuz I hear its a fairly new mod and I dont want to spend $$$ andnot see significant gains.
Old Aug 25, 2005 | 05:10 PM
Backseatofamax's Avatar
this is like your fourth thread today when are you gonna start searching man.
and this is not a new thing just to some
http://forums.maxima.org/showthread.php?t=257931
Old Aug 26, 2005 | 07:59 AM
Playboycutie69
That still aint answer my questions about performance? How much hp does it actually give?
Old Aug 26, 2005 | 08:05 AM
Stephen Max's Avatar
I don't think anybody has done a before and after dyno where the TB is the only mod. People usually incorporate the TB as part of an entire intake revamp, such as installing a MEVI or 00VI, or installing 3" SC piping.
That being said, a larger TB isn't going to help much unless you are moving copious amounts of air through it. A normally aspirated Maxima isn't going to gain too much just from the TB, except maybe in the case of people running high rev limits.
Old Aug 27, 2005 | 09:05 AM
GodFather's Avatar
Made in Taiwan
agreed, and/or with jwt cams?
Old Aug 27, 2005 | 09:17 AM
nismology's Avatar
Man the people that actually need PF TB's (read: 4th gens with 3.5 swaps) can't find them anywhere cus 3.0 guys with bolt-ons ****** them up for no reason.
Old Aug 27, 2005 | 09:29 AM
GodFather's Avatar
Made in Taiwan
yeah, people like me just "snatched" them for no reasons.
acutally, i'm getting everything ready because i cannot stop my crave for more VQPOWER with our cars. i want to do all N/A mods available for our cars, and when that's done, i may think about SC-ing it. so PFTB isn't a bad idea, right?
Old Aug 27, 2005 | 09:34 AM
nismology's Avatar
Noticed how i said 3.0 "with bolt-ons". A PF TB is overkill for almost any N/A 3.0. If you plan on doing internal work, more power to you. But anything short of that and you've wasted your money. My statement was directed to 3.0's with I/Y/E etc.
Old Aug 29, 2005 | 04:59 PM
Weimar Ben's Avatar
Helicopters! Money!!!
the mallfinder TB might actually hurt your top end power on a 3.0 while giving you slightly more HP/TQ on the low end. You need high velocity air coming into the cylinders at high rpms because the valves are only open for a few milleseconds to fill up the cylinder.
Old Aug 29, 2005 | 08:58 PM
NmexMAX's Avatar
dot dot dot ...
Maybe not overkill w/ VI/ECU ... but still hasn't been proven ... and even if so .. I'd say less than 5hp.
Old Aug 29, 2005 | 10:35 PM
Weimar Ben's Avatar
The MallFinder needs more low end TQ at the expense of top end power because of its weight. This is why the frontier/xterra VQ40 has the same amount of HP as the 3.5. I would say that if you want slightly more low end TQ, but less top end, go for it.
When the Nissan engineers redesigned the VQ30DE and made the DE-K, they increased the size of the TB a little, but not as big as the pathfinder. I would say that with the VI and mods, the 00 TB is prolly the optimum size, that is, the best compromise.
Until someone dynos it, I think we're all just talking out of our a**ses.
Old Aug 29, 2005 | 10:54 PM
s0ber's Avatar
My DE-K TB is the same size as my old DE TB.. :\
Old Aug 30, 2005 | 07:30 AM
Weimar Ben's Avatar
Are you sure? I thought it was a few mm larger????
Old Aug 30, 2005 | 07:54 AM
s0ber's Avatar
Not mine, I checked, exact same thing.
Old Aug 30, 2005 | 08:35 AM
nismology's Avatar
How is this relavent to the discussion/topic? Furthermore, that grunt comes from cam profile and timing and intake manifold design more than the TB. All FWD 3.5's that i know of all have a 70mm throttle body as well. SR20 is make 260 WHP with the same 70mm throttle so that "more low-end/less top-end" theory goes out the window. How in the world can a larger TB produce more low-end on a car with a smaller displacement than it was designed for? It's common sense really. Larger diameter=lower intake velocity at lower RPM=less low-RPM torque. You'd be lucky to not LOSE any torque. This mod is for top-end power, if ANYTHING.
No. The DE-K TB's have the same inner diameter. Which just proves how useless a bigger one is on a 3.0 and that there are MANY other places to look for power FIRST. Unless you're swapping internals out like cams and such that DRAMATICALLY improve the volumetric efficiency of the motor at high RPM, something like a 00VI and/or ECU will be a much better investment.
The onus is not on the skeptics, it's on the people that say it makes an appreciable difference. Bigger is not always better. Some people have complained of a loss of throttle response with this mod, FYI. That's never good...
Which brings me back to my original post:
Old Aug 30, 2005 | 08:42 AM
Most people experience an increase in throttle response with a larger TB.
Old Aug 30, 2005 | 08:49 AM
nismology's Avatar
Are you speaking in general, or specifically to this discussion? If the latter, that's news to me. I've read at least a few complaints about this on this forum over the past 2 years.
Old Aug 30, 2005 | 09:01 AM
Are you speaking in general, or specifically to this discussion? If the latter, that's new's to me. I've read at least a few complaints about this on this forum over the past 2 years.
Both.
My experience is increased throttle response, and I have heard others say the same thing.
The increase in throttle response is due to more area being opened up for the same amount of throttle opening, compared to a smaller TB.
Old Aug 30, 2005 | 09:05 AM
Weimar Ben's Avatar
We were talking about the 3.0 and not the 3.5. I agree that the 70mm TB is probably the best size for the 3.5. The evidence of this is the near 100% volumetric efficiency on the 3.5. A smaller one on the 3.5 would prolly lose quite a lot of low end TQ, and gain little or nothing on the top end.
Engineering is all about compromises. Unless you have some kind of VI, then you can optimize your intake/exhaust and cam profile for low end TQ, mid range, or high end power. Honda figured out a long time ago that high end HP sells and doesn't give a rat's rear end about low end TQ.
GM, Ford, and Dodge primarily make trucks and Stupid Urban Vehicles that need the low end TQ just to get their heavy a**ses moving. That's why the most of their engines are pushrods or SOHC.
I think Nissan did a really good job on the DE-K and the 3.5 in designing an engine that has good low and midrange power, but also decent (but not great) top end power with a VI.
Old Aug 30, 2005 | 09:27 AM
96sleeper's Avatar
Both.
I had increased throttle response from the TB as well.
Old Aug 30, 2005 | 09:29 AM
nismology's Avatar
Both.
You're boosted, so the objective is to cram as much air as possible in there. N/A it's a little different. Were these others boosted as well? Don't quote me, but IIRC I30tMikeD complained about this when he did this mod when he was still n/a with the MEVI/ECU etc.
Makes sense in theory, but what about the reduced velocity of the air entering the intake manifold?
Old Aug 30, 2005 | 09:37 AM
nismology's Avatar
You may have experienced this, but there will be others that say the opposite. I've learned that the butt dyno is useless because some people said they felt the mid-range loss with the MEVI, other people said they didn't notice any change. We just need a solid back-to-back DYNO with and without to really compare.
Old Aug 30, 2005 | 10:46 AM
Air velocity is most important at the entrance into the combustion chamber. That is why opening up intake ports can have disastrous effects on torque. An upstream enlargement in flow area has very little effect on flow velocity into the heads, except for improved flow capacity at high rpm (as long as the larger TB is not drastically larger than the pipe feeding it or the throat of the intake manifold. Abrupt changes in flow area have a negative impact on resistance to flow, just as a tortuous path does.).
Butt dynos can be deceptive, but I immediately noticed an increase in throttle response. To me the difference was very pronounced, even annoying until I got used to it. Being boosted no doubt had an effect.
Did Mike say he did not sense any increased throttle response, or was he saying he did not sense any power increase? Also, did Mike port-match the throat of the IM?
Old Aug 30, 2005 | 11:08 AM
GodFather's Avatar
Made in Taiwan
no doubt, i sensed an increased in throttle response, too. i noticed right after i plugged in the pf tb, i started chirping 3rd gears. i even remembered taking the car down to a meet where all these integra boys didn't believe when i told them i chirped 3rd. then i took all of them one at a time to ride my car. when they get off, amazed and believed, they tell the next guys to hold on to their *****.
of course i know my car is N/A, not as fast as FI cars, but it was true that I chirped 3rd after the tb install. Bobby and Jon, both orgers down here in Baton Rouge were there that night, too. and they have experienced the 3rd gear chirps. I really don't remember their org names, though. That was months ago, hope they still remember and can chime in to verify this.
i want to point out, pf tb wouldn't give gains on a stock N/A setup, but on a N/A 3.0 modded all the way down, I think it does give good gains. word...
EDIT: "I think it does give good gains"=well, i have installed it, and i know for a fact that it does give good gains.
Old Aug 30, 2005 | 11:45 AM
nismology's Avatar
What's modded all the way down? 99% of the 3.0's on this site have just bolt-ons.
No you don't know for a fact. Chirping 3rd doesn't constitute good gains.DYNO DYNO DYNO
Why is it throughout the past 2 years or so no one has shown solid dyno proof that this mod improves HP/TQ?
BTW, the fastest(trap) and quickest(E.T.) n/a 3.0 A32 ran a 13.43 @ 102 WITHOUT a PF TB.
http://forums.maxima.org/showthread.php?t=299895
Old Aug 30, 2005 | 11:55 AM
98SEBlackMax's Avatar
Maxima.org Insomniac
I have an interesting discovery that I have been keeping secret...
Well when I switched from the stock manifold to a ported 2000 VI with a 70 mm Pathy TB my butt dyno felt like I had gained more TQ in the midrange.
This was proven to be misleading because the ported 2K VI LOST TQ however it has a smoother power band.
Here are some dyno comparisons-
Blue is stock manifold with stock air/fuel and timing.
Red is ported 2K VI with 70 mm Pathy TB with stock air/fuel and timing, vias shut off.
Green is ported 2K VI with 70 mm Pathy TB with stock air/fuel and +8 timing with SMT, vias shut off.
The blue run was done with stock cat in palce so my A/F ratio looks much leaner, 21 and 22 were done with a test pipe. Also the blue run was the first run of that dyno session (done in the winter as well) and the ones with the 2k VI were after a couple of runs, so the losses appear more extreme do to heat soak conditions. I had some issues with the SMT on my dyno runs with the VI so I made 5 runs earlier correcting the massive misfires I was getting. Then I did run 21 and 22. Also it was about 95 F in that dyno on that day. However all runs were done on the same dyno in 3rd gear and are SAE corrected.
Appears that I took a hit in volumetric efficiency from the ported VI and pathy TB but I gained it all back and then some with timing advance and A/F tuning. Volumetric efficency, timing advance, and detonation have a direct correlation with each other especially at WOT conditions.
This makes me believe why Kevlo's car detonated so badly on the dyno with my SMT timing and A/F maps. IIRC he has a 2K stock manifold with a stock 2K throttle body. He gained like 20~25 WTQ @ 4000 rpm but had to stop the run cause the engine was pinging so badly.
Old Aug 30, 2005 | 01:18 PM
vipervadim's Avatar
I like Maximas
hey joe i didn't know you had the pf tb. you must have nice response is with the smt, pf tb, and 00vi.
but why was the vias off? no top end power
Old Aug 30, 2005 | 01:33 PM
It's responsive alright...
but why was the vias off? no top end power.
Those dynos were posted cause they are the most similar to show that I had midrange losses with the pathy TB and porting the VI to accomidate the pathy TB. However after some tuning and using the rpm switch on the SMT...
Blue is what I started with and red is what the SMT and opening the vias did for my car.
Old Aug 30, 2005 | 01:46 PM
nismology's Avatar
Hmmmm...so you had mid-range losses that had to be made up for with tuning huh? Interesting. The proof is in the pudding folks. There are A33's with bolt-ons putting out similar numbers, if not higher, with stock TB's. Nice numbers BTW... Just playin devil's advocate, that's all...
And in case anyone missed my previous post...
http://forums.maxima.org/showthread.php?t=299895...Check the mod list...notice how the PF TB isn't there.
For years Dave B was preaching that the PF TB was useless on an n/a 3.0 and that bigger wasn't always better. Nobody really believed him, including myself. Now i know he was right all along because, to this day, there has been no CONCLUSIVE evidence that it's worth a damn.
Also, Nealoc187 is respected as one of the great pioneers of A32 n/a performance and he didn't find it necessary to include the PF TB as a useful mod. If he had thought it would help his car get down the 1/4 mile any quicker, i'm sure he'd have hopped on it. His 1/4 mile record still stands, stock TB and all. I admired his no-nonsense approach to n/a modding. No BS, no hype, just parts that perform. Don't even get me started on UDP's...
Old Aug 30, 2005 | 03:32 PM
s0ber's Avatar
What? MY UDP gave me 30whp on the dyno??? You saw it..
Old Aug 30, 2005 | 03:55 PM
96sleeper's Avatar
He had slicks on that run. Several have trapped higher than him, and dynoed more than him, including myself. Why don't you nutswing a little more. If I decide to buy slicks this fall, we shall see what happens to my et. Then will the pf tb be a good mod? I admit its not the be-all end-all mod, but for someone looking for every last ounce of cheap power available in the 3.0vq, every little bit helps. For most people, no, the pf tb is not a worthwhile mod.
Old Aug 30, 2005 | 04:26 PM
95maxrider's Avatar
Lightly modded
JK
Although I have nothing to back this up with, I feel that a VQ with 00VI/MEVI and JWT ECU will benefit from a PF TB, even if it is only a few HP. As pretty much a final NA mod, it may be more valuable for some people than others. Depends on your goal/budget.
For FI people, the gains should be more concrete. I hope/assume the same would be true for people running nitrous. If I ever get around to dynoing, I may try and swap in a PF TB if I can find one to use....
I'll just say that I plan on getting a PF TB when I get some funds together.....
EDIT- I think it's somewhat the same argument as for the UDP, only isn't applicable for FI guys.....a few HP is a few HP....add em all up and you got 10-15 HP from all these small mods...
Old Aug 30, 2005 | 04:42 PM
NmexMAX's Avatar
dot dot dot ...
ricer math
Old Aug 30, 2005 | 04:51 PM
nismology's Avatar
You have extensive a/f tuning done as well as an exhaust cut-out, both of which have been proven to make good power. This still says nothing about the PF TB. And as for these people that out-trapped him, i'm sure they had notable mods other than a PF TB. And what do you say to A33's that out-dyno you with stock TB's? Besides, dyno numbers are pretty inaccurate except when used on a "baseline then mod" basis. He dyno'd lower than most with the same mods yet consistently out-trapped them at the track. Trap speeds > *
Nice one, big guy. Grow up...
Refer to first portion of this post...
If you'd read my original reply to this thread, you'd have seen i had a problem with 3.0's with just bolt-ons.i.e. i/y/e/UDP that plucked up alot of the PF TB's when some people that actually needed them (A32's with 3.5 swaps) couldn't find them.
Old Aug 30, 2005 | 05:49 PM
Seximus Maximus's Avatar
They are not the holy grail of parts. They are not that hard to find.
Old Aug 30, 2005 | 05:55 PM
nismology's Avatar
At one point there wasn't even ONE to be found on car-part.com NATIONWIDE...
Old Aug 30, 2005 | 05:59 PM
96sleeper's Avatar
A safc is not extensive a/f tuning. I dynoed over 200whp before the cutout, or tuning, or headers for that matter. Dyno links to A33 (non 3.5) with more than 210hp at the wheels please? maybe 1, 2? I still have a higher trap than neal, even hitting the rev-limiter before I cross the line, and I weigh 100lbs more than him, what does that mean?
Old Aug 30, 2005 | 08:02 PM
95BLKMAX's Avatar
I have to congratulate you on your car, nice 3.0 power being taken to the extreme.
That aside, I see what you're saying, that last post seemed as if you're exposing the pathy TB as the only reason why you're trapping higher than Neal. The bottom line remains that no one has tested the pathy TB before and after by itself to see how much/if it makes more power.
I personally think it would create power, but barely worth the hassle (2-4 horses TOPS). I would definatly expect an increased throttle response. But then again, since there is no before and after dyno, its all assumptions and educated guessing.
Old Aug 30, 2005 | 09:01 PM
krismax's Avatar
Father of the 00 VI
I have the fastest street tire 3.0 4th gen and i had a pathy TB
Old Aug 31, 2005 | 06:59 AM
95BLKMAX's Avatar
, but using street tire 1/4mile results to compare TB u'd still have driver skill and weather conditions as variables.
Could one of the guys that have done the pathy TB install go to the dyno one time? 2 runs with stock TB then 2 runs with pathy TB. That'd be the only way to really see how much power/if any it makes over stock. I would do it myself if I had the pathy TB.
