Sponsored by:
Sponsored by: CARiD
Finally got a chance to to Timing Advance to my max
Old Sep 19, 2005 | 02:49 PM
vsamoylov
Well I finally got the chance to do the timing advance on my max to 17d before tdc and the best part of it it was free. The only thing I did notice or maybe it was my mind but my car did seem to pull harder in 1st and second gear but it might be just me. The only part that I am dissapointed with was when I hooked the consult, it gave me 3 codes so now I have to get them fixed.
Old Sep 19, 2005 | 02:57 PM
MaxObesset's Avatar
how did you advance the timin ?
Old Sep 19, 2005 | 03:15 PM
liqidvenom's Avatar
brotherhood of tq
did adjust it using the consult program? i did the same but i really couldnt tell any difference in doing so.
how did u check to see if it got advanced? im clueless when it comes to timing and i tryied to log it but i was seeing everything from high 40~s to a negative number
Old Sep 19, 2005 | 03:37 PM
NmexMAX's Avatar
dot dot dot ...
I thought your car was 'retired'?
Old Sep 19, 2005 | 04:12 PM
turbo
Should be seeing 15-25 depending on RPM etc.. My BRAND NEW KS is screwed and reading low teens.
Old Sep 19, 2005 | 04:47 PM
JClaw's Avatar
Change your knock sensor harness, should solve the problem. I had that happen to me too. Changed KS, nothing. Then changed the KS harness and it pulls like it's supposed to now. There really is a big difference.
Old Sep 19, 2005 | 04:55 PM
vsamoylov
i work at nissan so i have access to a consult 2. i hooked it up and my stock timing was 14 degrees. i changed it to 17 degrees and updated the ecu. my next step is getting all these codes fixed.
Old Sep 19, 2005 | 05:13 PM
turbo
Yeah I was thinking that POS harness may be the culprit!
Old Sep 23, 2005 | 01:03 PM
XeroX's Avatar
Hella internets
I know you can check the actually KS with a multi meter, but can you do this with the harness itself? if so what are the specs?
Old Sep 23, 2005 | 03:32 PM
turbo
Checking the KS by resistance means sweet F@ck all. Pulling codes and logging timing data tells you for sure.
THE KS harness can be verified by checking for continuity unless your wire is loose sometimes; I believe that to be my case.
Old Sep 23, 2005 | 03:37 PM
VQuick's Avatar
Chassis Freak
How much is the KS harness and what's the part number? I changed my knock sensor and noticed no difference myself, although I didn't actually know that the old KS was bad, so who knows. The old KS was five years old and I just felt that the car was slow. Thanks.
Old Sep 24, 2005 | 08:03 AM
turbo
You need to pull the codes and log the timing like I mentioned to know for sure. KS harness - call your Nissan dealer they are like $15 or so ballpark
Old Sep 24, 2005 | 03:04 PM
meccanoble's Avatar
Sports Button FTW
are u using stock 5th gen computer or 4th gen? if 4th gen, i thought the timing automatically goes back to normal once the car is cut off? something like that? btw liqidvenom, i didnt know u had the ability to increase timing! we must seach other very soon
Old Sep 24, 2005 | 06:29 PM
DandyMax's Avatar
3.5 in the works
The Consult cannot permanently advance timing on a 4th gen. I've verified this on a couple of occasions.
Old Sep 24, 2005 | 06:57 PM
vsamoylov
i have the 5.5 gen ecu.
Old Sep 25, 2005 | 01:04 PM
Weimar Ben's Avatar
Helicopters! Money!!!
Anyone try the KS resistor trick with a 3.5 swap?
dank4us
34
Jun 10, 2024 03:45 AM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
MaxInfamy
Forced Induction
Aug 24, 2015 12:01 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
maxinout93
Aug 16, 2015 07:25 PM
