Could JWT Compensate?
Okay here's the problem:
Error codes: EVAP and Intake air temp circuit malfunction (Mech says it's reading at -50 degrees, could this cause an idle problem?).
I'm not really sure how to get rid of these two freakin codes!
AND: For some reason my car has had a rough idle since my MEVI install. I've had it checked for leaks and a mechanic at the dealer says that the BPT valve is responsible for a small ticking noise but is not a critical problem. He was not able to diagnose the rough idle.
I don't know why it idles the way it does but my car is a lot quicker than what it was without the MEVI (about 4.5-5 cars difference faster). Low rpm's has a notable loss in power but I've heard that this is normal so i haven't worried about that loss.
Do you guys think that I should still go ahead and get the JWT ecu or go spend hundreds at the dealer to get this problem fixed first?
Buy a new air intake temp sensor $50 and it will fix that. you can put that on with a screw driver. and with the evap there s diff evap codes you must give more info
Alright, I'll check on the EVAP codes and get back to you guys.
About the intake air temp sensor..... I've already got a new one. On the 97 it just plugs in, it's a small plastic piece and it clips in perfectly. I still have the intake air temperature CIRCUIT malfunction reading.
I know that getting a new ECU won't fix these problems NmexMAX, I'm just asking if their ECU would still run on my car/if they had to make any changes that would include these sensors.
Of course it will run, why wouldn't it ... It will run the same but with slightly advanced timing and a leaner a/f ratio under WOT all the way to 7k rpm, unless you wanted a higher fuel cut.
Doesn't JWT program conservatively and keep the a/f around stoich/rich?
Slightly advanced timing is what you get with the JWT ..
Check this forum, there are many different people who have logged their timing ... eng92 is the timing guru .. he's got many timing plots w/ JWT & TS.
Okay. One question though.... why would it have slightly advanced timing a a leaner a/f ratio(definitely don't want that!)? Doesn't JWT program conservatively and keep the a/f around stoich/rich?
Also the JWT program changes open-loop settings. This is at >40% and ~3000+ RPM. Everything else is like stock.
litch
123
Jan 4, 2024 07:01 PM
t6378tp
Sep 29, 2018 04:27 PM
Mahmuth
Sep 25, 2015 10:08 AM
