Sponsored by:
Sponsored by: CARiD
Pic of my new engine (slapped a little paint on)
Old Nov 19, 2005 | 01:44 PM
Jime's Avatar
Ok this is Altima engine I bought to put into my 95 GXE. Cleaned it up a bit and sprayed a bit of paint on.
Cams are going in just as soon as I get them back from Rob (Tilleys99) Hope I don't take too much of his time telling me how to get the cam timing correct.
Old Nov 19, 2005 | 01:55 PM
Nismo3112's Avatar
Custom User Title
Sweet!! At first I was thinking "why is he replacing his engine with another VQ30"
Old Nov 19, 2005 | 02:01 PM
Jime's Avatar
Sheit you caught me. Oh well it will fool the uninitiated, I think?
Old Nov 19, 2005 | 02:05 PM
Jason R's Avatar
aka UNCDooD
haha, nice.
Old Nov 19, 2005 | 02:13 PM
MDeezy's Avatar
It got me too, I was thinking why does the altima engine look like the vq30 Then I saw Nismo3112's post and realized that was his sig.
How much did the engine run you if you dont mind me asking?
Old Nov 19, 2005 | 03:35 PM
Jime's Avatar
Engine was $1k, has approx 6k on it. Virtually brand new, just painting so its easier to keep clean than bare aluminum.
Old Nov 19, 2005 | 03:56 PM
naplesmaxima aka Tommyali the scammer!'s Avatar
I scam therefore I am
sounds like a waste of time
Old Nov 19, 2005 | 04:42 PM
Jime's Avatar
The valve covers are 3.5 its just the plastic 3000 sign from my old 3.0L, don't want to advertise the 3.5 just keep it low key. The plastic cover for the 3.5 was broken when I got the engine and they just hold heat in anyway so I was just about to throw the old 3.0L sign away when I thought I would see if it would fit. Its going to take some additional holes because the originals don't line up with anything on the 3.5 valve covers and some plastic dremeling but it should be good for a laugh.
Old Nov 19, 2005 | 04:43 PM
Jime's Avatar
Whats a waste of time, the painting of the engine or putting the 3.5L in?
Old Nov 19, 2005 | 05:13 PM
JeEvE's Avatar
Dont bother with what he says, he always has something bad to say about everything.
Old Nov 19, 2005 | 06:39 PM
the painting of the motor
Old Nov 19, 2005 | 06:47 PM
NmexMAX's Avatar
dot dot dot ...
That's sweet Jime .... Really like that low key look ... Had me fooled but the LIM gives it away ... What IM are you going to use?
Old Nov 19, 2005 | 07:09 PM
DandyMax's Avatar
3.5 in the works
um... I don't see a pic..?
Old Nov 19, 2005 | 07:13 PM
NmexMAX's Avatar
dot dot dot ...
Check his sig... ... Turn on Sigs ... and pictures on options menu.
Old Nov 19, 2005 | 07:15 PM
Nismo3112's Avatar
Custom User Title
^ his sig pic.
Jim, what headers are those ?
Old Nov 19, 2005 | 07:18 PM
NmexMAX's Avatar
dot dot dot ...
They look like HS ...
Old Nov 19, 2005 | 08:46 PM
Jime's Avatar
Planning on using the Kinetix SSV and they are HS's got them 2 years ago and they have served me well. That plus the new Dulobz cams should perk it up a little.
Old Nov 19, 2005 | 09:29 PM
DandyMax's Avatar
3.5 in the works
I had sigs turned on... my internet options somehow changed.. couldn't see offsite pics.
It's all good now.
Looks nice Jim.
Old Nov 19, 2005 | 10:01 PM
chilled's Avatar
Im my opinion getting subs that heavy/loud is a waste of time and good money also.
Old Nov 19, 2005 | 10:48 PM
Fr33way™'s Avatar
Wild for Width
I think it looks really good.
Old Nov 20, 2005 | 05:52 AM
s0ber's Avatar
quoted for truth.....
anyways, the engine looks hawt jime
I thought it was a VQ30 until I saw the oil cap :-\
Old Nov 20, 2005 | 06:05 AM
chilled's Avatar
The engine is looking really good Jim. Should be a powerhouse in that light of a car.
Old Nov 20, 2005 | 10:46 AM
95BLKMAX's Avatar
I must approve as well, looks awesome
Old Nov 20, 2005 | 01:59 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
You painted the injectors?
Old Nov 20, 2005 | 02:28 PM
Jime's Avatar
Alex everything got painted, the hardest was the timing chain, trying to get into all the little places you can't really see. It was easier to paint the injectors than cover them up so I just covered the connector.
I did the transmission today that was worse, took me 2 days to clean it, was really nasty. Now I want to try and keep it clean. My Son tells me its much easier to keep the painted surface clean than bare aluminum.
Old Nov 20, 2005 | 02:44 PM
IceY2K1's Avatar
Looks good Jime...can't wait to see the 1/4-mile results.
Old Nov 20, 2005 | 03:32 PM
gtr_rider's Avatar
192.168.1.1
I said a couple times before actually noticing.
Old Nov 20, 2005 | 10:44 PM
vipervadim's Avatar
I like Maximas
what cams are you referring to?
ebay $699 jwt copies?
oh yeah a big tip: make sure to use high temp clear coat, that way wiping the dirt off is a snap, and no residue on the paint with a nice glossy appearance, also great for brake calipers, Duplicolor Makes good high temp clearcoat.
that vq should be putting down some nice times either n/a or N2O'd
keep on tuning
Old Nov 20, 2005 | 11:02 PM
Jime's Avatar
Ya they are testing them on the Altima forum now, one has dynoed and the other is this week. Looks like around 15-20 HP. Rob has mine now for drilling and says they look really good. Now is the time to install them while I have the engine out and opened up.
Exactly what I'm using.
Old Nov 21, 2005 | 04:26 AM
JClaw's Avatar
So you bought the cams Jim?
Old Nov 21, 2005 | 05:52 AM
Jime's Avatar
Ya and its all your fault. None of this would have happened if you would stop advising people about what to do.
Old Nov 21, 2005 | 07:36 AM
IceY2K1's Avatar
Haha...
Old Nov 21, 2005 | 08:02 AM
JClaw's Avatar
Now I just may have to buy those to beat you at CSCS next year. And you and krismax have brainwashed me with weight reduction.
Old Nov 21, 2005 | 08:50 AM
nismology's Avatar
Just so you know those cams advance the cam timing by 2 degrees when installed on a 3.5 with VTC's. You should mention that to tilley so he doesn't set the cam timing to stock 3.0 zero advance.
Old Nov 23, 2005 | 09:44 AM
Jime's Avatar
Here is a picture of my Son and I doing the first part of the swap. This was just before his bike accident.
Old Nov 23, 2005 | 10:36 AM
Fred Allen Burge's Avatar
I bet it's nice to share a hobby w/ your son. He'll benefit from it forever, you too!
allen
Old Nov 27, 2005 | 07:17 PM
vsamoylov
haha cover holds in heat. good one.
Old Nov 29, 2005 | 07:10 AM
JClaw's Avatar
Shudup.
Old Dec 8, 2005 | 01:50 PM
jaemax's Avatar
JIME you are my IDOL!!!! I want to be at that age rippin a car apart and spankin it up... good stuff man..
Soon to get a VQ35.. so how things go..
Old Dec 8, 2005 | 04:06 PM
HotshotVQ35's Avatar
my kid will be a nissan guy for life after i corrupt him!
allen
