Sponsored by:
Sponsored by: CARiD
New VQ35DE 4th Gen: Dyno Included
Old Feb 10, 2006 | 08:14 AM
  #41
tavarish's Avatar
fwd gone rwd cr00
yeah, i'm planning on putting in the phanton grip lsd when i do my swap, should help with launching a bit better.
those #'s are awesome, especially on the nitrous. That car should be in the 11's.
Old Feb 10, 2006 | 08:17 AM
  #42
s0ber's Avatar
Dont do it, IronLung has a PG LSD on his BRAND NEW TRANNY that he got from nissan, he opened up teh tranny after about 3K miles on the tranny and found the side gears in the differential all chewed up because of the LSD plate.
Old Feb 10, 2006 | 08:30 AM
  #43
JClaw's Avatar
Originally Posted by Stephen Max
That was with a VLSD tranny, too, which has higher losses than the open diff tranny. Didn't Mardi lose about 20 hp going from open diff to VLSD?
VLSD doesn't have more loss than open diff. Mardi lost a little power because he went from Open Diff to Quaiffe Helical limited slip, not VLSD. Helical differentials induce more loss. VLSD is fluid-driven.
I also have VLSD and I don't have any reason to believe it is robbing any power.
Old Feb 10, 2006 | 11:25 AM
  #44
liqidvenom's Avatar
brotherhood of tq
these kinds of threads really make me want to go for the 4.5 gen setup
Old Feb 10, 2006 | 11:31 AM
  #45
Stephen Max's Avatar
I don't recall any thread about it. I remember him thinking about the fact that his quaife might be sucking some power being as it is heavier than the stock diff, but I find it hard to believe it would even be noticeable, it's only a few pounds and the moment of inertia for such a small radius (like 2") is very small. I didn't know mardi ever had VLSD even, I thought he went straight from stock to quaife.
Also, there are lots of guys out there with VLSD that don't show any abnormal dyno numbers. I30tMikeD for instance, both when he was NA and now that he's turbo.
That's right, Mardi did go to a Quaife. I stand corrected.
I do seem to remember some talk about a fairly substantial power loss, though. But I could be imagining things. I just had another birthday, and I'm getting to the age where mental faculties aren't what they used to be. Back in the day I could remember really well. We used to wear suspenders, too. There was an old guy who put his suspenders on backwards, what a joke. My favorite joke is about the two aggies and the old hound dog. My dog is allergic to flea bites. I have to give him medicine for it. Dog medicine is so much cheaper than people medicine... What the hell were we talking about?
Old Feb 10, 2006 | 12:26 PM
  #46
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Shud up and drop that VQ35 in already~!
Old Feb 10, 2006 | 04:13 PM
  #47
Nealoc187's Avatar
SLOW
Phantom Grip is a no-no, as Iron Lung apparently found out. Spider gears go bye-bye.
Old Feb 10, 2006 | 05:00 PM
  #48
eng92's Avatar
IIRC he was running some ridiculously thick "shockproof" gear oil and experienced a significant power loss.
Old Feb 10, 2006 | 08:12 PM
  #49
stephenlc's Avatar
does your check engine light always go on during WOT?
Old Feb 10, 2006 | 09:27 PM
  #50
tavarish's Avatar
fwd gone rwd cr00
Is Iron Lung the only one with a phantom grip LSD?
I'm really considering putting this in my spare tranny, but i'd need a second opinion.
Old Feb 11, 2006 | 05:47 AM
  #51
nismology's Avatar
Originally Posted by meximax
...CEL: Nominally no codes, enabled by JWT ECU during dry solenoid actuation...
Old Feb 11, 2006 | 10:27 AM
  #52
stephenlc's Avatar
Originally Posted by nismology
gracias
Old Feb 11, 2006 | 02:14 PM
  #53
MardiGrasMax's Avatar
my thought is that the RL Shock Proof and Quaife ATB pull more power than an open diff or factory VLSD with MT90. Just a guess, either way I still need to run both.
Old Feb 11, 2006 | 04:58 PM
  #54
95BLKMAX's Avatar
Freakin awesome #s MexiMax, congrats. Now lets see some track #!!!!!!!!! :-D
Old Feb 11, 2006 | 07:33 PM
  #55
MDeezy's Avatar
Amazing number, and great to see another 4.5 gen. A lot of good info in this thread.
God damnit JWT..... They're basically trying to get me to blow up my engine....******* idiots
again
Old Feb 11, 2006 | 09:03 PM
  #56
NismoMaxman2's Avatar
The only 4.5 gen in da 956
<----has phantom grip lsd, no issue whatssoever, before when running nitrous, had broken axles, running 100shot, now, no issues whatsoever. 2 tire burn outs are way better than one.
Old Feb 11, 2006 | 11:26 PM
  #57
krismax's Avatar
Father of the 00 VI
I have talked to Quaife directly about there unit and they told me you DO lose 5+ wheel torque.
Old Feb 13, 2006 | 10:58 AM
  #58
meximax's Avatar
SC Overspinning Swapper!!
I have/had a Gold Level Phantom Grip (PG) LSD on my cryo-treated tranny using 100% shockproof oil. It worked flawlessly (smoke from both tires), until I broke the driver’s side shaft (right on the spline) inside the differential. I have yet to open the tranny. When I do open it, I will inspect what 15,000 miles of spirited driving did to the cryo-treated spider gears.
I noticed no discernable loss in power between the open diff and the Phantom Grip LSD. I now have a VLSD installed with the newly added 3.5VQ. So, I can't equally compare parasitic losses between VLSD, PG LSD, and open diff.
Performance: PG LSD vs. VLSD
In short, the PG LSD was a beast. It felt like a true locker. The inner radius tire would slip/pop/hop on really tight u-turns, similar to doing a u-turns on pavement with a 4X4. Tire hoping was evident about 30% of the time with filled urethane mounts, and about 15% with a solid rear mount.
The AE VLSD is a much more composed unit. No locking and wheel hop is about 99% gone using filled mounts.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
JonBlz
Oct 5, 2015 06:02 PM
