Sponsored by:
Sponsored by: CARiD
Realistic to run mid 13's ?
Old Apr 24, 2006 | 08:47 PM
MaximA StyLeZ's Avatar
I have my goals of reaching around a 13.4, 13.5 in my max. I plan on doing:
-Greddy EMU, 00VI, good tune, 5th gen clutch setup, Y-pipe Back.
I jus want to know if my goal is realistic. Obviously, traction will be an issue, but slick or drags will be used.
Old Apr 24, 2006 | 08:53 PM
matty's Avatar
Everyone will say "DO A 3.5 SWAP MANNN!!!" because everyone on this board thinks it the best thing since toasted bread. Shouldnt even had made that part of your post
-matt
Old Apr 24, 2006 | 09:04 PM
lol.. your right quick edit
Old Apr 24, 2006 | 09:56 PM
maximariceboi's Avatar
what year is your car? thats what im trying to do lol. 00vi on sat. i have the 5th gen cluch on wit most bolt ons. greddy emu will have to wait since its pricey. well goodluck man. btw what part north nj u from?
Old Apr 24, 2006 | 10:09 PM
nismology's Avatar
-matt
What's better for the money?
I do kinda understand your point though. Sometimes people will completely ignore the question that has been asked when the poster is often-times not even considering the 3.5 as an option. It gets out of hand...
Old Apr 24, 2006 | 10:13 PM
a do it yourself 3.5 swap =]. it only gets complicated when having a 99 cali spec =/. couple friends and i will be attempting a 35 swap hopefully during the summer.
Old Apr 24, 2006 | 10:49 PM
Nealoc187's Avatar
SLOW
It can be done so it's "possible" but it's not exactly easy. You've got to be at the track in the best of weather condititions, your car has to put down very healthy power, etc. You are in NJ so you have some of the best tracks in the country at your disposal so you are lucky there. Whether or not your driving skill is up to the task will likely be the determining factor.
Old Apr 25, 2006 | 05:55 PM
NiZMo1o1's Avatar
You A32 guys get all the fun..
im stuck in a rock and hard place..
Old Apr 25, 2006 | 06:21 PM
Kevlo911's Avatar
Kevlo for President
Ceasar is almost there w/o a VI. Krismax was almost there.
Do some weight reduction, light wieght wheels, ect... and you will make it.
Old Apr 25, 2006 | 08:33 PM
Im a 96' SE, im from around the wayne area. Well, i ran a 14.7 my first out at the track at englishtown, with a 2.37 60'. Obviosuly my 60' sucks, but wasnt bad for my first time, especially since my key value crap was slipping and my trans was acting up. If i reduced that 60ft. by .2, i think i was looking at a 14.4. The thing is my trap was low.(92.7) My mods were basic: Short Ram/Y-pipe/Cat-back. Some say my car is a freak, but i really dont think so.
So if 14.4 was possible w/o engine management (rev limit extend, tune) and 00vi, and a good clutch/trans. I def. feel i can pull of mid 13's.. any thoughts ?
Old Apr 26, 2006 | 07:55 AM
95BLKMAX's Avatar
I doubt you'd pull a mid 13 without DRs on some light wheels and weight savings. A better question is, could you get into the 13s?, period. If you do go through with the VI, tuning and a better clutch, you should be able to hit 13s with good skills. Assuming some weight savings is involved.
Old Apr 26, 2006 | 10:53 AM
Nealoc187's Avatar
SLOW
Get to the track with a working clutch and we will have a better idea of what you and your car are capable of. A slipping clutch could be hurting you just a little bit or it could be totally destroying your time. You're definately going to need to be on a tire to see mid 13s, that is pretty much a given, unless you completely shatter the current street tire 3.0 record which you shouldn't count on.
Old Apr 26, 2006 | 12:57 PM
yah, i will prob. be on hoosier dr's. The only way is to find out, so i guess its time to start saving up. Any1 local knows how to do the 00vi swap?
Old Apr 26, 2006 | 01:25 PM
tavarish's Avatar
fwd gone rwd cr00
I do.
10beans.
Old Apr 28, 2006 | 05:40 PM
Aaron92SE's Avatar
NWP Engineering.com
... unless you completely shatter the current street tire 3.0 record which you shouldn't count on.
What is that current record?
Old Apr 28, 2006 | 08:42 PM
Nealoc187's Avatar
SLOW
13.79 by 96sleeper
captchaos
Mar 15, 2016 12:18 PM
junito1
Sep 23, 2015 12:14 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
