where does this coolant sensor go on the 3.5?
What do you guys do about the coolant temp sensor. On my de-k there was a bung that the sensor screws into and on the 3.5 i can't seem to locate it. Is there one or did you guys just drill and tap a fitting?
Originally Posted by Nismo3112
You have to reuse your 3.0 coolant log.. The one which connects to both heads on the side.
fugging ****. Was that in any of the other threads becuase if so i missed that one! Is that the only reason for using that coolant log or is there something else that requires you to use the 3.0 one.
Don't remember seeing that at all in all the threads I've read on the 3.5 swap. Looks like I need to start all over
Originally Posted by nismology
you =
Originally Posted by diymaximakid
you dont have to use it.what you do is mount the sensor by the coolant hardline(is this what its called)?and it will read accuratly within a few degree.if you want i'll take a pic
yea if you don't mind that would be awesome. Doing that sounds much easier than switching out the coolant tube.
It's not that difficult to swap out the coolant log...
I don't get how swapping out the coolant tube seems like a big mission considering that installing the 3.0 timing covers and chains/sprockets is 10 x's more labor-intensive.
well as much time that this has taken i just get aggravated when i have to go back and re-do things i have already done.
allen
zzznightmarezz
Sep 21, 2015 06:32 PM
