Sponsored by:
Sponsored by: CARiD
Do we have an injection off feature???
Old May 15, 2006 | 11:28 AM
Brushedpewter's Avatar
Do maximas have an injection off feature on decelaration or any other time???
This is pertaining to Automatics.
Old May 15, 2006 | 12:39 PM
nismology's Avatar
During deceleration/coasting the injectors don't fire any fuel.
Old May 15, 2006 | 12:46 PM
so this is true for both manual and auto???
also what generations of maximas does this applies to, the injection off feature.
Old May 15, 2006 | 01:00 PM
nismology's Avatar
Yes this applies to autos. If i'm not mistaken this has been a feature of EFI since it's been around.
Old May 15, 2006 | 01:35 PM
does the injector feature applies to certain speeds, certain conditions, certain elevation???
Old May 15, 2006 | 01:39 PM
nismology's Avatar
1. It's not an "injector feature". It's a function of the ECM.
2. When coasting with the throttle completely closed the injectors don't fire until a little over idle RPM. They then begin firing to maintain idle speed.
Old May 15, 2006 | 02:52 PM
can you tell me the precise rpm they start firing again?
Old May 15, 2006 | 05:52 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
The injectors still fire...just at a low pulsewidth.
A quick look at an old log shows ~2ms duration/~10% duty cycle with TPS = 0%.
Old May 15, 2006 | 06:58 PM
kcryan's Avatar
Good u guys had me scared there for a seccond cause no gas is usually not a good idea
Old May 15, 2006 | 07:14 PM
nismology's Avatar
What's wrong with no gas? Anyway i got my info from the FSM which distinctly said there was a fuel cut while coasting. Guess it's wrong...
I also noticed that coasting, whether the ignition was on or off, produced the same EXACT exhaust tone. I had a pretty loud exhaust so i could hear it clearly. This leads me to believe there is no combustion occuring while coasting.
Another thing to consider is that while coasting the ignition timing is at TDC itself. Zero advance...
Old May 15, 2006 | 07:32 PM
my manual said the same thing. that fuel is cut off on deceleration and high engine rpm.
jc53
Oct 12, 2015 05:12 AM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
MannyMonroe
Sep 24, 2015 08:45 AM
guitarman
Sep 19, 2015 11:52 AM
