Sponsored by:
Sponsored by: CARiD
MY 3.5 and 5 speed swap 55% done "I THINK"
Old Jun 14, 2006 | 10:20 AM
urmab's Avatar
Well I really haven’t post a lot about this but I just finished putting the 3.5 engine back together and I’m about pull the 3.0 from the car I have pictures going to post them up soon. But in general anything i should worry about while I’m taking the engine out of the car? But if anything ill keep you guys posted on progress
Old Jun 14, 2006 | 05:09 PM
Nismo3112's Avatar
Custom User Title
I would label the vacuum hoses.
Old Jun 14, 2006 | 05:54 PM
MaxBlack97's Avatar
Good luck w/ the rest of the swap. What parts did u get for the swap? Keep us posted.
Old Jun 14, 2006 | 07:05 PM
DAVE Sz's Avatar
Hooooooonda.....
sounds more like 45% done to me.
Old Jun 14, 2006 | 08:39 PM
urmab's Avatar
thanks and as far as the parts that im using is basicaly
3.5 Maxima 34,xxx miles engine with drilled 3.5 cams and spacers
3.0 Oil pan, timing covers, 3.0 intake gears and whole timing assambly
98 LSD Infinity tranny
and the rest of 5 speed swap parts
97 Manual ECU
Ebay FPR
Basicaly I think pretty much I think the same thing as everyone else doing simmilar swap.
Imgoing to use 3.5 injectors and fuel like and i need to modify the fuel line and I have a question about the return fuel damper I basicaly use the 3.0 damper on pressent fuel line right ?
urmab's Avatar
pressed submit twice
Old Jun 14, 2006 | 08:42 PM
nismology's Avatar
You don't have to modify the fuel rail at all.
Old Jun 14, 2006 | 08:46 PM
urmab's Avatar
On the current fuel rail there is no return line for the fuel there is only 1 damper and on the 3.0 there are 2 dampers I dont need to modify that ? I can leave only 1 damper on the fuel rail
Old Jun 14, 2006 | 09:03 PM
nismology's Avatar
Have you read the 3.5 swap sticky?
Old Jun 14, 2006 | 09:32 PM
mforrest100's Avatar
Check the stickey's. You don't modify but you convert it into a returnless system by adding an adjustable FPR and a tee. Check the sticky's and you will see what I am talking about.
Old Jun 14, 2006 | 09:39 PM
urmab's Avatar
O i just read it again o ok i see what you guys are talking about thats even better thanks alot
Old Jun 17, 2006 | 06:52 AM
MaxBlack97's Avatar
How much did u pay for the motor? Where did you get it ? Wha exactly or the misc. parts that u got? Did u get the ecu programmed w/ ur specific 3.5 setup by jwt or technosqaure? I am curious becuz I plan on doing this swap this summer so gotta keep well infromed. I live not to far from me so maybe u can some see it after its done. Good luck
Old Jun 17, 2006 | 07:47 AM
tavarish's Avatar
fwd gone rwd cr00
you can get the motor for about 700 bucks shipped. You have to get some various hoses, coulplers, tilley's cam adapters, and possibly stephenmax's iacv adapter. Your stock ECU will work just fine, but you may want to tune it with something like the Greddy Emanage Ultimate. I'm in elizabeth, and I just finished my swap.
Old Jun 17, 2006 | 10:42 AM
I know someone selling one in Queens right now. The story is I told some kid about the swap and he went and bought the motor and put it in. Nothing else. So after I told him he messed up because of all the other steps he missed he is going to get a VQ30 and put it in. I think he wants $600. He bought the motor from Saw Mill out in Yonkers and it has a 6 month warranty. I think only a month and a half of the warranty is up. Has 39K on it. If you are interested. Let me know.
Old Jun 17, 2006 | 11:45 PM
urmab's Avatar
hey what do u mean he messed up because if all of the other steps he missed, is the motor good ?
As for other question I bought the motor in Brooklyn from a junk yard for $650 shipped, I have 6 month warranty on it its 3.5 out of a 2003 maxima 34k miles. I think I’ve gotten a pretty good deal and as far as the ecu and everything else goes, stock ecu , I have emanage blue probably going to use that. I hope it will do the job although I’m not sure but it might. I got my cams drilled and spacers from tilley. Suggestion get your self a 2nd 3.0 if you need your car running while you’re prepping your engine. I’ve gotten an engine which was pretty much apart but it had all of the parts that you need for the swap. and MaxBlack97 sure you can see it when its done i hope in a week or 2 it should be up and running
Old Jun 17, 2006 | 11:57 PM
[QUOTE=urmab]hey what do u mean he messed up because if all of the other steps he missed, is the motor good ?
What I mean is that I told him the motor can physically fit in the car but I told him there was a lot of other things that needed to be done. So this fool goes out and buys the motor and puts it in the car without swapping the timing equipment. Once I told him he had to remove the timing equipment and have the cams drilled he wants to get rid of it now and get the 3.0. Like I said great condition motor with warranty. If anyone is interested let me know.
Mike
Old Jun 18, 2006 | 12:16 AM
urmab's Avatar
in that case I might find someone who might be intersted I will let you know how that goes
Old Jun 18, 2006 | 09:17 AM
MaxBlack97's Avatar
If I can get that motor leak and crack tested then I will b very intersted in it.
Old Jun 18, 2006 | 12:08 PM
urmab's Avatar
hey for $600 and a leak test done id say jump for it
Old Jul 7, 2006 | 06:41 PM
urmab's Avatar
Alright progress I guess its about 90 % completed all i need to do is to feguar out what to do with some wires I have a thread open with that question then It should start
Old Aug 3, 2006 | 03:25 PM
a ojeda's Avatar
who drilled the holes in the cams for you if you could help me out cause i'm having trouble with my engine swap please e-mail i need help
Old Aug 3, 2006 | 06:32 PM
Drilling is a thing of the past. Contact Stephen max for the adapters. I'll give you this since this is your first post. Donate and search.
zzznightmarezz
Sep 21, 2015 06:32 PM
Socalstillen
Sep 20, 2015 11:46 PM
Bonka
Sep 14, 2015 11:18 PM
MaxRPM6
Sep 11, 2015 06:56 PM
I<3 A32's
Sep 10, 2015 11:07 AM
