00vi gasket
Jul 24, 2006 | 07:40 AM
I'm trying to peice up everything I need in order to start my 00vi swap and I have one question. Do I only have to use the 00 IM gasket for my 00vi swap? And do I need any other gasket?
Thanks for the help
Jul 24, 2006 | 08:48 AM
you need one gasket part #14033-2Y901, and you need 2 IM gaskets part #14035-38U01
thats what you need for gaskets for the manifolds... you will also need gaskets for the egr system as well but they are cheap, couple bucks, if you didnt get all of that already when you bought the egr guide tube... hope that helps
Jul 24, 2006 | 09:41 AM
Quote: you need one gasket part #14033-2Y901, and you need 2 IM gaskets part #14035-38U01
I plan on re-using a good many of my gaskets, but you're saying 3 different gaskets are needed for the two intake manifolds? Like one lower -> heads and two upper -> lower? What would I need assuming I was using my 4th gen lower and the 00VI upper?
Jul 24, 2006 | 10:07 AM
Quote: What would I need assuming I was using my 4th gen lower and the 00VI upper?
good luck, and customization skills
hope you got a metric tap at least, lol
Jul 24, 2006 | 10:23 AM
Quote: you will also need gaskets for the egr system as well but they are cheap, couple bucks, if you didnt get all of that already when you bought the egr guide tube... hope that helps
thanks!!
you don't have the egr gaskets part number by any chance?
Jul 24, 2006 | 10:32 AM
You likely don't need to replace the 2 gaskets b/w the lower manifold and the heads. They are metal and usually still in good shape (unless for some reason yours aren't).
Jul 24, 2006 | 10:35 AM
Quote: You likely don't need to replace the 2 gaskets b/w the lower manifold and the heads. They are metal and usually still in good shape (unless for some reason yours aren't).
this is true... the part numbers i gave were assuming you were using the 00vi w/ the 5th gen lower
Jul 24, 2006 | 10:38 AM
u need 4 things total w/ the new egr set up... the egr guide tube, another metal tube and 2 gaskets:
part #s: 14713-2Y900, 14722-38U02, 14722-2Y000, 14719-W7001
the guide tube is around $25 and the other 3 peices are about $2-3 each
Jul 24, 2006 | 10:56 AM
Quote: this is true... the part numbers i gave were assuming you were using the 00vi w/ the 5th gen lower
Same scenario.
Jul 24, 2006 | 11:05 AM
Some time back there was a guy on the org (overseas somewhere IIRC) doing the 00VI swap, and he was trying to use both the 4th gen & 5th gen gaskets between the UIM & LIM. Absolutely a NO NO! Whichever LIM you use, use just the 5th gen (00VI) gasket.
Jul 24, 2006 | 11:07 AM
Why would you use both?
Jul 24, 2006 | 11:18 AM
Quote: Whichever LIM you use, use just the 5th gen (00VI) gasket.
So I just need to pick up a 5th gen upper -> lower gasket and I SHOULD be ok? I hope so...I'd hate for this to get even more complicated
Jul 24, 2006 | 12:20 PM
maximaSE327, you're a god among men!
thanks!!
Jul 24, 2006 | 02:22 PM
haha not a problem... i had all the same questions not too long ago... i just did the swap last weekend... im glad i could help
