Sponsored by:
Sponsored by: CARiD
3.5 swap: please check out these 3 sensor readings and let me know what you think!
Old Aug 6, 2006 | 05:57 PM
csb's Avatar
csb
Problem: fuel, but no spark.
Used this link for 1993-98 Maxima: http://www.autozone.com/servlet/UiBr...3d801f4f97.jsp
Troubleshooting procedures taken: checked (with digital multimeter) both crankshaft position sensors ("pos" for volt reading and "ref" for ohm reading) and the camshaft position sensor for "ohms".
The results:
crankshaft (pos): 12.1 volts (according to above link, it should be 5!)...tried numerous combinations, paid most attention to the #2 (white) and #3 (red) wires per the link site. They say to touch a screwdriver to the sensor "core", which I'm assuming is the magnetic portion that reads the flywheel.
crankshaft (ref): within link specs
camshaft position sensor: within link specs
Also checked: all grounds (3 total...alt, engine wiring harness and main battery ground): 12.39 volts at each.
So...do you think my crankshaft position sensor (POS) is bad???
Would this explain the no-spark condition and should I just go buy a new sensor from Nissan?
Thanks guys.
Old Aug 6, 2006 | 06:03 PM
nismology's Avatar
A bad CPS (POS) will cause erratic spark, but there will still be spark.
Old Aug 6, 2006 | 07:38 PM
csb's Avatar
csb
Alright...so assuming it's a fact that there will be erratic spark (while I have none whatsoever), what should I check next? The '97 FSM recommends replacing the CPS (POS) if the reading isn't 5V (as I mentioned, it is at 12.1V on my car). As I mentioned above, I've already checked the grounds, CPS (REF) and the camshaft position sensor.
Old Aug 6, 2006 | 08:17 PM
MDeezy's Avatar
have you tested the coils?
Old Aug 6, 2006 | 08:21 PM
Nismo3112's Avatar
Custom User Title
Doubt that the coils would all fail at once.
Did you check the ground wires for each coil plug?
Old Aug 6, 2006 | 08:27 PM
csb's Avatar
csb
No...I haven't checked any coil plug ground wires. If one is bad, will all 6 coils not function or ? Thanks for the suggestion...at this point, I'm considering all possibilities.
MDeezy's Avatar
if one is bad just that one will be bad.
Old Aug 6, 2006 | 08:55 PM
Nismo3112's Avatar
Custom User Title
Keep us updated.
Some things from teh FSM:
1. When the key is in the "on" position, the #3 terminal on each coil harness plug should read .01 - .1V, (these are the different colored wires, not the red or black wires going to the coil)
2. The red wire on each plug should read battery voltage when key is at "on" position. (If there isn't battery voltage here, check the condenser plug.)
3. Black wire on each should be ground..
Make sure the condenser plug is plugged in...
maxinout93
Oct 27, 2015 01:29 PM
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
Blackwind
Aug 5, 2015 06:35 PM
