vafcII vs. neo on 06 Max
check this
http://forums.maxima.org/showthread....ght=vafcII+neo
not everyone can search. cut the noob some slack
edit: not everyone knows how to use all the fancy buttons on the forum
My installer pretty much abandoned the idea of installing the V-AFC II on my 2004 Maxima. They stated it wouldn't work because it's only compatible with hot wire vehicles and not MAF sensor vehicles like mine. Can anyone point me to a write up on how to set it up?
1. Maxima MAF's have a hot wire element.
2. The V-AFC II was made primarily for honda's with VTEC and they use absolute manifold pressure sensors, not hot-wire type MAF's to determine the airflow.
Originally Posted by nismology
Slap him for 2 reasons.
Again, is there a write up to get it to work or no?
http://forums.maxima.org/showthread.php?t=461576
Did you ever bother trying to use these links...
instead ...
Originally Posted by NmexMAX
The wiring is the same for any other A34...But the template on how to be smarter than the VAFC and take advantage of it can be found here...
I'd say getting slapped for believeing an 'installer' before reading the useful posts on here would be a
instead ...
instead ...
BTW,
I've seen this shop's work, you would believe what they say also if you did.
I'm thinking with the wiring diagram that Glude posted along with the extra info from these threads it should be enough.
This S-AFC II install must be kickin' their a$$!!! 2 full days with the car and they're still having problems. The latest they tell me is that the S-AFC is wired up correctly but the car is still running extremely rich and will not idle. When the SES light does come on it throws an error code that the engine it misfiring. They've already replaced 3 spark plugs.
Any insite on this?
Any insite on this?
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
