Sponsored by:
Sponsored by: CARiD
How to: Hook up 00VI ??
Old Aug 19, 2006 | 10:29 AM
matty's Avatar
How does it go ?? When I had my MEVI, I had an external Vaccum tank that I used that was wired to the seleniod and then to the manifold.
Without that, Im confused. Theres three lines going out of seleniod, and one main line coming of the manifold.
Can someone shine some light on this for me. kinda confused. I have the RPM switch wired up through my emange ultimate. I just need help on the vaccum line running for the seleniod.
-matt
Old Aug 20, 2006 | 02:15 AM
TomV's Avatar
if you have the rpm switch wired up and the manifold installed, you're done. the actuator for the vias gets its vacuum from inside the manifold, no external vacuum source required. the small port on the vias assembly can be left open, its simply venting the non-vacuum side of the diaphragm as far as i can tell.
Old Aug 21, 2006 | 06:35 AM
jmeister's Avatar
Sorta but not really. The vac tank is internal on the VI but you still have to run a vac line from the nipple on the VIAS to the mid pipe.
Old Aug 21, 2006 | 07:43 AM
matty's Avatar
Some run it to the mid-pipe and some just leave it open.
Anyone know that part number of the connecter for the built in seleniod on the 00VI ?? Someone said they sell the connector at Radio Shack ??
-matt
Old Aug 21, 2006 | 10:32 AM
DandyMax's Avatar
3.5 in the works
That is correct. Whether you want to run it to the intake tract to give it a source of filtered air or not is up to you.
t6378tp
Sep 29, 2018 04:27 PM
lrb6805
Sep 30, 2015 08:12 AM
Finkle
Sep 27, 2015 09:53 PM
maxima297
Sep 24, 2015 01:18 PM
Maximeltman
Aug 31, 2015 01:01 PM
