Sponsored by:
Sponsored by: CARiD
MEVI not activating..
Old Sep 18, 2006 | 11:24 AM
sean05's Avatar
grr.. I went to install my pionner ipod connection so I can jam out to my iPod in my car and i got it all hooked up and everything and tada it works! well the other day i was installing my LED for my alarm and my MEVI activation lights wiring got pulled apart. My fault for not soldering then to begin with. So i hooked them back up and nothing... Well i was in a rush so i just left them disconnected. Well just out of curiousity i was like i better make sure the MEVI still works becuase the wiring is a little messy. My fault again for my being organized. Well guess what.. not working. So i began to check my wiring for the summit switch and found the gray wire was disconnected. got out my wiring diagram and saw this one shouldnt be connected? Well i have the power running off the cigrette lighter power.
I cant figure it out. I know its not getting power because the leds in the summit switch dont light up. Could I have to much running off the cig lighter and blown a fuse? i guess i somewhat diagonsis'd my own problem here. If someone can point me in the right direction i would be be very thankful
thanks again
Sean
Old Sep 18, 2006 | 11:32 AM
NmexMAX's Avatar
dot dot dot ...
I used to run it off the battery...Straight through the firewall. Find another source taht uses ignition switch as a power source.
Old Sep 18, 2006 | 12:16 PM
sean05's Avatar
ya i need to do that. sucks not having time to fix my car with school and work. thanks. hopefully its an easy fix.
Old Sep 18, 2006 | 12:22 PM
RA030726's Avatar
I'm nutty for Nissans
get a multi meter to check the wires. dont bother trouble shooting any other way even though its only a few wires.
Old Sep 18, 2006 | 02:55 PM
sean05's Avatar
can you reccommend a good multi-meter?
Old Sep 18, 2006 | 04:00 PM
RA030726's Avatar
I have a Craftsman I like it overall, but the leads are rather cheap. Fluke is awsome but way too much money.
Either of these should do the trick for minmal amount of money:
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
http://www.sears.com/sr/javasr/produ...TOOL&ihtoken=1
But if you do lots of electrical stuff get something with more features and wider range.
Old Sep 18, 2006 | 05:06 PM
MaximaSE96's Avatar
Maxima Owner
i have a craftsman as well and its fine....find an auxilary fuse thats not in use....get teh plug in fuse with the power wire off of it..is called add a fuse or lead or something liek that
Old Sep 19, 2006 | 10:32 AM
sean05's Avatar
can you explain on this? i think i have the jist os what your saying but im not so sure.
Old Sep 19, 2006 | 12:27 PM
RA030726's Avatar
Old Sep 19, 2006 | 12:42 PM
MaximaSE96's Avatar
Maxima Owner
^^^^^^^^ That be the shiznit
litch
123
Jan 4, 2024 07:01 PM
maxprivate
Nov 29, 2017 08:52 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
BkGreen97
Apr 2, 2016 05:47 AM
lrb6805
Sep 30, 2015 08:12 AM
