Sponsored by:
Sponsored by: CARiD
3.5 swap in progress, need double check on timing chain install
Old Nov 5, 2006 | 11:54 PM
juani's Avatar
Rockin' VK56!!
well, I got all the timing components on the engine, and I wanna get it double checked by who have done the swap. I followed the instruction on the FSM and I'm pretty sure I did it right. but who knows, I could've made mistake, so here's the picture of my timing. Let me know if I did anything wrong.
Old Nov 6, 2006 | 05:08 AM
MDeezy's Avatar
looks spot on. Good job.
Cylinder 1 cams will be pointed like / \
Cylinder 4 cams will be pointed like \ /
just for extra reference.
Looks like your good to go, RTV it up.
Old Nov 6, 2006 | 06:22 AM
csb's Avatar
csb
And make sure to read the thread about "cam spacer problems" (if you're using the aluminum adaptors from StephenMax, anyways). Nothing against him...it's just that people have had problems with them breaking.
Old Nov 6, 2006 | 07:00 AM
juani's Avatar
Rockin' VK56!!
great!
Yea, I just read that thread. Hopefully it doesn't break on mine.
Old Nov 6, 2006 | 07:26 AM
csb's Avatar
csb
Didn't you drill out/enlarge the two holes (one on each side) on the inner case as per the FAQ? Is it just me, or are there no bolts installed there? Could be an opportunity for a leak...
Old Nov 6, 2006 | 07:47 AM
Biggs_02's Avatar
yeah there is not nut there...you didn't drill out the hole so you can put a nut in...i would do that to insure there won't be a break....
Old Nov 6, 2006 | 08:16 AM
csb's Avatar
csb
Thx for the 2nd opinion. It looks as though there are possibly two bolts missing on the rear bank side. I'd bet it'll leak if you don't remedy that.
Old Nov 7, 2006 | 06:35 AM
MDeezy's Avatar
listen to bigs and csb. Better to tackle this now while the engine is out of the car and much easier to work on, than your get the motor back in and you realize that it will be a problem. Do it right the first time.
Old Nov 7, 2006 | 12:37 PM
SpeedCrazie's Avatar
Could some circle the two missing bolts that are being reffered to?
Old Nov 7, 2006 | 04:13 PM
Nismo3112's Avatar
Custom User Title
2nd pic.... above the 2ndary chain tensioner.
Old Nov 7, 2006 | 08:34 PM
juani's Avatar
Rockin' VK56!!
I kinda didn't understand what it meant on the instruction when it says you have to drill/enlarge the hole on the inner timing cover, but now I get it. I guess I have to take off valve covers, outer timing cover, cam sprockets to enlarge the holes on it.
I also have question on tensioner. It seems like my tensioner isn't doing it's job, since my timing chain is kind of lose. It's lose to the point where I can push the tensioner with my hand. Should I swap in the 3.5 tensioner in, or is it supposed to be that lose?
I'm kinda not sure about using 3.5 tensioner if I have to use it, because I just read a thread about 3.5 tensioner on 3.0 timing chain and it was scrapped to the metal.
Old Nov 7, 2006 | 08:44 PM
Biggs_02's Avatar
tensioner won't be putting out that much pressure to make the chain tight until you start the car and build up oil pressure. 3.5 tensioner on the 3.0 chain is fine...the one you read is one isolated incident. i believe everyone else uses the 3.5 tensioner.
maxinout93
Oct 27, 2015 01:29 PM
schmellyfart
Sep 25, 2015 04:47 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Blackwind
Aug 5, 2015 06:35 PM
