Sponsored by:
Sponsored by: CARiD
bigger injectors?
Old Nov 13, 2006 | 03:51 PM
babymac's Avatar
BOOST 4 LIFE!
bigger injectors?
If I were to put a set of bigger injectors and a fpr would I get any hp gains? This is just a question so please no flaming. gotta learn somehow.
Old Nov 13, 2006 | 03:56 PM
matty's Avatar
Youll just run rich. You need something to control the injector PW like a SAFC or Emanage.
Your stock injectors are perfectly fine for N/A power. Once you boost, then you need to look into larger injectors with a higher FP
-matt
Old Nov 13, 2006 | 04:02 PM
babymac's Avatar
BOOST 4 LIFE!
-matt
thanks......
Old Nov 13, 2006 | 06:24 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=434821
Old Nov 13, 2006 | 06:44 PM
nismology's Avatar
-matt
There is a way to make more power by using larger injectors/upping fuel pressure and using a AFC while N/A.
NmexMAX shows the way.....
Old Nov 15, 2006 | 02:43 PM
MDeezy's Avatar
it could be a decent way to add more power.
that plus the MEVI and other mods that are on the way, at the end it could work out to a nice gain.
Old Nov 15, 2006 | 05:09 PM
goldtooth's Avatar
http://cgi.ebay.com/ebaymotors/Altim...spagenameZWDVW
is this FPR good?
Old Nov 15, 2006 | 05:14 PM
matty's Avatar
No. Spend the money and get a good AEM or Sard Unit
Old Nov 15, 2006 | 05:30 PM
goldtooth's Avatar
like this:
http://www.rx7store.net/product_p/sard%20fpr.htm
http://www.rx7store.net/product_p/aeromotive%20fpr.htm
does it matter that its from a RX7 store? do the fitting still match with the maxima? The cost is not an issue as long as the unit is GOOD.
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
