Sponsored by:
Sponsored by: CARiD
In the middle of VI swap, question on fuel rail
Old Dec 4, 2006 | 09:47 PM
Kenny302's Avatar
I"m in the middle of doing my VI swap, and I'm having a problem with the sx7r.com fuel rail off fitting leaking fuel. Is there suppose to be a gasket that goes in between the fuel rail and the fuel rail off fitting? Did anyone else have this problem?
Old Dec 5, 2006 | 02:54 AM
matty's Avatar
There is a little black O-Ring that goes on the fitting, then you lube that up and slide it into the fuel rail. Without that O-ring you will leak fuel fast !
-matt
Old Dec 5, 2006 | 08:09 AM
speed racer's Avatar
You need an O-RING
Old Dec 5, 2006 | 08:14 AM
Kenny302's Avatar
cool, the fitting didn't come with an O-ring. Would the little black O-ring on the bottom of a fuel injector work?
Thanks for the help guys
Old Dec 5, 2006 | 08:18 AM
matty's Avatar
Its probably a different size. Get one from nissan or a local auto parts place
-matt
Old Dec 5, 2006 | 09:16 AM
Bring the fitting to autozone and have them look for an o-ring to fit.
Old Dec 5, 2006 | 11:52 AM
Kenny302's Avatar
got it stopped leaking. Thanks
Now all I need to do is get the car to stay on, but I'll figure that out tomorrow
Old Feb 12, 2007 | 10:18 AM
ghostmax301's Avatar
Is sx7r's fittings the only fittings i can use or can i get them from a store? If so, where? Im stuck in the middle and dont know what to do with the 2 dampers on the fuel rail.... PLEASE shed some light to me on the fuel rail routing
Old Feb 12, 2007 | 10:21 AM
jmeister's Avatar
One is the damper (front) and the other is the fuel pressure regulator (rear). You can leave the damper, things work just fine with it on there.
Old Feb 12, 2007 | 11:55 AM
its 2 hoses on it, which 1 do i block off
Old Feb 12, 2007 | 12:12 PM
jmeister's Avatar
huh???????
Old Feb 12, 2007 | 12:20 PM
on the regulator and on the damper, its a nipple & hose coming out the side and a nipple and hoses coming out the head(top) of both, but on my fuel rail its only 1 hose on the damper. What do i do with the other one?
Old Feb 12, 2007 | 02:06 PM
jmeister's Avatar
Still not 100% sure what you're talking about but both of them need vacuum sources, the larger hose is the fuel and smaller is for vacuum. Fuel goes into the damper side & returns via FPR side.
Old Feb 12, 2007 | 02:39 PM
so the one on the front side is the damper... and 1 more question(lol) where do i hook those hoses for a vaccum?
Old Feb 12, 2007 | 05:19 PM
and what does that nipple on the valve cover go to..
Old Feb 12, 2007 | 05:47 PM
Mad-MAX_SE's Avatar
Still kickin'
edit: Answer is below this
Old Feb 12, 2007 | 06:28 PM
goldtooth's Avatar
it goes to the FRONT valve cover nipple
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 3, 2015 05:18 AM
maximusrising
Sep 2, 2015 09:55 AM
iflexsteel
Sep 2, 2015 08:04 AM
