Sponsored by:
Sponsored by: CARiD
. . . it was the Pathfinder TB
Old Dec 14, 2006 | 06:14 AM
MDeezy's Avatar
If any remember I was having an idle problem with my car. 3.5 went in smoothly and everything appeared connected properly and everything. When starting the car and idling, the car would idle at 2k then fluctuate. 2k ->2.5k -> 2k -> 2.5k and so forth. Getting suggestions to check for a vacuum leak, I searched and searched but wasn’t able to find one. Looking at my Pathfinder throttle body I realized the bottom portion of the TB where air will circulate to the IACV and out the two outlets, were not plugged up at all. I used some JB weld and filled the square opening in the TB, and used more JB weld for remaining openings that would let air escape. Re-assembled and started the car and finally she idle around 650. Finally I can resume this vehicle as my daily driver. . .
Cliff note: Before installing a Pathfinder throttle body, make a block off plate or fill the opening with JB weld.
Old Dec 14, 2006 | 06:55 AM
speed racer's Avatar
got pics??
Old Dec 14, 2006 | 06:57 AM
matty's Avatar
I used a two part epoxy to fill the iacv channels, but same thing.
-matt
Old Dec 14, 2006 | 07:00 AM
matty's Avatar
Here are the pics of the gallies that need to be filled..just tape them off and fill from the bottom with any two part epoxy.
Old Dec 14, 2006 | 07:10 AM
95BLKMAX's Avatar
blah! hahaha. before tearing my engine apart, I finally put on StephenMax's PF TB adapter, and I had the same exact thing, idles right at 2 grand.
The two outlet holes of the IACV, I poured silicone into them and put a bolt of the same size as the hole into them, and covered them with jb weld... yea not enough, the valve itself still allows for air flow. Before I put the engine back together I'll have my block off plate installed already.
Old Dec 14, 2006 | 07:48 AM
MDeezy's Avatar
yes indeed Matty. I taped them off and filled it. Once I started my car and saw how it idle, even after it warmed up I knew I solved the problem.
Old Dec 14, 2006 | 07:56 AM
MDeezy's Avatar
Its funny (only now its funny) that what appears to be such a small thing was whopping my as* for so long. It was at a point I drove my car to work (had to that day), and you wont believe the amount a looks you’ll get driving your family car with the b-pipe not connected to the muffler, and revving up and down from 2k to 2.5k . . .
by the pathy tb
Old Dec 14, 2006 | 03:03 PM
Cdg2125's Avatar
I'm making my plate tonight for my PF tb. I'm gonna seal it to the bottom of the tb but I'll have to fill those holes first. Good thing I checked this today. Just that hole in front of the butterfly?
Old Dec 14, 2006 | 03:15 PM
MDeezy's Avatar
Yes fill that hole. and look at the 2nd pic matty posted. look underneath that produding rectangle you'll see another air way for air to escape. Once you make your plate it will cover the whole bottom of the TB and thats it.
funny thing was I always read 00vi swaps with the pathy TB, or DEK swaps and have seen pics of people covering that plate up . . . it should have hit me sooner.
Old Dec 14, 2006 | 03:29 PM
Cdg2125's Avatar
Hey I noticed the tube coming out of matty's tb. What hose is that?
Old Dec 14, 2006 | 04:46 PM
jcy98maxse's Avatar
Turbo is too much fun!
That tube for the coolant. I mention that on matty's thread about the same issue with silconing/JB welding the bottom of both the PF TB and 5th gen TB. Both of them have similar holes for the IACV. I'm glad that it fixed your problem. It isnt necessary for a IACV plate if you did what MDeezy did. The plates has the same affect as the blocking those holes.
Old Dec 14, 2006 | 04:48 PM
Cdg2125's Avatar
Ok thanks. I might put a nipple on my block plate to run a coolant line. Everyone says there's no need but I'll see what I can come up with.
Old Dec 16, 2006 | 12:06 AM
krismax's Avatar
Father of the 00 VI
I have never filled these holes and idle has been perfect
Old Dec 16, 2006 | 09:41 AM
MDeezy's Avatar
are you using the IACV? or do you have those lines properly routed? In my case I did not have the lines routed anywhere so it would become a leak for me.
Old Dec 16, 2006 | 01:40 PM
krismax's Avatar
Father of the 00 VI
Oh maybe i misunderstood but i have a block off plate but holes werent filled.
and i had the IACV on but took it off and now my startup is rough but thats exspected with no IACV
halfpol
Oct 17, 2022 12:16 PM
t6378tp
Sep 29, 2018 04:27 PM
spencerwh1
Jun 30, 2016 05:44 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
