What's best way to remove "the shelf?"
I want to remove "the shelf" on my 3.5 IM and make an adapter plate for the TB. So I would be chucking the elbow. What's the best way to cut out the shelf?
Originally Posted by juani
I just did this today, and I just used hacksaw blade and dremel to cut the shelf. took me about three hours to remove IM, cut the shelf, clean, and reinstall
Originally Posted by 915Max
Dont mean to sound new but I seem to be lost... but very interested. What are you reffering to when you say "shelf"?
What does the shelf do? Is it more of a restriction than a function??
The "shelf" is a Plenum volume divider/restricter, and the VIAS opens a valve to allow for the volume to increase. Thus more top end. This is simpler and cheaper to use than a variable runner length IM. I am not positive which is necessarily better since both runner length and plenum volume are important aspects of an IM.
The only VQ manifold that has variable runners is the Pathfinder VQ35. All other variable VQ manifolds are based on Plenum volume. This includes all of the FWD VQ35s, the MEVI, and the 00VI/DEk manifold. The RWD VQ35s including the "rev up" and the HR and VQ30DET are all nonvariable.
The FWD VQ35 IM already have large, short runners and increasing the plenum volume by removing the "shelf" or "VIAS delete" it allows for more top end for very little time and almost no money. Some loss of low end is possible, so be warned. Although the VQ35 has quite a bit, and some tuning can also compensate and gain back much of it if not more.
Aside from losing low end power, are there any other downsides to it?? And about how much torque would you estimate losing?
I am currently doing the 3.5 swap and I came across this thread, which interests me a whole lot. I am willing to sacrifice low end power to gain top end, afterall, the VQ's are already torquee as hell!
What I'm really curious about is if it would still allow the VIAS to work properly.
I really dont know too much about the 3.5's intake manifold and/or variable intake manifolds but I really would want to learn more about it and get the best performance out of the engine.
Like you all at one point... I'm just trying to do my research.
Thanks again!!!
Aside from the larger displacement, I always thought the VIAS was a huge contribution towards the power the 3.5's produce.
This is amazing to me! The many options we have with this motor.
I think I read somewhere here that someone had done the swap but the car was running sluggish because of the VIAS was not connected. That would be because the butterfly valve was closed and it was interfering with air flow right??
Thanks again!!!
It's not clear whether removing the shelf will help or hurt your low end torque compared to an open VIAS. The difference between a working and a functional VIAS is about 30ftlbs of torque up until about 4000rpm.
Originally Posted by Weimar Ben
Who made the assertion that there would be no loss of low end torque?
Yea, I'm still using the elbow, but there's definitely more pull on high end. I'd say about 10-15 whp. and I feel almost no loss on low end.
thanx for the reference dyno NMexMAX. I love how the it holds HP at a plateu from the previous stock peak onto redline.
Question, its obvious that the shelf inside the IM is removed and everything is smoothed out. BUT what about the shelf in the elbow? Is that also cut out off as far as the sawshall can reach n smoothed with the dremel as well?
theres only couple inches in on the big end where its wide everywhere else on the elbow shelf is very close together.
So am I understanding this right??
those numbers seem a little low. Do you not have headers?
PM me if the run files are needed. Here's a more 'clear; graph.....
Originally Posted by SPiG
That is backwards, Reverse the top and low. It also looks more like a dual runner setup from what I can tell. Is that from an 02+ FSM? If you take one apart it becomes pretty obvious what we are talking about.
Its actually off of a 04 FSM.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
