Sponsored by:
Sponsored by: CARiD
Need some help finishing up a 3.0 4th gen overhall
Old Jan 16, 2007 | 04:00 PM
danman700's Avatar
Guys I am finishing up a complete over hall on a 3.0 and I cant get this thing started, I got it cranking, only things not hooked up are power steering and belts and a single ground wire that is on the drivers side front wheel well. I cant find or figure out where that went for the life of me, so I am getting no spark, defitnally a huge fuel smell so i dont forsee that being an issue. I've checked power to coils, thats good, I didnt have signal to the coils until i realized that my crank sensor on the tranny wasnt tightened, and while i was at it checked the other crank sensor n cam sensor, they are all good, so now I've got ground, signal, so i am in the process of figuring out the ground situiation, To be honost with you i dont remember what function on the multimeter you use to check contounity to ground but I did try a few different ways and all ways are pointing to no ground on that circuit. My stupid hanes manual wiring diagram is absolutly no help in this situiation as it doesnt have connector locations or anything of the sort. Anyone come across that ground wire that goes to the body, its maybe 10" long and has a small black connector on the end I need to find out where that goes and if its related to my problem. Any insight anyone might have would be greatly appreiacted, Thanks.
Old Jan 17, 2007 | 06:43 AM
MDeezy's Avatar
I would make sure all ground connections are made, I'm not sure which ground wire your refering to that isnt connected but I'm sure its needed. Ground it somewhere, it doesn't have to be where it was originally grounded.
if you have or can take pics that will help alot.
Old Jan 17, 2007 | 07:19 AM
csb's Avatar
csb
That may be the primary ground...very important. I believe it goes to a mounting plate, located on the block, just a few inches in front of the starter.
Old Jan 17, 2007 | 10:16 AM
danman700's Avatar
[IMG][/IMG]
ran home at lunch to take cell pic, its bad but it gives you an idea of the connector, it grounds to the body from there. I am defitnally going to check out that location on the block and see if i can locate it. thanks for the help
Old Jan 17, 2007 | 10:27 AM
tavarish's Avatar
fwd gone rwd cr00
the 2 grounds on the intake manifold. Check them. The car won't start without them.
Old Jan 17, 2007 | 10:47 AM
maxlinegtr's Avatar
thats funny ...when i did an engine swap that is the thing that stumped me. couldn't figure out why the starter would not crank...that connector to the starter....its always something small. look through all your connectors. miss one and you will be scratching your head a while ...get a volt meter too to check all wires if you have too. misc ground wires are important.
Old Jan 17, 2007 | 02:25 PM
KRRZ350's Avatar
it goes to a little tab on the transmission, it's back there a little ways attached to a case bolt
clean it, connect it, check the two by the intake manifold and the bigger one that goes from under battery tray to the mounting plate by the front head. if you're still having trouble go here even if thats not it just read through that thread and you'll def. gain some insight towards what it could be
Old Jan 17, 2007 | 05:25 PM
danman700's Avatar
hahahaha she started right up....and it was something so stupid i completely over looked the engine block ground, the one krrz350 mentioned.. i had it on there but not tight whatsoever. THANK YOU ALL!!!!
MAXSE5SPD
Sep 17, 2022 04:00 AM
RWCreative
Sep 21, 2015 11:01 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
