Sponsored by:
Sponsored by: CARiD
Which Year 3.5
Old Jan 19, 2007 | 08:25 PM
moogotzskillz2's Avatar
Which Year 3.5
I'm currently changing my clutch.(5th gen) and i thought that taking the tranny isnt a big deal but DAMN!!! So it hit me that I've always want'd to do a 3.5 swap, and lookin at my motor now.. its only being held by a floor jack and one Motor mount(center memeber, front/rear motor mount, tranny are All off) so.. I'm lookin for a 3.5 and i just wanan make sure WHICH year/s to get that has less problems if i remember corrcetly one year has the EGR/Iacv not having it?
And i really dont want it to have CEL on...*NC emissons*
or should i just try to get a Low mileage DE-K?
thanks
-moo
Old Jan 19, 2007 | 08:46 PM
95BLKMAX's Avatar
02-03 Max 3.5 had no EGR and No IACV, so yea that will set off your CEL, unless you get the resistor for the EGR and adpater plate from StephenMax for the IACV. 04+ Maxima 3.5s had EGR. Im not sure about the Altima 3.5s having/ not having EGR/ IACV so I wont mention them.
You sure you want to take on a 3.5 swap? I ask because you were complaining about a tranny removal, lol. If you think you can do it go for it, best way to learn is to get yourself dirty with it, lol
Old Jan 19, 2007 | 09:28 PM
MDeezy's Avatar
I will be codeless once I put my 95/96 cat back in and plug in my rear o2 sensor.
Trust me there is more to the swap than just pulling out your motor.
I believe the oil cooler is larger on the 04+ Max motors, not like that a substantial enough reason to go for that year. I'd go for 02-03 with the internal EGR, unless you want to figure out how to setup the egr on the 04+ 3.5's with the EGR that is present on your year car.
Besides the internal EGR, I believe the motors are pretty much the same.
Old Jan 22, 2007 | 07:08 AM
GodFather's Avatar
Made in Taiwan
You can always go for the 02 pathfinder heads on your 3.5 swap, which allows you to keep the 4th gen upper assembly, including EGR and IACV. This will yield no CEL's. But, it'll rob your pockets clean.
-Peter-
Old Jan 22, 2007 | 09:01 PM
goldtooth's Avatar
so what is the most recommended year engine for a 95 maxima? how about a 99, since its got the most emission bullsh!t ?
Old Jan 22, 2007 | 09:50 PM
vipervadim's Avatar
I like Maximas
2000-2001 vq30dek is a direct swap more or less
Old Jan 23, 2007 | 04:38 AM
goldtooth's Avatar
oops, i meant the 3.5
Old Jan 23, 2007 | 05:40 AM
SR20DEN's Avatar
VQ Wizard
Use the 2004+ Maxima VQ35 and don't bastardize it like everyone else does. Use the whole thing.
But you still need the 2001-2004 Pathfinder bank 1 CVTC and CVTC cover.
Old Jan 23, 2007 | 06:35 AM
scrhale's Avatar
SR20 ... why 04+ engine? The A34 engine is only slightly more powerful. Do the A34 6-speed ECUs use CAN system?
I know the A33B 6-speed uses no can system.
Old Jan 23, 2007 | 06:39 AM
NmexMAX's Avatar
dot dot dot ...
If one were to use the entire 04+ set-up, they could also use the Z33/V35 ECU.
Old Jan 23, 2007 | 07:14 AM
scrhale's Avatar
Yeah good luck with finding the ORG member to pony up the dough to pay for that.
I am feeling the full A33B swap. A little easier.
Old Jan 23, 2007 | 07:24 AM
nismology's Avatar
To me, there's no advantage to running a Z ECU unless it's the Revup along with the Revup timing cover and exhaust VTC's.
Old Jan 23, 2007 | 07:27 AM
NmexMAX's Avatar
dot dot dot ...
Not even for the said VTC map of even the non revup? With a ZIM?
Old Jan 23, 2007 | 09:42 AM
GodFather's Avatar
Made in Taiwan
I agree with Nismology, there's no point doing the Z ecu unless you get the whole Z deal to work. Heck, with all these trouble, it's the simlest to buy a 350Z and say goodbye to all the hurdles.
-Peter-
Old Jan 23, 2007 | 10:14 AM
nismology's Avatar
The Z VTC maps can always be flashed onto an A33B ECU.
Old Jan 23, 2007 | 10:16 AM
nismology's Avatar
-Peter-
I'm all for the A33B ECU in an A32, though.
Old Jan 23, 2007 | 10:23 AM
SR20DEN's Avatar
VQ Wizard
Because it already comes with the EGR connections.
Yes but that has nothing to do with swapping an engine. You would only deal with that if you were using the '04+ ECU. If you're going to use a new ECU, use the A33B one and the A33B engine because you won't need EGR anyway.
If you really want to get slick, wait for the '07 Altima engine.
http://forums.maxima.org/showthread.php?t=508067
I think it does have an item or two on the CAN BUS.
Old Jan 23, 2007 | 12:05 PM
915Max's Avatar
How do you go about making it work??
The connections are different-- I have an 04 engine that I'm in the process of swapping and I was looking at that. The 96 EGR has 3 wires attached to the connector (if I remember correctly) and th 04 has six.... Do you know how to make it work/read??
Old Jan 23, 2007 | 01:39 PM
NmexMAX's Avatar
dot dot dot ...
This has yet to be proven, do you know something I don't know?
I asked for it from TS, but they said it was not possible. I've posted their replies to me in a thread or 2. Even sent it back so they can 'try' it but still didn't happen.
Old Jan 23, 2007 | 01:41 PM
nismology's Avatar
If all else fails, V-manage.
Old Jan 23, 2007 | 04:36 PM
scrhale's Avatar
The 95-98 EGR is controlled via a vaccuum. The 04+ EGR is controlled electronically. You are going to have to adapt the entire 96 EGR system onto the engine somehow. Shouldn't be too hard. I think someone had problems connecting the pipe that goes to the rear exhaust manifold.
Old Jan 23, 2007 | 07:28 PM
NmexMAX's Avatar
dot dot dot ...
V-manage
Is it better than the Emanage?
Old Feb 2, 2007 | 11:51 AM
VQmaxi17's Avatar
moogotzskillz2,
Where in Charlotte are you? I'm about 20 minutes outside of Charlotte. I dont know ANYONE on the org near me... lol
...sorry about being off topic.
Old Feb 2, 2007 | 11:58 AM
SR20DEN's Avatar
VQ Wizard
Originally Posted by VQmaxi17
moogotzskillz2,
Umm.
We're all over the place.
Old Feb 2, 2007 | 05:53 PM
Umm.
fo sho
Old Feb 4, 2007 | 05:48 PM
VQmaxi17's Avatar
lol yeah ur right... i just need more maxima friends... my friends make fun of me cause i am obsessed with my car... u know... the usual "why dude its just a gramma car" stuff... I beg to differ...
Old Feb 4, 2007 | 08:22 PM
SR20DEN's Avatar
VQ Wizard
I would be happy to line my 'gramma car' up against most of your friends cars.
Old Feb 6, 2007 | 06:42 PM
VQmaxi17's Avatar
hahah... yeah, and the only friend of mine with a faster car has a new Pontiac GTO... even though I always blow their doors off they just dont shut up. lol...
Old Feb 6, 2007 | 06:49 PM
SR20DEN's Avatar
VQ Wizard
See if the goat owner and your other friends want to take a trip to Rockingham one day.
Old Feb 6, 2007 | 08:41 PM
Jason R's Avatar
aka UNCDooD
haha. they just don't know.
Old Feb 6, 2007 | 08:58 PM
Mad-MAX_SE's Avatar
Still kickin'
you guys lemme know when you're headed back out there! i haven't gone to rockingham in over 2 years, i wanna improve my times from last time.
Old Feb 7, 2007 | 06:36 PM
VQmaxi17's Avatar
hahah... they REALLY dont know what they are talking about. Actually, I'm planning on going to Rockingham some day on the first week of summer, it would be great to meet up with some of you guys there.
-ReLLiK-
Apr 29, 2016 06:25 PM
Maximan190
Dec 16, 2015 06:01 AM
MaxRPM6
Sep 11, 2015 06:56 PM
MaxLife17
Sep 8, 2015 02:36 PM
Maxboy23
Sep 4, 2015 06:04 PM
