Sponsored by:
Sponsored by: CARiD
VQ35HR Piston Pics
Old Feb 6, 2007 | 04:37 PM
SR20DEN's Avatar
VQ Wizard
VQ35HR Piston Pics
http://www.turbo6.net/vqtech/Images/VQ/VQ35HR/
I took these with my camera phone and they don't look that good. But here you go.
I can't get it to show up on the camera, but it has 'Hitachi' in it.
Old Feb 6, 2007 | 04:42 PM
jmeister's Avatar
What other piston is it being compared to in those pics?
Old Feb 6, 2007 | 04:46 PM
Hoooper
you can see where it says hitachi in pic 0206071919c, on the inner side of the skirt. at least it looks like it says hitachi.
SR20DEN's Avatar
VQ Wizard
That is a standard VQ35DE piston on the right.
Old Feb 6, 2007 | 04:50 PM
SR20DEN's Avatar
VQ Wizard
Oh yeah. Part# A2010-JK21B
Old Feb 6, 2007 | 04:54 PM
krismax's Avatar
Father of the 00 VI
some areas of the vq 30 ,vq 35 pistons to me actually look thicker.
and also i dont really see the height difference the HR piston is suppose to have over the 3.5 ?
Old Feb 6, 2007 | 04:55 PM
SR20DEN's Avatar
VQ Wizard
The location for the top compression ring and the oil control rings are the same but the location for the second compression ring is slightly lower. And the best I can tell for now, before I get my calipers to measure, the pin height appears to be the same.
Old Feb 6, 2007 | 04:56 PM
SR20DEN's Avatar
VQ Wizard
I need to put this thing on a scale. I am betting it is lighter because of the way they designed the skirt.
Old Feb 7, 2007 | 12:05 PM
hacim105's Avatar
Where did you get HR pistons from?
Old Feb 7, 2007 | 01:11 PM
SR20DEN's Avatar
VQ Wizard
I didn't .
Old Feb 7, 2007 | 01:17 PM
hacim105's Avatar
Originally Posted by SR20DEN
I didn't .
So how are you planning on measuring the pistons and components? Or are you refering to measuring the VQ35DE pistons?
Old Feb 7, 2007 | 02:18 PM
SR20DEN's Avatar
VQ Wizard
I'll just measure the one I have with my calipers.
Old Feb 8, 2007 | 09:14 AM
Luquire's Avatar
Im confused
Old Feb 8, 2007 | 12:39 PM
Hoooper
yeah me too, do you have an HR piston or not? if not, how are you going to measure it?
Old Feb 8, 2007 | 01:28 PM
SR20DEN's Avatar
VQ Wizard
Yeah I was just being a smarta$$. He asked me where I got the pistonS from. But I only ordered and bought one piston from Nissan.
Old Feb 8, 2007 | 03:36 PM
JClaw's Avatar
How much did a single piston run you?
Old Feb 8, 2007 | 06:36 PM
SR20DEN's Avatar
VQ Wizard
IIRC the OTC price was <$50. That means you can buy a set for <$300. Not bad for small upgrade to an older VQ35.
Old Feb 8, 2007 | 07:00 PM
glenmoormax's Avatar
10 psi
how you you rate this HR piston compared to a CP piston.
Old Feb 9, 2007 | 02:58 AM
JClaw's Avatar
Yeah those combined with 440$ eagle rods, ARP rod bolts and JWT valve springs would make a good 8000 RPM engine!
Old Feb 9, 2007 | 12:43 PM
krismax's Avatar
Father of the 00 VI
OK sounds great but ..........will these HR pistons go in a VQ35DE as is?
Old Feb 9, 2007 | 02:58 PM
10 psi
hmm, is it worth the upgrade to these vs the CP's, taking into account the cost, etc, i would say these are a great upgrade for the money... 300 vs 800.
Old Feb 9, 2007 | 04:19 PM
JClaw's Avatar
Well if youre opening your engine anyway it would be worth it. These combined with the eagle rods would be good for high reving NA or boost. Both ways IMO. Just cause we have the ''old'' VQ35 doesnt mean we have to dump it lol. Junkyard VQs are so ******* cheap anyway.
Old Feb 9, 2007 | 08:17 PM
jcy98maxse's Avatar
Turbo is too much fun!
Now the questions is, $300 is only for the pistons? or does it include the rings and wrist pins? I figure its just the pistons alone...
Old Feb 9, 2007 | 09:12 PM
Red Lion's Avatar
Anyone know what's the compression on them? still 10.3:1?
Old Feb 9, 2007 | 11:36 PM
jcy98maxse's Avatar
That brings up a good point! All this excitement about the stronger piston design, we forgot about the C/R factor. NA would not be a problem but the c/r is 10.6:1... def not good for boost. Hmm it would be an awesome alternative to getting a new set of pricey aftermarket pistons but that would only be good if this would can sustain FI.
Old Feb 10, 2007 | 01:06 AM
10 psi
True true, as this may be somewhat off topic justin, but i talked to cort, and he runs 40 lbs of boost with 12:1 comp pistons.... ??? I know what your thinking.... crazy *** cort.
With an awesome tune, i don't reckon that this piston would pop...
Old Feb 10, 2007 | 07:36 AM
nismology's Avatar
Are these pistons forged or hypereutectic cast? Do the HR combustion chambers have the same volume as the DE? Is the small end diameter the same between the HR and DE rods? Since the HR apparently has smaller valves, would milling the valve reliefs a bit be necessary? Is the compression height on the HR pistons the same? Does nissan offer them in an oversize (service)? Anxiously awaiting the answers from SR20.
Old Feb 10, 2007 | 09:52 AM
Red Lion's Avatar
what kind of tune would be necessary to run these efficiently besides higher octane? Timing advance?
Old Feb 10, 2007 | 10:04 AM
nismology's Avatar
The compression ratio wouldn't necessarily be 10.6:1. We don't know for sure yet if the HR combustion chamber volume is the same or if the HR pistons have the same compression height (distance from wrist pin bore centerline to crown deck). Even if the resulting compression ratio is in fact 10.6:1, .3 compression points isn't a big deal considering the pistons strength.
Old Feb 10, 2007 | 10:07 AM
nismology's Avatar
Old Feb 10, 2007 | 10:16 AM
jcy98maxse's Avatar
true but you really can't compare a built 4 banger (not really even a honda motor anymore, I think he runs a Dart block? or some insane race setup) but its more than just tune to handle that much boost.
Old Feb 10, 2007 | 10:18 AM
jcy98maxse's Avatar
Learning something new everyday. Especially something about internals of a engine and the process of building one.
Old Feb 10, 2007 | 10:35 AM
Red Lion's Avatar
I suppose I should have worded it: "Is there anything you'd need to do differently to run these in a regular VQ35DE so that the slightly higher compression doesn't cause problems?" assuming the compression height and combustion chamber volume are the same.
Old Feb 10, 2007 | 11:00 AM
eng92's Avatar
They are cast. Look at the inside detail.
Old Feb 12, 2007 | 11:35 AM
Tommy Boy's Avatar
Something to keep in mind. The reciprocating assembly comes from the factory at a certain balance weight. Replacing the DE pistons with the HR pistons (if they are of different weights) would require a rebalance of the whole reciprocating assembly. The assembly consists of the pistons, rings, pins, bearings, rods and bolts. This is reardless of whatever problems the CR creates or valve relief diameters in the pistons are.
Old Feb 12, 2007 | 12:00 PM
jcy98maxse's Avatar
Well if you plan on tearing the motor down to take such an endeavor as replacing the internals, balance and blueprint, micropolishing the crank, redecking the block are just some of the things one should do since they are in there already. The main concern right now is the fitment.
Old Feb 12, 2007 | 12:43 PM
nismology's Avatar
You almost sound like you're saying potential fitment issues or the resulting compression ratio isn't important... The balancing is secondary and besides the point. We need to determine what the physical differences between the DE and HR pistons are first.
Old Feb 12, 2007 | 07:30 PM
Broaner's Avatar
2060lbs and falling...
I'm very curious to know why one skirt is wider than the other? What is the theory behind this?
Old Feb 12, 2007 | 07:48 PM
nismology's Avatar
Less friction. The wider skirt portion is on the thrust side where it's needed and more narrow on the opposite side where the extra skirt area is unnecessary.
Old Feb 12, 2007 | 08:49 PM
jcy98maxse's Avatar
Copy and paste straight out of nissanperformancemag.com:
"The pistons have some interesting features, mainly an asymmetric shape with a larger skirt area on the thrust side for good support and a cut down skirt on the non-thrust side for less friction and less weight"
Basically what Nismology said.
linky here: http://www.nissanperformancemag.com/september06/vq35hr/
