Sponsored by:
Sponsored by: CARiD
00VI + EGR removal??
Old Mar 13, 2007 | 09:17 AM
VQ'ed's Avatar
Hello guys, I'm about to do the venerable 00VI swap on my 97GXE (fed spec). I Started the thread because after all the researches I've done on how to deleting/removing all the EGR system on the car, but to no avail...
Would you be able to guide me through with detailed steps for the removal.
Like blocking this, remove that, beware of that...
Thanks twice...
Old Mar 13, 2007 | 10:01 AM
nismology's Avatar
14017-4Y900- EGR block-off plate
14722-2Y000- Gasket for the plate
14052-21R00- EGR plug for the rear exhaust manifold
There. nismology-spec EGR delete.
Old Mar 13, 2007 | 12:19 PM
VQ'ed's Avatar
part number directly from the dealership?? If so, great thanks for the quick reply. Props to nismology!!!
Old Mar 15, 2007 | 05:00 AM
Ceasars Chariot's Avatar
Old Maxima Legend
i can get you some photos of the egr crap thats pulled out, and maybe some shots of all the hoses i have plugged, etc. im also a member of the egr delete club ! rofl
Old Mar 15, 2007 | 06:20 AM
streetzlegend's Avatar
Any benefits from deleting the EGR crap (besides ecu code which i dont care about)?
Old Mar 15, 2007 | 07:20 AM
VQ'ed's Avatar
Ceasar, would would save me a downtime to research as this is my only daily-driven car. pm me the solutions and i'm gonna translate the info in french on npclub to perpetuate the learning and learn myself to help others like you just did to me. GREAT HELP, buddy. Keep you car fast, you inspire me with you superb project. Thumbs up twice . I'm also in procedure to do the 00VI swap. I know you did it not long ago, would you help me through this, also...
Old Mar 15, 2007 | 07:22 AM
VQ'ed's Avatar
no more gunk crap in the intake tract and how tell you about it rises the combustion chamber temps, vent you hood to extract the heat and you've done something to help by directing cold air onto the intake...
Old Mar 15, 2007 | 08:18 AM
nismology's Avatar
You will have more NOx emissions. If your state/province doesn't have any emissions testing regulations this won't affect you.
Old Mar 15, 2007 | 08:57 AM
VQ'ed's Avatar
not yet in province of quebec...
Old Mar 17, 2007 | 09:28 AM
VQ'ed's Avatar
Man, i received 1 of the 3 parts you mentionned, the plug for the rear manifold. the other seems to be a ring gasket and a bracket... is this your infamous egr delete kit??? I was hoping for something else... the plug is ok but to REMOVE the EGR-bpt valve and EGR COMPLETE ASSEMBLY!! the bracket would be self-made with the 4th gen one and the ring gasket. There is suppose to have something to block the egr path to the block. If I remove the EGR valve. The hole left is suppose to be blocked by what??? Ceasar chariot is suppose to send me a follow-through of the whole procedure. A how-to of some sort.. I kept the plug but returned the 2 other parts!! What to do next?? help me with something more explained and not only parts numbers. please!!
Old Mar 17, 2007 | 09:44 AM
nismology's Avatar
Well it wasn't really a complete kit. In never said that's all it took to remove every EGR item. I kinda said it jokingly, i guess i didn't express that well enough. There's no possible way you could completely delete the EGR with just 3 parts. Those are just the parts that you will need to prevent a vacuum and exhaust leak. Did the 00VI you bought come with the block-off plate where the EGR guide tube would usually go?
Old Mar 17, 2007 | 09:51 AM
nismology's Avatar
Seems pretty straightforward to me...
Old Mar 17, 2007 | 10:37 AM
JClaw's Avatar
I was so glad when all that rusted crap was gone on mine. Dead weight.
Old Mar 19, 2007 | 09:36 AM
VQ'ed's Avatar
Today, i sent my 00VI and 4th gen lower to the machine shop. The guys over there are gonna fill the lower holes and retap completely newer ones to get the best seat surface. The egr guide tube came with the triangular plate with a hole in its center. they gonna plug this one with a cent bigger than a coin and weld it shut. Gonna take the egr delete plug for the rear manifold and gonna seal it with high temp threadlocker and screw it down the hole. Gonna remove the whole EGR assembly (I had a look this weekend on how it was made and hooked) and disconnect the sensors. CEL will come on, gonna take the scanner and troubleshoot the lights with the sensors i disconnected.
So i'm gonna know which light came on and know that the lights would be only EGR stuff and related to nothing else. Gonna post results after the install! thanks for the time you take for helping me out!!
Old Mar 27, 2007 | 02:59 PM
VQ'ed's Avatar
Hey buddy, what about the helping hand you told me about, it's been 2 weeks now!!! I'M about to do it on my own, if you still wanna help, post your pics... It will be appreciated. If not available, don't mind, you gonna have questions in your pm box. Thanks anyway.
Old Mar 27, 2007 | 03:56 PM
THT's Avatar
THT
Throbbing member
1. Cut
2. Weld
3. ??
4. Profit
Old Mar 29, 2007 | 02:52 PM
VQ'ed's Avatar
Originally Posted by THT
1. Cut
2. Weld
3. ??
4. Profit
what's the point??? you don't weld vacuum hoses!!! I know what to do with the EGR itself and how removing it, my question was directed at ceasar's chariot for the vacuum hose routing... thanks for the headscratch thought!!
Old Mar 29, 2007 | 06:21 PM
THT's Avatar
THT
Throbbing member
*sigh* I'll explain...
Cut the EGR pipe at the header and have it welded shut.
Old Mar 31, 2007 | 01:12 PM
97_Roadrunner's Avatar
He purchased a plug from the dealer to plug it up. The problem now for his swap is the iacv and 4th gen tb plate. the only things missing to complete.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
