Sponsored by:
Sponsored by: CARiD
Timing on 3.5 motor swap... valvs bent?
Old Mar 16, 2007 | 12:52 PM
Maximus_95's Avatar
What are the chances for the Valves to get bent when the timing is off?
I was getting help of a fellow member on my motor swap, and i dont remember if he set Cyl1 to TDC, but the timing chain and all was set to how its supposed to be.
We cranked the car, but it never turned on, so i figured the timing was wrong.
but now im thinking that there might be a chance that my valves are bent...
what are the chances?
Whats the best way to tell if they are or not?
Thanx....
Old Mar 18, 2007 | 11:22 AM
Maximus_95's Avatar
anyone? can anyone answer this for me?
Old Mar 18, 2007 | 12:11 PM
allanmaxt's Avatar
I don't think 3.5 bend valves because I had the same problem redid the timing like five times and now the car runs perfic
Old Mar 18, 2007 | 12:49 PM
gtr_rider's Avatar
192.168.1.1
Wow, you have been having some serious trouble with that swap huh.. GL man
Old Mar 18, 2007 | 12:53 PM
Maximus_95's Avatar
yeah....tell me about it....only if the timing was done right the first time, i wouldn't have to deal with this....
Old Mar 18, 2007 | 01:03 PM
GoalieKeg's Avatar
Fly me out and I'll fix it for you....
Old Mar 18, 2007 | 02:08 PM
Maximus_95's Avatar
haha, seriously....how much is a plane ticket? haha.
anyways....Dan, thanx for all the help, but im hoping that my valves are not bent. i talked to many people on the org, i keep getting mixed feedbacks. some say no, and some say yes...
this is killing me....i really want to work on my car and finish it up, but i got hit with the Gout! what the heck is that! i cant even walk!
Old Mar 18, 2007 | 02:23 PM
nismology's Avatar
Sorry i didn't get back to you earlier.
What exactly was off? The cam sprockets relative to the crank, crank sprocket relative to the cams, or the cams sprockets relative to each other? And how many teeth were they off?
The timing would have to be REALLY off for the pistons to hit the valves. Like 3 links or more...
Old Mar 18, 2007 | 03:00 PM
Maximus_95's Avatar
well the thing is, the guy that was helping me with the install, he did the swap on his car.... so what happened was, we set up the timing chain according to how its supposed to look like, but as far as i remember, i do not remember him setting Cyl1 at TDC.
i think he might have forgotten about that part....
Old Mar 18, 2007 | 03:34 PM
95BLKMAX's Avatar
You dont really need cyl1 to be at TDC. I've done my timing twice (swap, and then again after head gasket replacement) and as long as all the marks on the sprokets and colored links on the chain are line up like they are supposed to be, you wont have a problem with timing (assuming that the chain did not skip links during the initial crank, which is possible) Again good luck
Old Mar 18, 2007 | 03:53 PM
Maximus_95's Avatar
well im guessing that even though the links are matched up, if its not set at tdc, i would guess that the timing would be off, if you asked me.
how often can the link skip a tooth? is there anything we can do to prevent that?
Old Mar 18, 2007 | 04:02 PM
nismology's Avatar
Not necessarily. If the links line up, the #1 cylinder has to be pretty close but not directly at TDC.
The FSM recommends priming the tensioner with oil to prevent this very thing. Removing the plunger and dipping the whole tensioner in oil is how i'd do it.
Old Mar 18, 2007 | 04:08 PM
SR20DEN's Avatar
VQ Wizard
This is why you ALWAYS turn the engine over by hand, at least 720º, before you attempt to crank it.
Old Mar 18, 2007 | 04:11 PM
Maximus_95's Avatar
so even if the links were matched up with the links, but Cyl1 was not at tdc, can this cause the car not to start up?
Old Mar 18, 2007 | 04:15 PM
SR20DEN's Avatar
VQ Wizard
It's not likely to have all of the identified chain links matched up with the proper corresponding sprocket tooth and not be at or very close to #1 TDC.
Run a compression test.
Old Mar 18, 2007 | 07:26 PM
Maximus_95's Avatar
that does make sense....well....all i can do is a compression test i guess....
im hoping everything will turn out ok though...
Old Mar 18, 2007 | 07:47 PM
Snolife's Avatar
What we have here is a failure to communicate
Wow. Keep us posted, I gotta get your new number dude.
Old Mar 19, 2007 | 11:51 AM
JClaw's Avatar
So true. On my last swap I rotated the thing until the chain links had done 2 complete rotations. But priming the tensionner with oil is a good idea too.
Old Mar 19, 2007 | 01:10 PM
MDeezy's Avatar
If timing was off the cause can still start, you'll just run into other problems as a result of the timing being off.
There are more reasons why the car might not start besides timing. Have you check cam/crank sensors and tested with a multimeter and/or cleaned them?
Have you checked all grounds?
or better yet what exactly is the car doing?
Old Mar 19, 2007 | 09:00 PM
Maximus_95's Avatar
well before doing the timing, the car was cranking and all, but would not turn on.
i checked one of the sparkplugs and there was spark so im guessing they are working, i checked all grounds, they all seemed ok.
all it does is crank crank, but never turned on.
-i havent checked the crank sensor, so i will be testing that out if car still not turns on..
-timing was redone, i will be finishing this up hopefully this week so i hope this really works. since the timing was not done to TDC the first time, i would guess that was the problem.
Old Mar 20, 2007 | 07:01 AM
GodFather's Avatar
Made in Taiwan
Timing being off won't bend valves.
You've only checked 1 sparkplugs for fire. That's not good enough because when your timing is off, it can keep sparking, but at the wrong orders. You'd have to check them all individually. Even if is off by 1 degree, it can cause certain cylinders to not get fire. That's my experience with timing after 5 motors over cam jobs.
-Peter-
Old Mar 20, 2007 | 07:10 AM
nismology's Avatar
Our motors are interference. If the timing is off enough the pistons will hit the valves. But it would REALLY have to be off for that to occur.
And yea...i'd suggested taking out the spark plugs and checking for cyclic spark in his original thread. Having spark isn't good enough if it's erratic.
Old Mar 20, 2007 | 06:46 PM
Maximus_95's Avatar
do any of you guys know how its possible to test out an adjustable FPR?
im not sure if the one i got is working properly...
any methods?
Old Mar 20, 2007 | 07:40 PM
MDeezy's Avatar
how do you have it hooked up?
Old Mar 20, 2007 | 08:01 PM
Maximus_95's Avatar
ok, this is how i have the fpr hooked up....
Fuel Rail-----T-----Fuel Filter
.......Adjustable FPR-----Return Line
One question.....there are to tubings that are the same exact size, and i dont know exactly which one is the return line for sure and dont know what the other one is.
CorollaULEV
30
Aug 9, 2021 08:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 12, 2015 01:54 AM
