Sponsored by:
Sponsored by: CARiD
Finished the swap.... but one more problem...
Old Apr 15, 2007 | 10:29 AM
Maximus_95's Avatar
Ok guys, i got my car started, and got it running...
went for a test drive then then it happened..
seems like when i hit about 10mph, my car jerks really hard, then its ok, then it'll jerk again.
when i shift into second, it'll jerk again.... its pretty weird.
im thinking it may be my TPS and it might need to be recalibrated? what do you guys think?
i have the cable bracket mounted on the intake manifold, so im guessing its ok.
does the 2 metal pieces where the tps and the homemade metal notch supposed to be welded together?
Im almost done with this swap.... and im going crazy....
thanx for the help guys..
Peter
Old Apr 15, 2007 | 10:55 AM
95naSTA's Avatar
Is there any flex in the way you have it bolted up to the intake manifold?
Old Apr 15, 2007 | 07:31 PM
Maximus_95's Avatar
i dont think there is much flex....
can that be a problem? a huge problem to make the car jerk like that?
Old Apr 15, 2007 | 08:36 PM
tamer6187's Avatar
im a newbie
so im a newbie...and for one i cant figuire out how to post my own thread but anyways...
i see you have done the swap already...now i have a 95 maxima vq30de engine with about 180k miles on it...it runs good but id like it to run a lot smoother and/or replace it and just get a whole swap done
the transmission was replaced so my question is
should i rebuild the motor or just replace it??
what are the cost differences and performance differences
what is better?
Old Apr 15, 2007 | 09:33 PM
Maximus_95's Avatar
Stop whoring my thread.....jkjk.
3.5 is obviously a whole lot better and faster and if you replace with the 3.0 motor, it'll be cheaper but they will all be with high mileage so its up to you really.
i would say drive on your current engine right now until it poops out on you then swap it out. if you want it to run smoother, get a tune up, that's all you'll need.
anyways.... now can anyone give me any pointers about my car?
Old Apr 16, 2007 | 06:16 AM
95naSTA's Avatar
Too much flex would probably be almost as bad as mounting to the firewall. Any chance you could get a pic of your setup?
Those little notches don't need to be welded together for the TPS. The only reason it wouldn't work is if there wasn't enough tension in the TPS to keep up with the notch connected to the TB shaft.
Old Apr 16, 2007 | 02:36 PM
Cdg2125's Avatar
is the tps set right? Mine is off a little and it shifts hard to 2nd and 3rd. Check that.
To tamer, should be in the newb thread for questions like that. Obviously its a 3.5 so power is better. I would think that's obvious. Wait till your engine dies or go for the swap if you have money and know what you're doing. Remember this is not an easy swap and judging by the fact you didn't know 3.5 is a mahor power difference, I would start reading up on the swap before doing anything.
Old Apr 16, 2007 | 03:29 PM
GoalieKeg's Avatar
From the pic you sent me here peter, looks like the TB cable is crunched. Try to move the bracket so that the cable has more freedom of movement, and make sure there are no kinks.
Don't forget to try to adjust your TPS per the haynes manual.
Old Apr 16, 2007 | 03:32 PM
Maximus_95's Avatar
i think its the picture, but the cable is not touching anything...
i think i will have to adjust the tps....
if tps is not adjusted, can it cause the car to act like that?
Old Apr 16, 2007 | 03:37 PM
nismology's Avatar
Until everything is eliminated, anything is a possibility. Get things out of the way one by one. Checking the TPS/linkage mechanism is as good a place to start as any.
Old Apr 16, 2007 | 05:00 PM
Nismo3112's Avatar
Custom User Title
That piece of metal holding the TPS looks EXTREMELY thin..
Old Apr 16, 2007 | 05:44 PM
95BLKMAX's Avatar
i agree. Would you happen to have any of the apexi AFCs? you can monitor throttle % and V on one. If you're holding the gas steady, and throttle is fluctuating up by more than .5%, that TPS is moving.
I agree with Nismo, that bracket for the TPS is way to flimsy. get something beefier for it. I had the same sympthoms but went away when I put in the PF TB (to which the TPS screws on to like on the 3.0 TB). Ultimately a PF TB (if you can get ur hands on it) will solve any moving-TPS related problems.
Glad you got it running tho! Driving with a shaky TPS is a PITA, but once you fix that you'll fall in love with your car all over again, lol. Completly different beast
Old Apr 16, 2007 | 07:47 PM
juani's Avatar
Rockin' VK56!!
It could be your CPS(pos). does your CEL blink at you when it jerks??
I'm sorry peter, I had some serious family problem I had to take care of.
I'll call you tomorrow. Sorry
Old Apr 16, 2007 | 08:02 PM
Maximus_95's Avatar
wow john! whats up man.... i've been wondering what you were up to.... there were rumors that you might have gone to jail, or maybe you were in the hospital for something serious....
i was worried about you man, no calls and no posts... haha.
anyways....im glad you're back and hopefully everything that went on is all over by now...
call me tomorrow man, i'd like to talk to you... its been a while...
well guys, i know that looks pretty flimsy, i wanted to use that temporary but now i guess ill have to make a permanent one now haha.
you guys think it could be that? if the tps moves a little bit it can cause the car to jerk that much?
Peter
Old Apr 16, 2007 | 08:06 PM
Cdg2125's Avatar
Peter
yes it moves the ohms
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
Turbonut
46
Oct 21, 2015 08:28 PM
JoshG
Sep 5, 2015 10:10 PM
