Sponsored by:
Sponsored by: CARiD
00VI EGR Problems
Old Apr 20, 2007 | 12:27 PM
Tatanko's Avatar
Bacon Lover
00VI EGR Problems
I finally decided to put my 5th gen EGR tube on today...and now the upper manifold won't seal with the lower manifold. It's very, very close. I was told I need to bend the EGR tube towards the firewall a bit to make it sit right, but I absolutely cannot bend this thing, nor do I see how it is the cause for problems. If I can't get this problem fixed in the next hour, I'm putting my block-off plates back on...It's not worth this absolute nightmare of a problem.
Old Apr 20, 2007 | 02:17 PM
Tatanko's Avatar
Bacon Lover
Put my plates back on, car is fine...
Old Apr 20, 2007 | 02:49 PM
gtr_rider's Avatar
192.168.1.1
the EGR will not fit without bending it(dont know why but it wont). Just take your tire iron and shove it down the pipe and pull towards you.
unless youre a sissyman
Old Apr 20, 2007 | 03:07 PM
Tatanko's Avatar
Bacon Lover
Pull it TOWARDS me? I was told to bend it towards the firewall Either way, block-off plates are back on so maybe I'll put it back on next weekend.
For now, I'm hitting up the track tonight
Old Apr 20, 2007 | 04:18 PM
chillin014's Avatar
oh i see.
that sucks man...it went on fine when i had it on my car...strange. personally, i think the egr bull**** is 70 percent of the reason i opted for a 3.5 motor hahaha.
Old Apr 20, 2007 | 04:19 PM
gtr_rider's Avatar
192.168.1.1
interesting, mine was too far towards the firewall when I installed it so I had to bring it forward towars me.
Old Apr 20, 2007 | 06:20 PM
krismax's Avatar
Father of the 00 VI
when i did my 00vi swap EGR stuff bolted on perfect i used 00 max guide tubes both.
Old Apr 20, 2007 | 10:36 PM
goldtooth's Avatar
same here, no fitment problems either
Old Apr 21, 2007 | 07:22 AM
Tatanko's Avatar
Bacon Lover
Mine was ALMOST perfect. Just enough so that there was maybe a 0.5mm gap between the upper and lower, and only on the back, the front touched fine.
Oh well, maybe next weekend. Car ran pretty well at the drag strip last night once I remembered to change my RPM switch settings back to their correct digits (try a 0.6 difference in the 1/4 mile )
Old Apr 21, 2007 | 07:47 AM
speed racer's Avatar
What you have to do is keep the bolts on the 5th gen egr loose enough that you can move it. Put the UIM on and than carfully hit the egr until its lined up plumb. Once lined up plumb than tighten the lower bolts.
Old Apr 21, 2007 | 10:29 AM
Tatanko's Avatar
Bacon Lover
I tried that...I left it VERY loose. Still wouldn't line up
Old Apr 24, 2007 | 04:44 AM
Curt's Avatar
EGR Guide Tube Alignment
Ditto: Same Here
Old Apr 24, 2007 | 07:46 AM
DandyMax's Avatar
3.5 in the works
C'mon details man, whadidya run?
0.6 is a good improvement!
Old Apr 24, 2007 | 11:37 AM
gtr_rider's Avatar
192.168.1.1
15.8 @ 40
Old Apr 24, 2007 | 12:50 PM
Tatanko's Avatar
Bacon Lover
15.5 @ 90. Pitiful, pitiful track. I'm not going to make excuses for my driving ability (I've hardly driven my car the track ever) but that track is absolutely pitiful. Not-so-great elevation, slightly uphill (not kidding), etc. etc. Most definitely not a track to gauge yourself against people from other tracks.
That was with no weight reduction, manually shifting, no DR mod of any kind, nothing. Just my car with me manually shifting.
shilov
Feb 19, 2024 09:40 PM
t6378tp
Sep 29, 2018 04:27 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 19, 2015 01:07 AM
