Sponsored by:
Sponsored by: CARiD
4th gen 3.5 swap compression
Old May 8, 2007 | 02:04 PM
UNDEFINED76's Avatar
i wanted to see what kind of compression is everyone at in a 3.5 swap???
Old May 8, 2007 | 02:08 PM
NmexMAX's Avatar
dot dot dot ...
02+ VQ35DE's all have 10.3:1 if they're healthy. IIRC, earlyVQ35(01) Pathy's had 10.0:1. But that's another story.
Unless you interchange heads from the VQ30DE, there wont be any changes.
Old May 8, 2007 | 02:15 PM
sorry i didnt mension in psi please....thanks
Old May 8, 2007 | 02:38 PM
95BLKMAX's Avatar
same specs as 3.0. 180psi minimum.
Old May 8, 2007 | 03:08 PM
NmexMAX's Avatar
dot dot dot ...
180 - 185psi I thought that's what you meant, just thought I'd throw that out there for sharts and gangles.
Old May 8, 2007 | 04:13 PM
allanmaxt's Avatar
I have 225 0n mines on one head but the other head is shot its 180, 150 and 180 again.
Old May 8, 2007 | 05:31 PM
95BLKMAX's Avatar
225? you must have alot of carbon on those piston rings to have that high of a compression. The highest my engine does is 210psi, same with others maximas that I've been there for the compression check.
Old May 8, 2007 | 05:54 PM
nismology's Avatar
The minimum is closer to 143.
Either way, as you know, the absolute numbers aren't as important as variance between cylinders.
Old May 10, 2007 | 07:19 AM
allanmaxt's Avatar
yeah it doesn't matter anyway i'm tearing it apart as we speak droping in pistons and rods .
Old May 11, 2007 | 08:00 PM
SR20DEN's Avatar
VQ Wizard
I have never seen a VQ35 show less than 195psi, and no more than 215.
Fakie J Farkerton
Oct 14, 2015 06:25 PM
Finkle
Sep 27, 2015 09:53 PM
schmellyfart
Sep 25, 2015 04:47 PM
Blackwind
Aug 5, 2015 06:35 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
