Sponsored by:
Sponsored by: CARiD
VQ 37 HR dyno!!!!!!!!
Old May 21, 2007 | 07:08 PM
krismax's Avatar
Father of the 00 VI
just wow ,i had to put this here .
the raising of the dicplacment and the comp being raised from 10.6:1 to 11:1 and the VVEL make for a huge increase . and imagine when the VVEL is tuned
http://www.my350z.com/forum/showthread.php?t=273363
Old May 21, 2007 | 07:10 PM
MAXSE5SPD's Avatar
o snap
Old May 21, 2007 | 07:12 PM
MorpheusZero's Avatar
WOW.
Cliff's notes: 365bhp, awesome toark curve!1
I vant one...
Old May 21, 2007 | 09:09 PM
maxspeedse02's Avatar
Thinks he is fast
That is impressive. I can't believe how flat that torque curve is, just like an LS1. More than likely my next car....
Old May 21, 2007 | 09:25 PM
nismology's Avatar
The LS1 dyno's i've seen are ALL mid-range. Torque curves look like camel humps. They just make so much more average torque than most motors anyways so nobody really cares. This 3.7's is more like an I-VTEC torque curve, loooong and flat and that's damn impressive for a larger motor.
Old May 21, 2007 | 09:28 PM
DandyMax's Avatar
3.5 in the works
Sweet... man that VVEL would be nice to have!
Old May 21, 2007 | 09:52 PM
JClaw's Avatar
The next motor to go in my S13 is a VQ38 with VVL if I can get my hands on one in 2-3 years! Awesome find krismax.
Old May 21, 2007 | 11:01 PM
Theyears02's Avatar
torque numbers are a bit depressing but the HP numbers and flatness of torque curve make up for it...wonder what will be in the 2012 z, when im buying my next car
Old May 21, 2007 | 11:03 PM
tedo007's Avatar
faster than you think
thas almost 100hp/liter wow thats impressive
Old May 22, 2007 | 06:12 AM
NmexMAX's Avatar
dot dot dot ...
Borrowed from our own .orgness..
http://forums.maxima.org/showpost.ph...&postcount=152
Old May 22, 2007 | 06:20 AM
liqidvenom's Avatar
brotherhood of tq
i like the hp but the tq seems a bit sad to me...but its flatness is a nice thing to see.
and ls(?) dynos usually just have a tq flatness to them through out.
Old May 22, 2007 | 08:44 AM
nismology's Avatar
Hard to believe a motor without variable ANYTHING has a flat torque curve throughout. It's a mechanical impossibility, regardless of displacement. Not a knock on it at all, so don't get defensive in your next post, but I'll stand behind my previous statement. They look like camel humps. Low-end is good but doesn't quite match the HUGE mid-range torque which drops off at higher revs. Anything but flat, stock at least. Everything I've seen tells me the stock LS1 was tuned for mid-range torque. Don't want to get too far OT though. This thread is about another great Nissan innovation.
Old May 22, 2007 | 09:31 AM
liqidvenom's Avatar
brotherhood of tq
why you son of a bitc...nah im just playing, most i have seen have benifited from huge tq low end and carrying that same mostly through out...it does drop off higher up but thats mostly a cam issue than anything else. i am happy for nissan and this motor. if this would have been in the first g35 i wold have bought one in a heart beat....maybe i might end up with one with this powerplant. though it sucks for people who bought a 07-03ish g35 and got the "crappy" vq lol
Old May 22, 2007 | 11:56 AM
krismax's Avatar
Father of the 00 VI
one thing i noticed is this car was driven with AC on heat soaked to the dyno and tested .
i would bet people get higher #'s than this
and i believe the 08 z will get this engine ,because nissan has said this tec h will trickle down
Old May 22, 2007 | 12:05 PM
nismology's Avatar
I thought you hated variable valve timing technology and thought it was useless...
BTW the ECU has a cut feature that turns off the compressor during agressive throttle angles or revs.
Old May 22, 2007 | 12:11 PM
ajcool2's Avatar
So whats the next motor going into the max!! I want to do a 3.7 swap.
Old May 22, 2007 | 12:47 PM
thatcarguy350's Avatar
Ahhh, but with new technology, such as VVL, comes many more complications to your swap.
Old May 22, 2007 | 01:05 PM
LA02MAX's Avatar
VVEL. Variable Valve Event and Lift. I concur though..This is some pretty high tech stuff that would not be easily modifiable...a full swap might be possible but good luck on that journey...
The VQ37 impresses me and I can't wait until its release. I definitely want to feel the power delivery on that thing
Old May 22, 2007 | 03:11 PM
http://www.dragtimes.com/images_dyno...c-GTO-Dyno.jpg
80% peak torque at redline. Looks pretty flat to me... sure you weren't thinking of an LT1?
/OT
Old May 22, 2007 | 03:13 PM
nismology's Avatar
That's not an LS1 dyno...but w/e...
Old May 22, 2007 | 03:59 PM
jmeister's Avatar
umm... OK
Old May 22, 2007 | 04:27 PM
liqidvenom's Avatar
brotherhood of tq
ls1 dyno
http://www.dragtimes.com/2004-Pontia...aphs-9875.html
that is more flat then what the vq37 can wish to have
Old May 22, 2007 | 04:29 PM
http://www.internetautoguide.com/car...gto/index.html
Old May 22, 2007 | 04:48 PM
nismology's Avatar
ls1 dyno
Anyhow, that LS2 powerband is from 2500-6000. The 3.7's is 3000-7500+. You do the math.
BTW, whenever the air/fuel graph is included in a dyno chart the HP/TQ curves end up squished and look flatter/smoother than normal. Just an FYI.
Old May 22, 2007 | 04:50 PM
nismology's Avatar
Originally Posted by MorpheusZero
The GTO has an LS2. Either way, I digress. Useless banter, really.
Old May 22, 2007 | 04:52 PM
liqidvenom's Avatar
brotherhood of tq
04-05 has ls1
06+ has ls1
its ok your the mod of max.org all motor section...the rest of us follow other cars as well
(feels the thump of the ban stick)
Old May 22, 2007 | 04:54 PM
liqidvenom's Avatar
brotherhood of tq
even ls1 vettes have the same tq platuoe(sp) and they can rev up to 7k easy. and the 3.7's is up and down...more camel humpish if you ask me
Old May 22, 2007 | 04:55 PM
nismology's Avatar
Fine, ya got me with the LS1/LS2 model year jive.
Either way, I still don't think the LS1 comparison is valid simply because its effective operating range is smaller. The 3.7 torque curve is flat for LONGER. If the rev-limit was raised to 8k it would still be making good power up there.
Old May 22, 2007 | 04:56 PM
BTW, whenever the air/fuel graph is included in a dyno chart the HP/TQ curves end up squished and look flatter/smoother than they really are. Just an FYI.
-2k4 goats had LS1s.
-80% peak tq at redline. For reference, the VQ37HR has ~84% peak tq at redline.
-I'm not sure how your powerband comparison is relevant, but the chart is from 1500-6000rpm if you look closely, and it almost completely flat. Either way you look at it, there is a 40ftlb fluctuation (13%) between 1500 and 5500rpm on a car that peaks at 320ftlbs.
Old May 22, 2007 | 05:02 PM
VIP Maxima
uhhhhhh VQ35 swaps are now what, oldskool?????
psh, i wonder who is gonna be the first to swap in a VQ37. we must first aquire a FWD version
Old May 22, 2007 | 05:04 PM
Yeah, it'll be interesting to see when they start putting them in the FWDs.
Old May 22, 2007 | 05:05 PM
nismology's Avatar
-I'm not sure how your powerband comparison is relevant, but the chart is from 1500-6000rpm if you look closely, and it almost completely flat. Either way you look at it, there is a 40ftlb fluctuation between 1500 and 5500rpm on a car that peaks at 320ftlbs.
ZOMG.
I'm not saying that LS-series engines don't have a flat torque curve. I'm just saying it's not an apples to apples comparison to the 3.7 because its relative power curve is much broader, IMO. This motor should be compared to the M3's, GT3's, NSX crowd IMO. High-revvers with linear power delivery.
But you all can continue to dissect my posts and miss my overall point if you'd like.
Old May 22, 2007 | 05:09 PM
nismology's Avatar
3.5 swaps running off of 3.0 ECU's are.
According to nissan the 7th gen max has an ace up its sleeve. Hopefully it's a HR or an HR variant.
Old May 22, 2007 | 05:15 PM
ZOMG.
Dood. You said Ellis Juan = camel hump. I said "not exactly." It's pretty simple.
Old May 22, 2007 | 05:23 PM
nismology's Avatar
Show me a graph without the a/f at the bottom and I'll be glad to make nice.
Old May 22, 2007 | 05:28 PM
http://www.ericohlsen.com/FBODY/CamaroDyno.jpg
http://img.photobucket.com/albums/v6...c-GTO-Dyno.jpg
Old May 22, 2007 | 05:30 PM
nismology's Avatar
Wasn't revved out FTL.
Old May 22, 2007 | 05:33 PM
Jesus, you're insatiable. Check the post again.
Just in case it's still too flat, here you go.
Old May 22, 2007 | 05:36 PM
nismology's Avatar
No RPM on that last one?
Just givin' ya a hard time is all.
Old May 22, 2007 | 05:41 PM
I believe it's called "dragging your feet." Pshop it yourself if you don't trust me.
