Sponsored by:
Sponsored by: CARiD
Brian Crower Camshafts?
Old Jul 3, 2007 | 12:33 PM
Red Lion's Avatar
Just wondering if anyone has these installed on their VQ's.
I'm not looking for a really agressive cam right now, just a step up. I pretty much have decided on JWT's or Brian Crowers. Has anyone had any experience with them? I've searched NicoClub, Fresh Alloy, 350Z tech and here and haven't found anything bad to say about them but not really any info at all.
Their site says the stage 2 cams (264/264, 10.41mm) are fine with OEM valvesprings. What do you think?
Old Jul 4, 2007 | 02:40 PM
NmexMAX's Avatar
dot dot dot ...
IMO, valvesprings depend on what RPM you are using. I suppose with a real aggressive cam, valve springs might play a small role, but even then, 2 stock rev limits, I don’t think it will be an issue.
What engine are they going in(what are you planning on putting them in)?
Old Jul 4, 2007 | 03:11 PM
Red Lion's Avatar
04 Maxima VQ35DE.
Had planned on setting redline to 7200RPM.
I knew valvesprings/etc would be necessary if I were to do a build up and try some really high RPM's, but for just 7200 with these cams the OEM should be okay wouldn't they?
Old Jul 4, 2007 | 03:15 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by Red Lion
Had planned on setting redline to 7200RPM.Who did?
I would say they're ok. BUT, if you're going in there, why the heck not change them anyway?
IIRC, A34 VS are a touch softer than A33B's.
Old Jul 4, 2007 | 04:57 PM
nismology's Avatar
Aftermarket cams @ 7200 RPM w/stock valve springs =
Why risk it?
Old Jul 4, 2007 | 05:13 PM
Red Lion's Avatar
Why risk it?
well, my understanding was that ARP rod bolts would be all that was necessary for the 3.5 to rev to 7200 safely; I didn't take into consideration that aftermarket cams would cause any problems up top. They're cheap though (the valvesprings), so I probably will go ahead with it if the stock units aren't safe with aftermarket cams at that RPM.
Old Jul 4, 2007 | 05:17 PM
nismology's Avatar
Increased valve lift = increased valve stroke speed @ same RPM. Combine that with a raised redline and the demands on the valvespring to keep the tappet in contact with the cam lobe at high RPM rise dramatically.
Old Jul 4, 2007 | 08:55 PM
THT's Avatar
THT
Throbbing member
Crap...I knew I should have sprung for the Ferrea parts to go with my S1 knockoffs....
Old Jul 4, 2007 | 09:22 PM
NmexMAX's Avatar
dot dot dot ...
IIRC Nealoc187 did see some possible valve float on his VQ30 @ 7200 w/stock cams.
Old Jul 5, 2007 | 08:21 AM
Red Lion's Avatar
hmmm, thanks for the input fellas. $308 for BC valvesprings/retainers is cheap insurance if I am going to run cams and try to get the 7200rpm redline out of the engine.
Old Jul 5, 2007 | 08:40 AM
DandyMax's Avatar
3.5 in the works
The VQ30 engine modeling I've done seems to indicate valve toss starts (barely) even before that, however if that's true, then at that rpm it's not a physical problem as it's small enough that no piston/valve contact is made and things aren't bouncing too much. In fact a little bit of it at rpms higher than that may actually slightly improve high end breathing as it essentially extends the closing ramp... Once about 7600 hits though all bets are off (again according to the model but that seems to be born out by user experience as several of us have noted a difference in engine tone at that rpm and it was where we "thought" float might be". IIRC JWT seems to think it starts at 7300 or so...)
Now the VQ35 I have not modeled.. yet (I will eventually), but it has different valve train dynamics obviously.
Old Jul 5, 2007 | 08:51 AM
Red Lion's Avatar
well, the question of needing valvesprings or not is answered, but how do you all feel about BC's camshafts as far as reliability? Has anyone heard anything bad about them that would make me change my mind and pick another cam? I'm asking more about build quality than power, lift and duration, etc.
Old Jul 5, 2007 | 08:59 AM
NiSmOVQ35's Avatar
Ive heard nothing bad about them.
Old Jul 5, 2007 | 12:35 PM
NmexMAX's Avatar
dot dot dot ...
Come on man. We've all said you should get them in when you're getting the cams. Use common sense and add them when you do the cams, because, you are doing them, right?
I've heard nothing but good about them as well.
Old Jul 5, 2007 | 01:22 PM
Red Lion's Avatar
Huh? I said you guys answered the question and I was going to go ahead and get the valvesprings.
For the record, it's not common sense to me as my car came with a KA24DE originally and KA's don't need valvesprings/retainers to go from 6500 to 7200RPM with mild cams.
But I'm glad you guys told me otherwise about it, I'm still not 100% familiar with VQ basics. Thanks!
Old Jul 5, 2007 | 03:00 PM
636specman's Avatar
thats my plan for very soon...bc cams, springs, valves, and built motor. where in missouri are you from?
Old Jul 5, 2007 | 03:11 PM
SPiG's Avatar
SomePsychoGuy
You may need them, you may not, but if you are going to take apart the valve train then you should do everything together that you can. It would not hurt as a little insurance. The trouble of swapping engine or tearing it down later just to change the springs is way more trouble than doing it while doing the cams.
I think that valve springs do hurt your low end though since they make it harder to open the valves. Something else to consider, but if you are installing cams and raising the rev limiter, a little bit of low end loss is to be expected.
Old Jul 5, 2007 | 03:57 PM
Red Lion's Avatar
Joplin/Springfield area
Old Jul 5, 2007 | 04:47 PM
NmexMAX's Avatar
dot dot dot ...
I misread what you typed. I apologize for jumping on you. These are VQ's, not KA's though.
Old Jul 5, 2007 | 09:28 PM
nismology's Avatar
Common Misconception:
Many people mistakenly think that using higher seat pressures causes a reduction in the horsepower delivered to the flywheel because higher seat pressures (and also higher spring rates required for high performance) require horsepower to compress the springs. This thinking is simply incomplete! For every valve that is opening and its valve spring being compressed, another valve is closing and its valve spring is expanding. This expansion returns the energy to the valve train and the engine. This results in a net power loss of "0" hp. Many engineering texts refer to this as the "regenerative characteristic" of the valve train. Recent tests at Crane have shown no horsepower loss on a hydraulic roller equipped engine when changing the seat pressure from 135# to 165#. Power actually improved significantly at top end, probably due to better control of the relatively heavy valves in the engine.
http://www.cranecams.com/?id=5&show=faq
Old Jul 6, 2007 | 06:11 AM
Matt93SE's Avatar
STFU n00b!
a bit OT, but revving a KA to that kind of RPM is asking to eat rod and main bearings. how long do those things last at that RPM? Feel free to PM response since this is off the thread's topic.
back on topic.. I've heard nothing but good about Brian Crower components. I'd have no problem putting them in my car. (in fact I'm going to get a set of their 272 cams and valve springs for my KA when I get to that point).
Old Jul 6, 2007 | 06:36 AM
MaxBlack97's Avatar
rod bolts r probably the only necessity at 7200rpm, the springs r an option 4 xtra security, but I agree u might as well since ur building it anyway and the they arent that much $$$
Old Jul 6, 2007 | 08:06 AM
Broaner's Avatar
2060lbs and falling...
That Crane explaination is so simple yet makes so much sense. I kick myself for never thinking of it like that before.
Old Jul 6, 2007 | 08:37 AM
Matt93SE's Avatar
STFU n00b!
Sometimes you gotta think inside AND outside the box.
Old Jul 6, 2007 | 12:06 PM
SPiG's Avatar
SomePsychoGuy
I stand corrected. Very good info.
Old Jul 7, 2007 | 08:43 AM
THT's Avatar
THT
Throbbing member
Why not use a set of JWT springs since they're less expensive?
http://www.jimwolftechnology.com/cus...asp?PartID=448
Old Jul 7, 2007 | 10:47 AM
SR20DEN's Avatar
VQ Wizard
Why not use the VQ35HR springs and retainers that I have posted about?
http://forums.maxima.org/showthread....t=valve+spring
Also, why not save more money and use the Nismo or JWT knockoff cams you can buy from Ebay stores?
http://cgi.ebay.com/ebaymotors/Nismo...spagenameZWDVW
This is exactly the setup that I would use.
Old Jul 7, 2007 | 11:10 AM
DandyMax's Avatar
3.5 in the works
You guys should definitely consider what Matt's suggesting... look at the data and you'll see why.
PS Matt do you have the weight of the standard VQ35 valve spring handy somewhere?
Old Jul 7, 2007 | 11:15 AM
SR20DEN's Avatar
VQ Wizard
You mean the weight or mass of the actual spring? I do not. I still need to pick out and buy a good jewelry scale.
Old Jul 7, 2007 | 11:20 AM
DandyMax's Avatar
3.5 in the works
Yes mass, sorry. I imagine it's ~30-31 g or so, I was wondering how heavy it was compared to the HR.
Old Jul 7, 2007 | 11:23 PM
Red Lion's Avatar
lol I worry about the quality of the knock-off cams. Who makes them anyway?
And THANK YOU very much for reminding me of the HR valvesprings and retainers. I had completely forgotten about them! So the obvious question I'll ask is how much do they cost?
I'm kind of unsure now whether I want to try to get the motor to 7200rpm
s now. If aftermarket cams will work with the stock 6500 without needing valvesprings/retainers I'll do it. It's not so much because I'm cheap and don't want to buy the retainers, but on the other hand I'm getting this urge that says if I'm going to buy cams and valvesprings/retainers, why not buy different rods and pistons, do some headwork, full rebuild...etc. etc.
It's humiliating but I have to keep myself retrained right now and go for a full build or something else later on.
Old Jul 7, 2007 | 11:44 PM
SR20DEN's Avatar
VQ Wizard
I don't like to quote prices but I will say that the springs and retainers are pleasantly cheap from the dealer. To the point of which it isn't worth skipping out on.
The problem is getting the (economical) tooling to change them in the car.
Both brands of knockoffs are made in China/Taiwan IIRC. And combined I would say that 100 or more of them have been sold.
I have seen the Nismo knockoffs and I must say they look really nice.
Old Jul 8, 2007 | 12:46 AM
DandyMax's Avatar
3.5 in the works
Any leads/suggestions on that? I've been looking around here for just such a tool lately and no luck. Anything that looked somewhat promising didn't work because of lack of space between the spring and lifter guide wall. I have a spring compressor that works just fine with the heads off, but I'd love to have something that works with them on.
Old Jul 8, 2007 | 05:37 AM
nismology's Avatar
http://www.my350z.com/forum/showpost...3&postcount=24
Seems like an awesome tool. Not sure how easy it'd be to use with the engine still in the car though.
Old Jul 8, 2007 | 05:59 AM
SR20DEN's Avatar
VQ Wizard
Great find!
Old Jul 8, 2007 | 12:18 PM
Red Lion's Avatar
nice find!
Luckily for me the engine is out of the car.
alright, cool, no quoting necessary, but would you say they are less than the $308 I've found for BC's springs/retainers?
Old Jul 8, 2007 | 12:23 PM
SR20DEN's Avatar
VQ Wizard
<<<<<$200........ Call Dave Burnette at South Point Nissan. 888-254-6060
Also don't forget to order a new shim set because you really should double shim these springs.
However the BC kit appears to have about 75% more pressure than the OE spring.
And everyone be aware that I have not found a single aftermarket spring that uses the factory retainer, except for a JWT spring which appears to have similar specs as the VQ35HR spring. And of course for more money. I suspect they're now reselling those springs with a JWT badge.
All other aftermarket springs have different install heights.
Old Jul 8, 2007 | 12:39 PM
SR20DEN's Avatar
VQ Wizard
Ok i somehow missed this post.
Because? My answer is above.
Old Jul 8, 2007 | 02:26 PM
Red Lion's Avatar
lol cams and valvesprings/retainers for less than the cost of BC, JWT or Nismo cams? I'm glad I made this thread...thanks a ton!
Old Jul 8, 2007 | 07:35 PM
DandyMax's Avatar
3.5 in the works
Kewl... might just have to try one of those out!
