Sponsored by:
Sponsored by: CARiD
Datalog sheets
Old Jul 6, 2007 | 01:10 AM
The Law's Avatar
I R The Law
Datalog sheets
Well here are some datalog sheets that I ran about a week ago. Tell me how these look. I'm still trying to learn how to read these files still and I'm having a bit of trouble with it. I also forgot what settings they were suppose to be at. Any help with this would be appricated.
Old Jul 6, 2007 | 05:53 AM
speed racer's Avatar
you need to calibrate the gauges. The manual explains this. The A/F should be 0 to 20 on your Y axis. Your X axis should read rpm.
Old Jul 6, 2007 | 06:38 AM
MaxBlack97's Avatar
yo speed racer, do u know a shop in NY that has experience in tuning maxs?
Old Jul 6, 2007 | 07:01 AM
http://forums.nycmaximas.org/showthread.php?t=24581
I went to T&R racing. It cost me $120.00 for an hour of dyno and adjusting A/F ratio.
Old Jul 6, 2007 | 10:16 AM
MaxBlack97's Avatar
wha ecu r u using, thanx in advance
Old Jul 6, 2007 | 12:01 PM
NmexMAX's Avatar
dot dot dot ...
What ECU pins did you tap into? I tapped MAF/TPS/ECT/MPH/RPM. Obviously the most useful is RPM vs AFR.
For comparison purposes, it's nice to test speed vs time whenever adding mods. Of course, it's best to try and compare whenever ambient temps are comparable.
I've also found that when data logging it's best/most accurate to log w/laptop in car, (pres REC, then log) vs using the black controller box to log.
Old Jul 6, 2007 | 12:51 PM
I always thought its the other way around. That logging with the control box produces more accurate data logging. I think it even says this in the manual.
Old Jul 6, 2007 | 12:53 PM
NmexMAX's Avatar
dot dot dot ...
Not IME. Look @ the RPM, 7290 My car only goes up tp 7100, and I get more accurate readings when direct logging w/ laptop. Even if I use the same mx+b equation re: RPM (hertz via FSM)
What page does it state that?
maxprivate
Nov 29, 2017 08:52 AM
jholley
Aug 30, 2015 06:39 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
SINYMaxSE
Jul 15, 2001 02:42 AM
