Sponsored by:
Sponsored by: CARiD
GI in 6speed timing rings for the vq30ecu
Old Jul 30, 2007 | 03:39 PM
95turbo gxe's Avatar
ok Im starting to get a lot of 6speed pms. Maniley about the 6speed timing ring.
Ok I custom made mine in the shop and the car runs fine na even hard na driving but when I get into boost the signal get distorted and the injectors cut out. Me and tilley had this same problem. Ok well im going to make the second attemp to get this worked out. Im going to a machine shop this time as I made my own last time it was very close but it was welded and it has a slight woble. And may be out of balance just like a tire it only wobbles at cretain speeds like my ring it breaks up at a surtain rpms.
Well this time it will be a fully bolt on ring with a spacer kit so you would not have to move or guess where the cps sensor would go. You would be able to leave it in the stock location. So it would be a fully bolt on kit.This kit would be only for aftermarket 6speed flywheels. If anyone had a auto flex plate and did not want it would help me with the project as I dont have anymore of them. I need it just to get a measurement.
I should have the out come on this in about a week.
Old Jul 30, 2007 | 05:33 PM
tsaulz's Avatar
Good looking. I am having a custom ring made for my swap, although it will not need a spacer (since I am using the FWD flywheel.) I'll see if I can have this machinist ship my auto flex plate back to you once he finishes using it as a template.
I haven't finalized the details with the machinist--if things don't work out, I may have to go through your guy.
Old Jul 30, 2007 | 05:38 PM
It will have to have some type of off set to work. It does not matter fwd or rwd. You will need it to set in place not just on the flywheel.
Old Jul 30, 2007 | 06:04 PM
tsaulz's Avatar
Did Travis's ring use a spacer? I thought that his ring bolted on to the 3.5 flywheel in position for the CPS w/o realignment of the sensor.
Old Jul 30, 2007 | 06:18 PM
No from what I understand from max5speed he had to cut out and move sensor and try to get in the right place. He used Travis ring
Old Jul 30, 2007 | 06:28 PM
nismology's Avatar
The offset is different only with RWD flywheels.
Old Jul 30, 2007 | 06:36 PM
tsaulz's Avatar
http://forums.maxima.org/showpost.ph...&postcount=115 :
And, if you're scratching your head about the CPS ring issue, since we will be running the A32 ECU/harness with a 6spd.. here's how we got around it..
I had a CPS ring cut out on a water-jet machine, out of 1/8" steel. This ring bolts to a VQ35DE FWD flywheel from JWT, which puts the teeth in the correct location for the sensor to read.
Travis
Old Jul 30, 2007 | 06:37 PM
Timing ring off set has to be about the same because when maxspeed switched from the 350z to the maxima6speed wheel he did not have to move his sensor
Old Jul 30, 2007 | 07:22 PM
nismology's Avatar
That would only make sense if perhaps the custom timing rings were a different thickness than the OEM 6-speed timing ring, i.e. thicker so that the CPS can still read from it despite the offset being different. As far as the 6-speed VQ35 timing rings are concerned, the offset is absolutely different.
Old Jul 30, 2007 | 07:39 PM
Yeah im not sure about the stock timing ring being differant. the flywheel off set as to where it mounts should be about the same
Old Jul 30, 2007 | 07:41 PM
nismology's Avatar
Dude, the stock timing ring offset is different between FWD and RWD, period. SR20 discovered this a couple years back. The questions come in to play when custom rings are made.
Old Jul 30, 2007 | 07:52 PM
ok. Im going to get back on point here and make my ring again and see if I can help some other with aftemarket flywheels Rwd/or fwd
Old Jul 30, 2007 | 07:58 PM
Hey I see your post here. That cool. i just wondering why maxspeed had to move his for the rwd but left it in the same position for the fwd flywheel he later swaped to. If that is right what traivs said your in luck and it should work with no problem. I may be the only one that has to have the spacer due to using the rwd flywheel. I can honestly say because I dont have them both infront me but im going by his word on not moving the sensor again back to stock location. I know with the rwd flywheel you will have to move the ring closer to the block.
Old Jul 31, 2007 | 07:04 AM
tsaulz's Avatar
Looking at my FWD flywheel, there is no way I could fit a spacer for the timing ring, because then the ring would hit the block. How much were you looking to pay for these rings? Fred Burge's machinist in Arizona gave me a pretty good quote on one (much cheaper than the $400 a local machinist wanted.)
maxfever1987
Nov 19, 2016 08:01 PM
umnitza
Sep 1, 2015 01:03 PM
95Maxi
Aug 25, 2015 08:01 PM
Team STILLEN
Aug 10, 2015 04:29 PM
