Sponsored by:
Sponsored by: CARiD
Differences between 04 and 02?....
Old Aug 13, 2007 | 11:50 PM
00SEMAX19's Avatar
My friend has a 04 alty wich I believe is basically the same setup as the max.
It appears that he only has 2 O2 sensors and we know my 02 has 4.
I know that the 2 rear 02 sensors are for cat efficiency and don't controll A/F and stuff like that. (by the way with my 02 sims I still have slow responce codes)
The question is, Can I install a 04 alty or 6th gen computer to eliminate the other 2 O2 sensors? Does the fact they have EGR have anything to do with it? What issues would this cause or would it be a better idea than using O2 sims?
Any info or ideas would be much appreciated.
Old Aug 14, 2007 | 03:23 AM
scrhale's Avatar
I wouldn't advise a 6th gen. I have done a lot of research with the compatibility and changes necessary for 4th gen ECU -> 5.5 gen ECU and 4th gen ECU -> 6th gen ECU and realized that the differences are enough between the two are enough to provide more headaches then it is worth. I would stick to sims. I do not know about 04 Alty.
Old Aug 14, 2007 | 04:17 AM
nismology's Avatar
Swapping ECU's over o2 sensors is just crazy talk. Not worth the trouble.
Old Aug 14, 2007 | 07:37 AM
eng92's Avatar
Where did you get your O2 sim from?
I have been running an o2 sim in place of one of the two rear sensors (03 maxima ecu) for about a year and a half without any codes.
Old Aug 14, 2007 | 10:30 AM
00SEMAX19's Avatar
http://webstore.o2simulator.com/
Ya, I figured there would be other differences than just the 02's. I think the fuel systems are different also. The Alty was different when I installed his nitrous than my car was
It just appears that I can install headers on his car without the trouble of using 02 sims like I had to.
I guess I was just hoping that it would be a direct swap.
Thanks for input
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Pied
Sep 26, 2015 03:29 PM
