Sponsored by:
Sponsored by: CARiD
exhaust on 3.5 swap
Old Nov 4, 2007 | 02:48 PM
ShiftVQ35
exhaust on 3.5 swap
To those that have done the 3.5 swap into a 4th gen, which exhaust are you using? Meaning what generation headers or what y-pipe are on your car currently ? I am asking because i am using headers from cattman for the 5.5 gen max on my 3.5 swap and im having trouble with fitment. The headers are perfect but the y-pipe doesnt line up with the actual headers and if i force it to line up, the exhaust is off-centered and hits the tunnel. The whole exhaust is also pushed back so it sticks out further then its supposed to be. Or is there something else that i am missing here ?
Old Nov 4, 2007 | 03:46 PM
nismology's Avatar
Have you tried contacting Brian directly? The 3.5 swap part of it does not apply. If you're having fitment issues with the 3.5 in there you'd be having issues with the 3.0 as well.
Old Nov 4, 2007 | 04:49 PM
96sleeper's Avatar
You should be using headers for the 4th gen if you want them to line up correctly with the exhaust.
Old Nov 5, 2007 | 07:36 AM
ShiftVQ35
well according to cattman all headers are the same meaning the only difference is the egr on the earlier models. So it has to be something else then. Any ideas ?
Old Nov 6, 2007 | 05:03 AM
MDeezy's Avatar
you should be using 4th gen parts, and you shouldn't have any figment problems unless the component itself was improperly made
the 5.5th gen header will fit onto the motor, how it will bot up to a 4th gen y-pipe (if thats what your doing) I'm not sure if it will work well.
an exhaust shop could help fix any problems your having.
Old Nov 6, 2007 | 05:58 AM
L.M.L.
it sounds like his 5.5th gen headers/y-pipe (cattman) don't align with cat/b-pipe..
Old Nov 6, 2007 | 03:39 PM
MDeezy's Avatar
thats what I get for speed reading a post before i have to rush to work. I see now that was the delima.
Solution will be to either buy 4th gen parts, or to save time and money take it to an exhaust shop and have them cut and weld it to line up. Tell them to weld back on your flanged to keep everything a bolt up affair. Some shops friends have gone too just cut and weld everything as a solid piece.
Old Nov 11, 2007 | 03:30 PM
ShiftVQ35
well i got it figured out thanks for all the help haha
Old Nov 15, 2007 | 05:09 PM
11-YEARS-DEALER-EXP's Avatar
Will installing a free flowing cat set my engine light ?
Old Nov 16, 2007 | 02:22 PM
NmexMAX's Avatar
dot dot dot ...
No . . . . . . .
meccanj98
Sep 16, 2015 06:06 PM
MaxRPM6
Sep 11, 2015 06:56 PM
I<3 A32's
Sep 10, 2015 11:07 AM
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
