Sponsored by:
Sponsored by: CARiD
CAM question..........again
Old Nov 6, 2007 | 10:33 PM
redmaxpa007's Avatar
i SeE what you did therE
ok...........seriously.... i am really tired of searching.. my eyes hurt...
has anyone sucessfully got a set of 350z rev up cams working in their 3.5 maxima/altima? and if so, dyno? impressions?
Old Nov 7, 2007 | 08:33 AM
26 reads and no one.............
Old Nov 7, 2007 | 09:17 AM
Puppetmaster's Avatar
IIRC, this was tossed around a bit last year, but no one has done it because it hasn't been worth the effort, esp when you can now get JWT, Nismo, Delubz, etc cams on eBay and my350z for around the same price. Someone please correct me if I'm wrong.
Old Nov 7, 2007 | 09:46 AM
NmexMAX's Avatar
dot dot dot ...
You may need to alter them in some way in order to accommodate the added CVTC phaser/sprocket. No one on here has even attempted this as of yet.
Old Nov 7, 2007 | 12:54 PM
yeah, i read those.. and i know they would have to be modified slightly to work..
was just wondering if the slight difference in the rev up would be worth the install.. guess i might as well wait to get some JWT, Nismo, Delubz, etc cams
i can get a set of rev up cams hella cheap, that is y i was asking....
Old Nov 7, 2007 | 12:55 PM
i was just gonna pm you since it seems you are full of..................... info..
Old Nov 7, 2007 | 02:10 PM
NmexMAX's Avatar
dot dot dot ...
I can be full of caka if I don't like you, semi helpful otherwise. Either way, the info is out there, just seems as if your OG-ness inhibits you the proper search skills. My real point is, why not get as much as you can prior to going with cams? Because they're cheap? Anyone of us could get them for pretty cheap on the Z/G boards.
In any case, rev limiter extension should be mandatory.
Old Nov 7, 2007 | 02:47 PM
og-ness aside.... i search for over 2 hours on 3 different boards without a 100% yes or no....
yes, cheap on the z boards was y i was asking about them. and as for getting as much as i can before cams? HELL yes.. doing the research now and planning ahead is always how i have modded cars.
the .orgy is the best site for all this... the z guys go beyond our scope sometimes and the altima guys are tight lipped...
rev limiter and ecu adjustments....
Old Nov 7, 2007 | 07:45 PM
NmexMAX's Avatar
dot dot dot ...
Get an FSM from each vehicle and study it for 2 hours (EM section)
Old Nov 7, 2007 | 07:47 PM
Get an FSM and study it for 2 hours (EM section)
..... i have that as well........
Old Nov 7, 2007 | 07:50 PM
NmexMAX's Avatar
dot dot dot ...
From each vehicle? (Z33/A33B)?
Old Nov 7, 2007 | 08:01 PM
Z33/L31
Old Nov 7, 2007 | 08:04 PM
NmexMAX's Avatar
dot dot dot ...
IBIseenismologylookinginherehurryandhelp
Old Nov 7, 2007 | 08:05 PM
IBIseenismologylurkinginherehurryandhelp
fixed it
Old Nov 7, 2007 | 08:09 PM
NmexMAX's Avatar
dot dot dot ...
I thought of that, but being that we can see that he's in here sorta eliminates the lurk effect.
Old Nov 7, 2007 | 08:20 PM
nismology's Avatar
The FSM's wouldn't really help him as far as installation is concerned since the steps are identical. He needs pictures of the business end of a revup exhaust cam to know precisely how to reposition the dowel if necessary. He also needs to know how many degrees the electromagnetic retarders sweep to know exactly where the dowel needs to be for cam timing purposes. He could use the Z33 manual to look up the cam timing however but until he gets those two other bits of info the cam timing specs in the FSM are useless.
Old Nov 7, 2007 | 08:28 PM
NmexMAX's Avatar
dot dot dot ...
Old Nov 7, 2007 | 08:35 PM
those were the issues i understood, just wanted to know if anyone had already figured it out... grumble grumble...
my car is a daily driver, so i can experiment.....
and here i thought you had all the info.........
nismology......
Old Nov 7, 2007 | 08:37 PM
NmexMAX's Avatar
dot dot dot ...
I get all my info from him and spread it around as best as I can.
Old Nov 7, 2007 | 08:40 PM
well then,
all motor is gonna be my new home......
Old Nov 7, 2007 | 09:38 PM
nismology's Avatar
I just PM'ed a revup cam seller over on my350z requesting a picture of the sprocket side of the exhaust cams. Now I wait.
Old Nov 7, 2007 | 09:41 PM
NmexMAX's Avatar
dot dot dot ...
I think I'm nearly at my electronic ceiling right now, minus EMU/UTEC/SA. I soon may need to add cams.
Oh yeah, :
Old Nov 7, 2007 | 09:54 PM
i was just looking through the 350z threads to find that!!.......
Old Nov 7, 2007 | 09:55 PM
Oh yeah, :
Old Nov 8, 2007 | 05:24 AM
98MaXeDouT's Avatar
Well fellas....I'm in the process of dropping these into my motor. Were swapping the new engine in saturday. Basically we custom fabbed adapters for the exhaust cams. We essentially modded JWT cam spacers, by drilling a 6mm hole 180* from the original.
Not sure exactly how its gonna work, but only time will tell. Anyways...these are going in a built 3.5 (minus pistons/rods) and its gonna have some boost on it. As soon as we are up and running I'll let you guys know.
Old Nov 8, 2007 | 08:57 AM
DandyMax's Avatar
3.5 in the works
Post up some cam pics..
nismology's Avatar
So you essentially have no idea what your exhaust cam timing is going to be?
Old Nov 8, 2007 | 09:04 AM
98MaXeDouT's Avatar
Well I'm not the one doing the actual cam setup...my good friend is, vipervadim. He knows his stuff. I'll get more info after I speak to him, and hopefully ill post cam/adapter pics.
Old Nov 8, 2007 | 09:01 PM
still waiting for pics............
Old Nov 9, 2007 | 05:02 AM
98MaXeDouT's Avatar
Keep on waiting....I'm goin over there tonite to start the swap....see If I can take a couple and post em up.
Old Nov 9, 2007 | 06:28 AM
cw96's Avatar
So your motor is the one that Viper was talking about getting the rev up cams to work in.Have you gotten your rod bolts yet.I remember him saying that the bolts were the only thing holding up the install but everything else was finished. Unfortunately I bought my bolts from the same guy on e-bay and I'm still waiting on mine 3 weeks later.
Old Nov 9, 2007 | 08:48 AM
i will wait till the cows come home!!...... damn party cows!
Old Nov 9, 2007 | 09:04 AM
DandyMax's Avatar
3.5 in the works
Take a pic of a non-revup exhaust cam put end to end with a revup exhaust cam please. The sprocket ends I mean, put one cam end beside the other and push them together until the end(s) hits the flange(s) to stop more movement (hope that's understandable, it's hard to explain).
Thanks!
Old Nov 12, 2007 | 06:54 AM
98MaXeDouT's Avatar
well sorry for the delay guys....I've been really busy with work/car.
Unfortunately...it was too late to get the pics you guys requested. Sorry again :/
I did get some pics of the install, and how it was done.
Ok, here is a quick overview of what was done to make these work.
1. Buy JWT cam spacers
2. Drill a 6mm hole 180* from original hole (this will be intake sprocket)
3. For the exhaust sprocket, you use the JWT with a longer dowel
4. Install
Apparantly, they fit perfectly and everything is good to go.
**Congrats to ViperVadim for the First Rev-Up Cam install in a Max.**
He basically did everything, I just helped get some of the machining done. Vadim knows his stuff, and I'm sure he'll chime in here if I presented any info wrong.
Hope this helps a lil.
Old Nov 12, 2007 | 10:44 AM
DandyMax's Avatar
3.5 in the works
What you've described is exactly what you'd have to do to non-revup cams to make 3.0 timing work if you didn't get StephenMax adapters or machine sprockets like I did. Which suggest the revup cams are the same length... although I'd still like to have a confirmed measurement..
Old Nov 12, 2007 | 10:54 AM
98MaXeDouT's Avatar
Ok, the rev-up cams are the same length. Only difference is the lift/duration, and the Rev-Up cams have VTC's on both intake/exhaust.
As I mentioned for the intake cam we used the modded JWT spacer (6mm hole drilled 180* from original hole), and the exhaust cam we used a 3.0 dowel pin (longer one). But yes, the rev-up cams are the same length.
Hopefully, I'll have the whole engine in within the week, and can give you some butt dyno's before I throw the blower on and hit a real dyno.
Again, all credit goes to ViperVadim, I just helped when he needed it
Old Nov 12, 2007 | 11:06 AM
nismology's Avatar
Well the intake cams are indentical to non-revup cams as far as installation is concerned so that wasn't really a worry. As for the exhaust cams, I guess they have 1 dowel at 0* like the non-revup cams so installation isn't difficult at all. Thanks for the info.
The other part of the equation, of course, is the valve timing. Did he degree the exhaust camshafts at all? Installing them straight up might have left them in the retarded position and you'd end up with a heckuva lot more overlap than you bargained for.
Old Nov 12, 2007 | 11:21 AM
Tatanko's Avatar
Bacon Lover
I agree
Old Nov 12, 2007 | 11:35 AM
98MaXeDouT's Avatar
Thanks man, I been teaching myself as much as I can as we go through this build. I'd have to say, I'm fully confident I can build a 3.5 from the ground up, + all the aftermarket goodies.
I'll let you know anything else I find out about the install. My engine is a Vq35-1/2HR lol
Old Nov 12, 2007 | 11:55 AM
DandyMax's Avatar
3.5 in the works
Default exhaust position is advanced is it not? (need to check the FSM).
The intake is no concern to me but the length/sprocket end of the exhaust cam is important for my 3.5 application...
