Sponsored by:
Sponsored by: CARiD
Best way to pry flywheel
Old Dec 20, 2007 | 03:44 PM
tsaulz's Avatar
So I've removed the 8 bolts holding on the flywheel and I'm having trouble getting it off of the crank. I've tried prying with a screw driver with no luck. Is there a particular place where I should pry? How about tapping the back of it with a hammer/mallet?
Thanks guys.
Old Dec 20, 2007 | 03:48 PM
kzoosho's Avatar
i used a bf screwdriver and pryed in difrerent spots.
matty's Avatar
I used a Slide Hammer. Came right off
http://www.mytoolstore.com/toolaid/colli02.html
Old Dec 20, 2007 | 10:48 PM
tsaulz's Avatar
Where exactly did you pry? Between the block and the starter teeth? I was trying to be careful, because I'm worried about bending the CPS ring.
Matty, that slide hammer looks really neat, but I'm going to try a bit more with a screwdriver (because I'm cheap!)
Old Dec 20, 2007 | 11:20 PM
accordingtou's Avatar
VQ30 DE T
Remove the spacer
Install 2 crank-flywheel bolts just by a couple of threads.(so the flywheel doesnt pop off & hit the ground)
And pry between the oil pan and the back of the flywheel with a pry bar/ pipe etc.. yuh done If that dont work wak the crap out of it with a rubber mallet
Old Dec 21, 2007 | 02:49 AM
matty's Avatar
I borrowed a slide hammer. Worked perfectly
-matt
KabirUTA13
19
Oct 17, 2015 02:15 AM
kenc15
Sep 25, 2015 06:38 AM
