Fuel Line size and adapters when using aftermarket FPR?
I am trying to buy a new FPR for my car. However, the FPR I want which is made by Aeromotive uses 3/8NPT fittings. The other Aeromotive FPR that is commonly used by some of ya'll uses -6AN fittings, which is equivalent to 3/8.
My problem is that my car has 5/16 fuel lines. I am having a hard time finding 5/16 barb to 3/8 NPT. I can find them on McMaster-Carr, but they are sold in a 10 pack. I also considered stuffing the 5/16 hose onto the more common 3/8 fittings, but I am worried I won't be able to remove the hose from the larger fittings.
What kind of setups are ya'll using? I am trying to avoid using a bunch of expensive fittings, but like I said I can't find much online in the 5/16 size.
Help!
Help!
These sites have them:
Plus a bunch more results from Google, checked with all of them to see if they sell individually? Of course, I have no idea how 'fuel safe' nylon fittings are.
- http://www.eldonjames.com/html/adapter.html
- http://www.newageindustries.com/data...BarbedFittings
- http://olsen.thomasnet.com/item/pipe...38516?&seo=110
I am using 3/8 lines. My fuel line was cut way to close to the rail when I got it from the junkyard. So I cut off the crimped connector and slipped on the 3/8. I did use two clamps per fitting to secure them.
popdedop
Sep 11, 2015 11:17 AM
