Sponsored by:
Sponsored by: CARiD
350z motor, ecu and harness swap
Old Jan 22, 2008 | 03:38 PM
VqMoNsTeR's Avatar
this might be a dumb question BUT, what besides money would keep us from swapping a vq35de or vq35hr motor, ecu and wire harness from a 350z. would the hr bolt up to our transmission?
the reason for this swap would be because of the endless amount of products they make that only work on 350z. example uprev makes this new product called osiris ( http://uprev.com/products/products.html ) there is also a company around here, Alteredatmosphere, that actually reflashes ecu's on the spot. for 350z and g35's of course. all the cool products are for the g350z ...
how much work would be involved if at all possible.
Old Jan 22, 2008 | 03:42 PM
DasYears
see the thread like 4 posts down about the vh45de swap
Old Jan 22, 2008 | 03:52 PM
VqMoNsTeR's Avatar
vh45de would be out of the question. different block and we know it won't bolt to our tranny. there is no benefit from a truck motor in a car!
Old Jan 22, 2008 | 03:56 PM
!PrjctMax!'s Avatar
E-mail Up-Rev and tell them that you are a Maxima owner interested in the Osiris program...you would be the 3rd Maxima owner e-mailing them. I have offered them my ECU for testing (6th gen) and they said that they are extremely busy/packed with other projects ATM, so I should try back within 2 months.
Old Jan 22, 2008 | 04:01 PM
VqMoNsTeR's Avatar
maybe we should make a thread on here with a list of serious potential buyers and send them the link.
Old Jan 22, 2008 | 04:10 PM
!PrjctMax!'s Avatar
I'll start it if you want...
Old Jan 22, 2008 | 04:35 PM
VqMoNsTeR's Avatar
sure. 700 bucks is kinda steep though. if we could reflash more than one car it would be worth it.
Old Jan 22, 2008 | 04:42 PM
Jeff92se's Avatar
I'm needing a caw
Um that also includes the OBDII diagnostics software also I believe. But if you think $700 is steep, not sure if you want to swap a HR motor, ecu and wiring harness.
Old Jan 22, 2008 | 04:53 PM
VqMoNsTeR's Avatar
its called a hook up at the jy
Old Jan 22, 2008 | 05:02 PM
mtrai760's Avatar
'Trynna' is not a word
ibanotherprojectgetstalkedaboutandnevercompleteddu etobrokeasspeopleoverextendingtheredreamsandrealit y
Old Jan 22, 2008 | 05:06 PM
Puppetmaster's Avatar
More reading material here:
http://forums.maxima.org/showthread....ight=350z+swap
http://forums.maxima.org/showthread.php?t=297880
Old Jan 22, 2008 | 06:10 PM
nismology's Avatar
Anything can be done with enough time, money, and know-how.
Old Jan 22, 2008 | 06:17 PM
nismology's Avatar
Also, the items listed don't impress me enough to go the the trouble of a CAN-drenched ECU swap. There are many things available for both the FWD and RWD platforms as far as the drivetrain/powertrain is concerned that most people don't bother getting or researching.
Old Jan 22, 2008 | 06:54 PM
!PrjctMax!'s Avatar
...we can...check out their website for more info
Old Jan 22, 2008 | 06:59 PM
!PrjctMax!'s Avatar
I resent that!
I've e-mailed them numerous times and have an ECU ready for shipping to actually test the equipment out; they just don't have the "time" at the moment.
dan
Old Jan 22, 2008 | 07:26 PM
VqMoNsTeR's Avatar
i seen where it said "if u need to reflash more than one car contact our email" part. but i think that would limit their profit.
Old Jan 23, 2008 | 06:20 AM
Niz-Dat's Avatar
The VQ35 HR will bolt to the same bellhousing that the VQ30 will bolt to. I have found that the top two motor mount holes in the VQ35 timing chain cover are in the same location as the VQ30 but the VQ35 is about 3mm thicker and they stagger the mounting bosses. I not saying to try and put the HR in a Maxima but just from my experience they will bolt to the tranny.
Old Jan 23, 2008 | 08:19 AM
hacim105's Avatar
What is your experience? What basis do you have for the statements you've made? It doesn't make sense in any way shape or form that Nissan would make their RWD VQ35DE only match up to their RWD tranny, and then redesign to a RWD VQ35HR and all of a sudden it matches up to an older FWD tranny. If you have a basis for what you said then that's good news, but it doesn't seem logical.
Old Jan 23, 2008 | 09:49 AM
nismology's Avatar
The HR transmission bolt pattern is different from the 03-06 RWD VQ's.
Old Jan 23, 2008 | 10:21 AM
!PrjctMax!'s Avatar
I could have sworn that it was at least 2 cars that you could flash...maybe somewhere in that 34 pages it was mentioned...
Old Jan 23, 2008 | 10:23 AM
nismology's Avatar
No. The website explicitely states that the Osiris software will link itself to the first ECU it comes into contact with and will flash only that ECU.
Old Jan 23, 2008 | 10:26 AM
Jeff92se's Avatar
I'm needing a caw
I think you can buy an extra license to be able to flash up to 2 cars with one unit.
Old Jan 23, 2008 | 10:40 AM
!PrjctMax!'s Avatar
Yeah, I just looked it up too...
...maybe I've been tracking it for so long that when it was blossoming, they did not realize that they could LOSE money if they enabled it for multiple vehicles...and from there they have obviously changed it.
nismology's Avatar
I figured extra money was involved.
Old Jan 23, 2008 | 10:46 AM
Niz-Dat's Avatar
I have a tube frame race car that was originally set up with a VQ30 from a Maxima. Last year I ran the VQ30 in the car but this year I am putting in a VQ35hr out of a G35. I have a custom modified pathfinder oil pan and it only bolts up at the starter area but all the bolts and dowels in the motor line up. I have the motor installed right now and the only mods I have had to do is where I bolt up the front motor mount. I have also bolted up a non rev-up VQ35DE and it matches up to all the holes also. I have found that the holes and dowels in the bell housing area of the two motors are the same but I only use the oil pan mount area at the starter. I also have a VQ30 pathfinder pan that I use on both motors and they bolt right together. I am able to mix and match parts from various motors to get where I need to be but to do this in a Maxima would be a lot more difficult.
Old Jan 23, 2008 | 10:48 AM
!PrjctMax!'s Avatar
I'd be getting greedy/business oriented as well! lol Sell a product for $700 that can be split for two cars? HELL NO!
Old Jan 23, 2008 | 11:18 AM
505max94se's Avatar
As far as I know, all of the VQ's (except the vq40 and I'm not sure about the HR) have the same bolt pattern on the block, but it's the upper oil pan that is different. I also believe that all of the lower oil pans are interchangeable.
Old Jan 23, 2008 | 11:40 AM
accordingtou's Avatar
VQ30 DE T
LOL
Old Jan 23, 2008 | 02:09 PM
kzoosho's Avatar
He has a build thread somewhere about his numbers and what not. I remeber seeing it when he first said something no one believed him then.
Old Jan 23, 2008 | 03:24 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=398121&page=2
Unless you know of another, feel free.
Old Jan 23, 2008 | 03:43 PM
kzoosho's Avatar
Thats it . Thanks.
Old Jan 26, 2008 | 07:46 AM
KRRZ350's Avatar
I was going Bwahaha when I saw hacim's posts because I remembered that thread vs his post count and was like........ oooh ooooh, pwnage coming.
Old Jan 27, 2008 | 01:21 PM
kzoosho's Avatar
Yea his car is nice.
Old Jan 30, 2008 | 12:00 PM
D-Bo's Avatar
Droppin logs
You think the RWD VQ doesn't have a different block (casting)?
Old Jan 31, 2008 | 08:28 AM
VqMoNsTeR's Avatar
yea but some ppl have tried different things that work on 350z ex. their clutches.
Old Jan 31, 2008 | 08:34 AM
nismology's Avatar
350Z flywheels work too, but that's beside the point.
Old Jan 31, 2008 | 08:37 AM
nismology's Avatar
It's not a truck motor. It was developed back when Nissan had tons of loot in the late 80's. Way ahead of its time. It's probably the most overbuilt motor Nissan has ever made.
Old Jan 31, 2008 | 10:06 AM
D-Bo's Avatar
Droppin logs
Right, but mounting a longitudinal engine in a car setup for transverse= arseload of work
Old Jan 31, 2008 | 10:09 AM
nismology's Avatar
Pretty much.
Old Jan 31, 2008 | 10:16 AM
hacim105's Avatar
Well I just read through that thread you posted in previously and I'm quite impressed. I stand corrected. I guess I should read up on maxima.org more often, this information has been available for quite some time.
Back on topic, couldn't you just use the VQ35DE from a FWD and then use the ECU and Harness from a 350Z (non-revup)? It seems like it would make things a lot easier for installation.
Or what prevents 5.5 gens from swapping in the 350Z ecu? Obviously you would have to change the connections for the harness to the 350Z style but isn't this a possibility?
