Sponsored by:
Sponsored by: CARiD
clearance issues with z32 rods and pistons in a Vg30e
Old Jan 27, 2008 | 07:06 AM
akurtzer57's Avatar
http://cgi.ebay.com/ebaymotors/Nissa...em320210580390
there is a link to rods pistons and rings. I am going to turbo motor on top of those. My question is will I have any clearance issues with the vg30e heads and those rods and pistons. From my reaseach those rods will go on the stock crank no problem. (Correct me if im wrong)
Old Jan 27, 2008 | 12:09 PM
Nismo87SE's Avatar
It would be a waste of money, you can buy factory VG30ET pistons which drop in and will make 400-500whp easy. Stock rods aren't as weak as you think, they are as strong or stronger than SR20DET rods. Now the only upgrade I recommend for a turbo motor is the turbo oil pump from Z31. BTW check yo pms
Old Aug 11, 2008 | 11:34 AM
SHIFT_maxboost's Avatar
im doin the same thing. weird?? so you have any info i might need? i just pulled my motor and tranny 2 days ago. motor had 275,3xx....and wont go in first. plus smoke out of exhaust.....valve seats or rings?
Old Aug 11, 2008 | 03:34 PM
95BLKMAX's Avatar
talk about bumping old threads! lol resize your sig btw, thats ridiculously huge
Old Aug 14, 2008 | 11:07 AM
sorry bout the sig....my bro hooked it up. yeah so im stuck on internals, got the motor and tranny out. found a vlsd tranny with axles. im getting the block and head hot tanked this weekend then i was wondering about jmt cams and valve springs. what do you guys think. i do want to keep at least an 8.5/1 comp. or the stock 9/1. i dont want to loose low to mid range power. any sugestions?
Old Aug 14, 2008 | 02:27 PM
NmexMAX's Avatar
dot dot dot ...
Lowering compression ratio and this forum do not go hand in hand, at all.
Old Aug 15, 2008 | 12:05 PM
my bad....
Old Aug 15, 2008 | 12:06 PM
but this does have to do with prepping the motor
BkGreen97
Apr 2, 2016 05:47 AM
6spd4dsc
Mar 4, 2016 05:19 PM
Bonka
Sep 14, 2015 11:18 PM
ef9
Sep 10, 2015 10:35 PM
ballerchris510
Sep 10, 2015 09:35 PM
