MEVI question
MEVI question
I recently brought a 98 max as a second car, from a former org member. Everything works fine except for the MEVI. For some reason. the switch is acting if it's not getting an rpm signal. Ive tried getting th signal from both the ECU and #6 coil. Ive also tried both a summit racing rpm switch, and MSD rpm switch, both with the same results. Any ideas?
Well, the car was stolen from the previous owner, and everything was stripped out of it. The previous switch was a harlan switch. But i was told they no longer make them. On the summit i have:
red-12V acc
black- ground
white- tach #6 coil
and wiring coming from the VI + side hooked to 12v, gound side hooked to the yellow wire on the rpm switch
red-12V acc
black- ground
white- tach #6 coil
red-12V acc
black- ground
white- tach #6 coil
red-12V acc
black- ground
white- tach #6 coil
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
