Sponsored by:
Sponsored by: CARiD
SSIM mod powerloss question
Old Mar 23, 2008 | 03:11 PM
mastercoryd's Avatar
Hey ive seen dyno's and heard ppl say that the SSIM mod u loose bottom to mid range hp and it evens out and gains after like 5k+ rpm's...
and i was figuring that was with stock parts... if u had an ECU and tune, Headers, full exhaust mandrel bent (really good breathing car) with an intake and a leightweight flywheel as your mods would u have a descent midrange with the SSIM and maybe start loosing only like under 4ish or w.e? ive tried searching for an exact answer like this but i wanted to make sure it was under the same scenario so thanks guys in advance - cory d
Old Mar 23, 2008 | 03:34 PM
nismology's Avatar
It causes a loss of volumetric efficiency in a specific RPM range so it will never completely go away.
Old Mar 23, 2008 | 07:40 PM
yeah i understand that but is it a major loss even with those mods or is it barely noticeable but will feel the top end diff.
Old Mar 23, 2008 | 08:22 PM
oldngivout's Avatar
Willing to learn
Oops, beat me to it.
nismology's Avatar
There will always be a lull in acceleration in that range. The most you can do is try to bump timing there but it will always be noticeable. You can't have your cake and eat it too. Most, if not every non-VI intake manifold sacrifices one portion of the powerband NOTICEABLY.
With that said, it's a worthwhile modification if you value top-end power.
Old Mar 23, 2008 | 08:50 PM
!PrjctMax!'s Avatar
How is MPG effected by this?
Old Mar 23, 2008 | 09:06 PM
nismology's Avatar
I'm pretty sure that has been discussed before. Any reason I shouldn't lock this?
Old Mar 25, 2008 | 01:18 PM
oTranscendental's Avatar
Originally Posted by nismology
There will always be a lull in acclereration in that range. The most you can do is try to bump timing there but it will always be noticeable. You can't have your cake and eat it too. Most, if not every non-VI intake manifold sacrifices one portion of the powerband NOTICEABLY.
Hey Nismo,
In my case I don't have the VI or VTC hooked up so I can feel the power loss below 4k, but after that it pulls very well.
Here is the question... if I do the SSIM, will the lull in power before 4k be even worse than now(non-working VI), or about the same? Cuz if its relatively the same, I would like to have the extra top end.
What do you say?
PS: I have an RPM switch waiting for install. Should I just do that instead of SSIM? I wonder which will give better 1/4 times.
Old Mar 25, 2008 | 01:50 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by oTranscendental
Hey Nismo,
What do you say?
http://forums.maxima.org/showthread....614&highlight=
Old Mar 25, 2008 | 02:50 PM
Thanks for the link, I've actually had it bookmarked since 2006.
Its a tough call. 20hp/tq gain below 4k with RPM switch or 20hp/tq gain above 5.5K with SSIM.
The RPM switch seems like a good idea for daily driving, but the SSIM is probably best for the drag stip.
I'm going crazy trying to figure out which is better! They seem like they are both nearly even.
Linear power curve vs. sloped w/ more net power.
Please excuse the dead horse beatings
I think that the rpm range you are in when banging through the gears means that you would only be under 4K for 500rpms. So for racing purposes SSIM would be better because you would net more power.
But I still feel like the VI would be just as close even without the SSIM top end power.
Someone check my logic here...
Old Mar 25, 2008 | 03:10 PM
What I really want to know is:
If I do SSIM will there will be a significant power loss greater than what is shown on the dyno graph below 4k with the VI constantly open(no rpm switch)
I've driven the car like this (red graph) for 2 years and its fine for daily use. If I can squeeze 20 more ponies out w/ssim for highway thrills I might concider doing that over the rpm switch.
Green: VI Closed
Red: VI Open
Blue: Old VQ30DE days
Old Mar 25, 2008 | 03:30 PM
!PrjctMax!'s Avatar
http://forums.maxima.org/showthread.php?t=557307
#31 down
TQ gets you off the line
HP keeps you going
You pick...
Old Mar 25, 2008 | 04:35 PM
Well, I found a thread that answered my question:
http://forums.maxima.org/showthread.php?t=552190
If you are interested check it out!
POST #11:
95BLKMAX
No need to post my dynos, but as far as "midrange loss" when gutting the IM is concerned...
If like 90% of 3.5 swaps, your VI is currently not working, you will NOT loose any midrange power. The "loss" is already there from not having the VI functioning. So if you do the SSIM, really you have NOTHING to loose, and ALL to gain, mainly after 4500, thats where my powerband kicks in like woah.
Pre-SSIM I was ~180-185whp at redline, Post-SSIM I went up to 210whp. Added catback and 3" MAF took it up to 230whp. Add cutout and I dont remember what I gained at redline but it was ubber, lol. If you add some adapters clocked to have the Int cams in their "fully retarded" position, that redline would be insane with this mod on an A32
Old Mar 25, 2008 | 07:58 PM
!PrjctMax!'s Avatar
Yaup, that's another thing that convinced me.
Old Mar 26, 2008 | 06:30 AM
NmexMAX's Avatar
dot dot dot ...
Your VIAS system (2 stage) and CVTC (Z33) mapping make your comparisons invalid against oTranscendental's.
Mar 12, 2020 12:06 AM
ballerchris510
Sep 23, 2015 08:46 PM
Pixel
Sep 15, 2015 05:53 AM
Maxima Pride '07
Sep 12, 2015 07:29 AM
Johnny9595
Sep 3, 2015 05:18 AM
