Sponsored by:
Sponsored by: CARiD
LC-1 wideband questions
Old May 31, 2008 | 09:37 AM
chillin014's Avatar
Okay...I planned on installing my wideband and tuning today until I was told/and read that there isnt actually a wire to connect to the RPM wire on the ECU. Can someone clarify that there is another component I need to buy in order to tune this? I got the impression one of the wires connected to the RPM wire and then I could datalog on my laptop.
How do you guys tune without having an RPM to look at on the graph?
Old May 31, 2008 | 10:21 AM
95BLKMAX's Avatar
It does it by time. You as the driver know the RPM that you start and end the run. So you know thats the rpm range you have to work with when you log. Then you make the corrections in that range guesstimating more or less wat point in time is what RPM.
Its EASIER if you have an RPM X-Axis on the log, but really you dont HAVE to have it to log and tune. Takes maybe 1 or 2 more runs to get it all right but its no big deal. I've been tuning like this for months, and this si how we've been tuning streetz' car for like 2 yrs now. Works just fine
Old May 31, 2008 | 10:25 AM
chillin014's Avatar
i appreciate the help man. looks like i'll have to get a friend to help me with managing the computer then while i'm driving
Old May 31, 2008 | 11:10 AM
chillin014's Avatar
alright the wiring is pretty straight forward except for the brown wire which is Analog 2. I dont think I need it, although it shows it hooking to the ECU in the diagram. Analog 1(yellow) is for a gauge and I'm not using one at the moment so I know that one will be loose. Should I be leaving the brown wire loose as well?
Old May 31, 2008 | 11:36 AM
zero2sixtyZ's Avatar
You embarrass me.
My buddy purchased the SSI-4 to log the RPM signal as well. Take a look at the innovatemotorsports site.
Old May 31, 2008 | 11:38 AM
chillin014's Avatar
ah yeah I was reading about that. I'll have to get that in the future, I'm going to try to tune this today. thanks
Old May 31, 2008 | 04:56 PM
chillin014's Avatar
my laptop isnt that old but..it doesnt have a serial port that matches with this db-9 cable that came with the kit...
Old May 31, 2008 | 06:41 PM
PeteusMaximus's Avatar
The more I read these threads, the more I start to think it'd be alot easier to just go get cars dyno tuned.
I just bought a used safc2. I dont have: a laptop, wideband with 02 sensor or anykind of rpm reader. What would it cost me to do it myself? At least $400 for the laptop, $3-400 plus for a wideband, another $100+ for whatever to look at rpm signal, then what software do I use on the laptop? Sounds like alot of money to try and do this? Am I missing something here?
Old May 31, 2008 | 07:11 PM
kzoosho's Avatar
Radioshack sells a serial to usb adapter. Thats what i am using to log my zt-2. I think you can find them cheaper on ebay or something man.
Old May 31, 2008 | 07:12 PM
kzoosho's Avatar
And to you if you plan to mod once and never change things then yes a dyno tune is in deed cheaper but if you are like me and others we would be spending thousands of dollars or tunes and waiting to have it done.
Old May 31, 2008 | 07:26 PM
chillin014's Avatar
thanks. I'll check that out.
new problem. I make my corrections, I subtracted up to 20 points(?) of fuel and showed no differences on the wideband. I kept going back to subtract more fuel but was getting the same results on the wideband.
2nd gear pulls- VAFC2. any ideas? 500 rpm increments. Its dipping down below 11 and steady in the 12's up top.
I changed it back to no corrections since it wasnt giving me any results, just to be safe.
thanks.
on the wide-high map.
Old Jun 1, 2008 | 11:47 AM
You embarrass me.
Could you elaborate more on the time method? I have the SAFC2 and the LC-1, but was waiting to install when I bought the SSI-4. I have a laptop and can connect to an LC-1 no problem, but the tuning w/o RPM is where I would see difficulty.
Old Jun 1, 2008 | 12:20 PM
chillin014's Avatar
the way I understood it was basically that you record your run (from 3k to 6500) and nothing more. That way when you look at your graph you know the beginning of the graph is 3000~ rpm and the end is 6500~ and everything in between is the rest of your powerband kind of like a dyno chart. I was doing it last night and I got the basic concept down I just wish the car would make the changes that I entered into the vafc.
I started at 10.9 and it went up into low 12's toward the upper end. I've been driving like this for over a year
Old Jun 1, 2008 | 01:23 PM
pmohr's Avatar
No more Maximas...
You could also add in a fair amount of fuel at one arbitrary RPM, then use that as a reference point in the wideband's logs.
Old Jun 1, 2008 | 01:39 PM
chillin014's Avatar
oh I see waht your saying. I just want my adjustments to make a difference period right now....I got zero response from my changes....
Old Jun 1, 2008 | 01:56 PM
pmohr's Avatar
No more Maximas...
Sure the VAFC-II is wired in/configureed correctly?
Old Jun 1, 2008 | 02:01 PM
chillin014's Avatar
pretty sure yeah. would it even work if it was wired wrong? I am fairly sure the configurations are right. 10% and 50% for my throttle setting. the setup is correct.....i donno.
Old Jun 1, 2008 | 02:03 PM
kzoosho's Avatar
what maf are you running and what are your in and outs?
Old Jun 1, 2008 | 02:06 PM
chillin014's Avatar
stock maf. 4 in 4 out.
Old Jun 1, 2008 | 02:16 PM
kzoosho's Avatar
and you say you made corrections and it did nothing? Try adding to see if it makes a difference.
Old Jun 1, 2008 | 03:05 PM
chillin014's Avatar
Correct no changes at all. I will try adding tomorrow when I get back home.
Old Jun 1, 2008 | 04:00 PM
kzoosho's Avatar
You do know that pulling fuel adds timing also. Wasnt sure if ya knew.
Old Jun 1, 2008 | 06:09 PM
chillin014's Avatar
Well I kinda knew that.sorta...that's a good thing though right? Doesnt really have much to do with the irresponsiveness though, yeah?
Old Jun 1, 2008 | 11:29 PM
95BLKMAX's Avatar
For All Motor, Adding ign timing= FTW!!!!
Old Jun 2, 2008 | 01:37 PM
chillin014's Avatar
well I hope I can add a significant amount indirectly/this way...I'm going to tinker with it later this afternoon when it cools off.
Old Jun 2, 2008 | 03:03 PM
chillin014's Avatar
the only wires I connected to the ECU are...the throttle position wire, both grounds, both power wires, the maf input and output and the RPM wire. are there any kind of vtec settings I need to be entering numbers for to allow the vafc to make corrections or something?
Old Jun 3, 2008 | 09:31 PM
chillin014's Avatar
I bought the damn cable. Now when I plug it in its telling me I need a driver. Excuse my ignorance as far as this goes...but is this something I should be able to get off their website? I have version 2.04 of the software so Im not sure if I need to be updating any firmware or what to do really.
Old Jun 4, 2008 | 11:48 AM
xraver_px's Avatar
what does the error message exactly say?
did the cable come with an installation cd?
Old Jun 4, 2008 | 12:15 PM
chillin014's Avatar
your right. there was an installation cd for the cable...it was the tiny discs, taped in the packaging real hidden.
thanks. starting a new thread for my vafc now. im done with this one.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
