Sponsored by:
Sponsored by: CARiD
fans not work with EU board E
Old Oct 4, 2008 | 04:47 PM
liqidvenom's Avatar
brotherhood of tq
I got my Eu up and running just fine this afternoon and i followed dandys write up but for some reason My fans arent coming on and my water temps climbed to 190 where i just shut it off.
I have heard of one other org member having this issue and he just cut the wire and isnt using the water temp. http://forums.maxima.org/all-motor/5...ease-help.html
I would rather find a way to make use of it if possible. Do any of you gents have any ideas on how to make this work?
will
Old Oct 4, 2008 | 05:37 PM
matty's Avatar
I changed one of the Jumper settings inside on the EU board to make my fans activate.
-matt
Old Oct 4, 2008 | 05:38 PM
liqidvenom's Avatar
brotherhood of tq
did you have board e also?
and was it jumper 13?
Old Oct 4, 2008 | 05:43 PM
matty's Avatar
I have no idea if I have a board e or not..is that a new syle board ?
was it jumper 13?
Coulda been. I really forget what jumper it was.
Old Oct 4, 2008 | 06:45 PM
liqidvenom's Avatar
brotherhood of tq
do you think you can check and if it is a board e can you take note of where you jumpers are
Old Oct 4, 2008 | 10:18 PM
liqidvenom's Avatar
brotherhood of tq
Ok i just tried both jumper settings and it doesnt seem to work for some reason. I am going to try to go down in software to 2.0 and see if that changes anything.
Old Oct 4, 2008 | 10:46 PM
liqidvenom's Avatar
brotherhood of tq
ok i tried 2.0 with jumper 13 open and the fans didnt kick on. my car got up to 190f and i just turned it off. Any one have an idea what temp the fans normally kick on?
How many if any guys are using an eu with a board type e? if you are how did you get around this issue and still have the water temp values recorded?
Old Oct 4, 2008 | 10:55 PM
mastercater7's Avatar
VQ35 FTW
Disconnect the wire for the water temp for the meantime. Ill pm you my number and Ill try to help ya out.
Zack
Old Oct 5, 2008 | 10:38 AM
liqidvenom's Avatar
brotherhood of tq
Zach
thats what i plan on doing. I'll give you a call later today and run some of this stuff by you. I did notice that i think version e has more jumpers then what is listed in dandys write up.
Old Oct 5, 2008 | 01:56 PM
liqidvenom's Avatar
brotherhood of tq
OK so i just opened my board to check out some stuff before i call zach and i noticed that i have 21 jumpers in here, which is more then the amount that danady has listed in his write up. The 21st jumper is set to 1-2 so i'm not sure if i should open it and see what it does.
Old Oct 6, 2008 | 04:55 PM
DandyMax's Avatar
3.5 in the works
Last I knew, using either "open" or "1-2" on JP13 would always work depending on the sensor type in the car (as mentioned in my writeup). I'm not aware of any difference in that regard with board E unless someone can definitively prove otherwise.
JP21 I can't remember exactly what it does (was added in version E) but I called Greddy on it a while back and was told to leave it in the default position, which I did and had no issues (on an install on a 98). IIRC it was something related to the I/J settings (ie another add/trim switch or something).
Old Oct 6, 2008 | 05:45 PM
maximariceboi's Avatar
i got mine tuned without using the water temp....but now i'm running into other issues with the engine...EU is the least of my concerns =/
Will...get it working yet?
Old Oct 6, 2008 | 07:06 PM
pmohr's Avatar
No more Maximas...
Only one of my three EU installation manuals mentions JP21 (the newest, obviously). It says:
Injector Input / Output Signal CH1~6
This jumper will Configure the Injector Input/Output Signal Ch1~6.
Set to "1-2" when using Injector Adj. Map to trim and add fuel, and set to "OPEN" to add only.
Funny thing is that it doesn't list it in the jumper chart, but only in the area where they are all explained.
Old Oct 6, 2008 | 07:47 PM
liqidvenom's Avatar
brotherhood of tq
If you want dandy i could make some videos showing you what is going on. Is there any type of software you would like for me to use or anything in particular?
My car drives just fine with the water temp wire not attached to the EU. It has developed a slight hesitation which is only present in 1st and 2nd gear at 900 rpm with a slow application of throttle. i'm not sure what it is, but ill try to figure it out.
Old Oct 11, 2008 | 12:46 PM
liqidvenom's Avatar
brotherhood of tq
I got my water temp working, i taped the sensor like normal but then i cut the wire going to the EU and i added a quick connect there. At 205f the fans kick on and its been working for about 20mins in near 80 degree heat.
It might have been a path of least resistance issue or something that was keeping it from working before. I'll keep on testing it to make sure it works constantly.
Zach i will be calling you later tonight, i ran into another small issue.
MattWithTheMaxima
Jun 30, 2017 01:06 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
jerrod99_se-l
Aug 24, 2015 10:24 AM
Carlos Levy
Aug 23, 2015 08:48 PM
kenc15
Aug 5, 2015 08:29 AM
