Sponsored by:
Sponsored by: CARiD
AFR Help
Old Jan 11, 2009 | 05:11 PM
505max94se's Avatar
AFR Help
I just installed an Innovate LM-1 and an Apexi V-AFC II. I figured that I would try to lean things out a bit to free up some power. I was a little confused when I did a baseline datalog. My fuel pressure was 43 psi and I didn't do any air correction with the vafc. Any thoughts on why it's already so lean??
This is from about 2k-6.5k rpm in 2nd gear.
Old Jan 11, 2009 | 08:53 PM
95BLKMAX's Avatar
You cant get an accurate reading of a/f on a short gear like 2nd. You have to go to 3rd gear at least so it puts more load on it. The lower loads of the shorter gears makes for a leaner a/f reading (that you are seeing). That is not your real a/f. Get a 3rd gear log, THEN you have something more accurate to work with.
Old Jan 12, 2009 | 01:50 PM
505max94se's Avatar
I thought about logging a higher gear and I definitely will now that you've mentioned it, but I was expecting the AFR to be somewhere between 10.5 and 12. Would logging a 2nd gear vs. 3rd gear really show that much of a variation?
What do you think about logging 2nd gear going up a steep hill? I just don't like the idea of doing multiple 3rd gear pulls on the street.
Old Jan 12, 2009 | 03:53 PM
nismology's Avatar
There shouldn't be that much of a variation from gear to gear with an n/a motor. What's the indicated AFR at idle?
Old Jan 12, 2009 | 04:45 PM
505max94se's Avatar
That's what I thought. Idle AFR is ~14.7, right where it should be, imo.
Old Jan 12, 2009 | 04:59 PM
nismology's Avatar
My first step would be to bypass the AFC.
Old Jan 12, 2009 | 05:09 PM
505max94se's Avatar
I was thinking about trying that.
Is there any difference between 1in 1out and 4in 4out?
Old Jan 12, 2009 | 05:36 PM
t6378tp's Avatar
Turbo 3.5
exhaust leak
do you still have all 3 cats you will read alittle leaner/richer depending on the sensor location
did you make sure the corrections on the controller is zero'd out
Old Jan 12, 2009 | 05:41 PM
nismology's Avatar
Originally Posted by t6378tp
exhaust leak, do you still have all 3 cats
Pre-o2 exhaust leak causes a rich a/f during closed loop conditions. His a/f is lean during an open loop condition.
Old Jan 12, 2009 | 08:20 PM
t6378tp's Avatar
Turbo 3.5
I was referring to a possibly leak near the wo2 which could make it read lean due to the extra air
also a intake leak could cause the lean reading. it happened to me when a vac cap starting to go bad I used to plug the manifold, it was weird cause during light throttle and idle the a/f would be fine but under 80%-wot it would read lean. the only difference in his graph and mine was I would spike really bad around 4k
Old Jan 12, 2009 | 09:25 PM
505max94se's Avatar
exhaust leak
Afaik, I don't have any exhaust leaks. I only have one cat (it's a VE) and the WBo2 sensor is located slightly upstream in the factory o2 sensor location. The corrections were definitely zero'd out and it was set to 4in 4out.
I didn't mention that this pull was done going down a slight hill which is probably why it's so lean (along with the fact that it was in 2nd gear).
I did some more tinkering and made a few runs. My last run was done in 2nd gear, going up a steep hill, with 1% more fuel. The AFR was between 12.5 and 13 from 4k to 6.5k rpm. This is better, but it's still alot leaner than I was expecting.
Old Jan 12, 2009 | 09:32 PM
505max94se's Avatar
I was wondering if I have an IM leak. I really don't think that I have one because it idles smooth and I don't hear any leaks, but maybe I'll look into it a little more.
Old Jan 13, 2009 | 04:40 PM
t6378tp's Avatar
Turbo 3.5
mine would whistle like a sc which turned out to be a good thing and allowed me to find it really fast
Finkle
Sep 27, 2015 09:53 PM
Stephen Max
Oct 22, 2004 10:40 AM
MardiGrasMax
Sep 14, 2004 07:00 PM
Stephen Max
Jul 31, 2004 11:40 AM
max'n out
Jan 4, 2002 09:12 PM
