VQ30DE-K OEM Piston Ring Material
The maximum tolerance between the cylinder wall and the piston is .004 or .005 if I remember correctly, I dont have my spec sheet in front if me but from the bottom of my mind, I remember that the tolerance on my block was .007 and out of spec for stock size piston.
I took the decision with my technician to have the engine honed oversize in order to match the custom .020 oversize piston I ordered later. The shop will machine the block to have .003 of clearance between the cylinder wall and the piston.
If your block is out of spec, you have the following choice:
1- Hone the cylinder wall by let say .020 and order custom piston.
2- Sleeve the engine and use stock piston or custom oversize.
3-Replace the engine block, but if you buy a used one you may end-up back to the beginning.
I hope it help.
AA
I didn't know that different honing technique would be used depending on the ring material, I thought it was related to how the engine would be used, ie: race car that is N/A or race car that is boosted or or a street machine. The custom piston I ordered are not arrive yet so I dont think the shop fm wouldn't know until he see what material was used for the custom piston. I remember the foreman saying that whenever they honed a block for a boosted application the cylinder lower portion is not totally circular and you need to have the wrist pin set @ .040 instead of being in the center but the stocker are also at .030 or .040 apparently this allow for more HP.
And the last thing you mentioned is wrist pin offset and is usually a function of a motor's rod:stroke ratio, piston material/skirt design and piston-to-wall clearance. It increases rod angularity on the power stroke to reduce piston slap (noise).
There are different stones/grit, varying RPM and up and down strokes per minute used during the honing process to maximize the chances of the different ring materials seating properly.
This is very well explained and I couldn't have explain the way you did, my french brain doesn't allow me to have such ability to formulate nice sentence in the Shakespeare language. Most of the time when I want to explain something complex in English, it require me a lot of attention and I literally struggle to formulate what I want to say. I'm pretty good in french but most of you wouldn't understand what I'm saying.Lol
Thanks again.
AA
Thanks again.
AA
Thanks again.
AA
Something else that has come to my attention and somewhat bothers me. The FSM calls for out-of-round and taper measurements with the block unloaded, but a common practice is to hone with a torque plate to achieve roundness with the clamping force of the head. Has anyone else picked up on this discrepency? what has your machine shop suggested?
Alright guys, got talking to DaveB today and he confirmed that the VQ30DE-K (I suppose these are the same for all VQ30s?) are a chrome-tipped top ring and an iron 2nd ring. Now we know!
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
atriuum
Sep 28, 2015 01:19 PM
Pied
Sep 26, 2015 03:29 PM
Does anyone know?
