Sponsored by:
Sponsored by: CARiD
Two I/J Maps Open at Same time= problems?
Old Jul 9, 2009 | 01:01 AM
MaximaSpd85's Avatar
ok, i figured if i could open both EU i/j maps and set each one for a different range of rpms (one set for 3k to 5500, the other from 5500 to 7200) i would get more tuning points, etc. is this not a good thing/possible to do? when i did this, the car leaned out VERYYYYY bad, and would barely accelerate so i let out. The a/f curve spiked like crazy up and down into the 20s and 10s and hesitated like crazy. when we took one of the maps away, and put everything back to normal the car drove fine again. what happened there?
Old Jul 9, 2009 | 02:21 AM
whlimi's Avatar
If you havent already done so, set up your second map so that it starts off at 6000 instead of 5500. If you have modified the pulse width for 5500 RPM in both maps , the EU will stack those figures and you will run lean.
You also didnt mention at what range it leans out. Is it leaning out right from 3K or from the transition point between the two maps?
Old Jul 9, 2009 | 07:18 PM
right, i understand that it will stack figures. but this was different. it leaned out and rich spiked back and forth. for example, it leaned to 20 at 3400, then richened to 10 at 3800, then leaned to 20 again at 4200, and so on. (those arent exact numbers but u get the point.) this happened from the moment i hit the gas at 2500 rpms and i let off after a few seconds after i realized what was going on and the graph went crazy. the graph went up and down. it basically felt like a horrible hesitation. or like when u run out of gas and the car just bucks. my two maps were on totally different ranges. one from 3000 or so up to 5500, the other from 5700 on. so they werent overlapping.
kjlouis
Nov 24, 2018 06:09 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
mrgooch
Aug 9, 2015 11:00 AM
