Sponsored by:
Sponsored by: CARiD
4th Gen Fidanza Flywheel not fitting on Crank Shaft
Old Aug 5, 2009 | 06:23 PM
OC_Nooby's Avatar
Hey
I ordered a fidanza flywheel (12lbs) and clutch from ebay. The flywheel weighs 12 pounds as stated and the clutch checks out. Now when I went to go put it on the flywheel does not fit on the crankshaft as the center hole is to small. My brother says the flywheel is a knock off. Is there any way of figuring if its a true fidanza flywheel? It does have some sort of ID scratched into the flywheel but thats it.
Any help would be appreciated. The flywheel is going to a machine shop tomorrow to have it enlarged, of course the original flywheel is going with it for proper measurement.
Old Aug 5, 2009 | 08:31 PM
maxboy325's Avatar
I've never heard of this, but if your having it machined then I guess it wont matter. Maybe someone will chime in that has had the same problem.
Old Aug 6, 2009 | 06:57 AM
mtrai760's Avatar
'Trynna' is not a word
I have installed a few Fidanza's and they have always been really snug. The one I just installed took a few minutes of light sanding and testing to get it to fit right. Never required any machining though.
Old Aug 6, 2009 | 01:13 PM
OC_Nooby's Avatar
was there any labels or marking to show that its a fidanza flywheel?
Old Aug 6, 2009 | 07:24 PM
Tmars's Avatar
Originally Posted by OC_Nooby
Hey
The fidanza I installed was snug as well, I just put in 6 flywheel bolts and tightened them evenly with not much effort till it pulled flush with the crank. Then removed the bolts and re-installed with loctite and torqued to 69 ft-lbs, have 600 miles on it now no vibration.
Old Aug 12, 2009 | 09:52 AM
Blazingwolf's Avatar
what's the weight difference on the fidanza? I ma very interested in the flywheel but Aasco said the stock flywheel was like 15 pounds? and that 5 pounds would be better? im looknig for about half of the stock weight. can anyone verify what that might be?
i have a 4th gen
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
kenc15
Sep 25, 2015 06:38 AM
