Sponsored by:
Sponsored by: CARiD
question?
Old Aug 6, 2009 | 12:51 PM
04flspecv's Avatar
question?
I'm new to the vq scene. i saw the cosworth heads and didn't find any info or reviews on it. I was wondering what ya'lls thoughts would be on the cosworth heads w/ JWT c8 cams.
would it be beneficial on a NA set up?
heres a link to the heads
http://www.stillen.com/product.asp?i...SAN&model=350Z
thanks in advance
Old Aug 6, 2009 | 04:00 PM
04flspecv's Avatar
bump. please chime in anyone?
Old Aug 6, 2009 | 04:55 PM
Nealoc187's Avatar
SLOW
you don't need to bump a thread from 2 posts down back to the top of the forum a mere 4 hours after it was posted. this forum gets a couple posts a day in it, your thread is not going to get lost in the shuffle. do not do that again.
VQ35 heads are some of the best flowing factory heads in existence on any normal street car (by that I mean short of supercars). unless you are building a race car and by that i mean a RACE car and you are willing to pay through the nose to get every single ounce of power you can out of the VQ35 NA, there is no way I would spend the money on touching the heads of a VQ35 let alone get the cosworth heads for it.
Cams are another story stock VQ cams are very mild. I don't know the specs on the C8 specifically, but cams are very worthwhile on a VQ assuming you have lofty power goals either NA or boosted.
Old Aug 6, 2009 | 09:53 PM
04flspecv's Avatar
thanks for the info, i didn't know its that serious for a measely bump.
i'm not sure of the specs of the c8's but travis used them on barry's car which is another sentra vqswap.
i was told from another member on my sentra site that going +1mm on the ports wouldn't be beneficial on a NA motor.
so if any more info that can be posted it would be great.
thanks again.
Old Aug 7, 2009 | 06:32 AM
doublea's Avatar
thanks again.
The Cosworth VQ35 heads are a piece of art but the price is steep. If you can P & P the heads yourself and have the valve seat bored by a machine shop you would save a bundle and have better flowing heads, but this kind of job take countless hours. I have a VQ 30DEK and I did an extensive P & P jobs on the VQ DEK heads, I then took them to a machine shop where they replaced the valve guide for manganese/bronze one but they also increase the valve seat by 1 mm ( this was done on a CNC ) The heads where also mounted with HR spring & double shim. I should know within the next month how well the heads flow now but there is no doubt in my mind that they will flow much better than before.
Adding aggressive cam would definitely give you more HP & TQ's, how much more ? well this depend on what other mods you have but I think a 15 HP should be close to reality, with a good tuning and P & P on the heads I think that should be in the 25-30 HP + range.
I will know for sure only when my car is running and dyno'd.
Hope it help.
Cheers
AA
Old Aug 7, 2009 | 07:49 AM
grey99max's Avatar
LandShark has Cosworth
thanks in advance
I'm in the final stages of assembling a seriously-built short block ( CP pistons, Carrillo rods, balanced, etc) and a new set of Cosworth heads and ZK2 cams for my '99, using the 3.0 timing setup with custom gears... I like the 10,500 RPM valve train - gives me a reason to upgrade the ECU setup.
http://forums.maxima.org/all-motor/5...her-3-5-a.html
Check with Cosworth for details: http://www.cosworthusa.com/
Their NA power gains were - impressive. Their flow bench numbers were also impressive.
Check on one of our member's experiences with porting the VQ35 heads and racing N/A with his car.
http://forums.maxima.org/all-motor/5...ss-thread.html
Make your own conclusions...
Old Aug 7, 2009 | 09:22 AM
04flspecv's Avatar
awesome info guys. can't wait to see ya'lls #'s on ya'lls build. I really appreciate the info and ya'll taking the time to post up useful info.
thanks again.
later
chris
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
