Sponsored by:
Sponsored by: CARiD
Any one know what a Built 3.5 compression psi would be per cylinder?
Old Aug 9, 2009 | 05:53 PM
96sleepergle's Avatar
Do any one know what the exact numbers should be on a built vq 3.5 bored out .020 over stock (3.6) liters with 9.0:1 wiseo pistons , did a compression test and got 175-180 psi from cylinders 1-3-5 and 160-165 from 2-4-6 getting mixed numbers when searching
Old Aug 9, 2009 | 06:06 PM
nismology's Avatar
The numbers from bank to bank should be pretty consistent. There seems to be a 20PSI max variance with your setup and that is excessive per the FSM. Either there's a head gasket breach all along the front cylinder bank or the cam timing is off (more likely of the two).
Old Aug 10, 2009 | 09:29 AM
Yep your right was discussing it with my brother theres no oil spitting outof the breather filter nor smoke but it seems to be off sequence when you listen to it idling never thought of the cam timing being off but thats what it sounds like your the man nismology tilley built this motor there were aot of F+++ked things he did so we will be pulling this motor to fix all his screw up
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
