Sponsored by:
Sponsored by: CARiD
3.5 Swap Questions
Old Sep 14, 2009 | 08:39 PM
Steve31's Avatar
3.5 Swap Questions
I have been reading for days about all the swaps
The questions I have are
I see some people used the 3.0 timing.
Why change the timing stuff over?
I have a 95 se AT could I still keep the AT without doing major mods...Or would it be best just to buy the 3.5 with the 6spd and ecu ?
And how much nitrous can it handle vs the 3.0
I did find out I will have to buy the TB adapter from another org member
Old Sep 15, 2009 | 05:51 AM
throttlehappy46's Avatar
People use the VQ30 timing chain setup as it has the cam position sensor on the intake cam gears.
Old Sep 15, 2009 | 09:17 AM
ajcool2's Avatar
You can use a 6 speed and ecu but search a full 3.5 swap and you'll quickly find out why most people go the other route.
Old Sep 15, 2009 | 09:28 AM
Steve31's Avatar
Ok so just swap the timing setup into the 3.5 along with a TB adapter from stephen and use all the 3.0 sensors and wiring I should be good ?
And make sure the o-rings stay in the oilpan
Old Sep 15, 2009 | 04:33 PM
nismology's Avatar
Almost EVERYONE swaps the 3.0 timing over. These are basic swap questions with which this section is rife. Please continue to read/search as it will probably answer every question you have and then some.
Old Sep 15, 2009 | 05:51 PM
93altima's Avatar
Turbo 4th Gen
Ok just basically this is my setup
02 Maxima 3.5
Stephan max cam adapters
Stephan max Pathy TB adapters
00-01 Pathfinder Throttle Body
Full 3.0 Timing and upper and lower Oil Pans
New water pump & chain tensioners
6 puck Clutch
Old Sep 15, 2009 | 07:00 PM
Steve31's Avatar
02 Maxima 3.5
6 puck Clutch
Cool
That helps alot
Dont look like a whole lot (besides the work involved lol)
I<3 A32's
Sep 10, 2015 11:07 AM
MaxLife17
Sep 8, 2015 02:36 PM
JoshG
Sep 5, 2015 10:10 PM
Maxboy23
Sep 4, 2015 06:04 PM
Johnny9595
Sep 3, 2015 05:18 AM
